Old 11-19-2011, 10:02 AM #1
Nelsonmd's Avatar
Nelsonmd Nelsonmd is offline
Nelsonmd is on a distinguished road
Nelsonmd's Avatar
ABS/VSC/TRAC Disable Master Thread
In order to avoid loading multiple threads into the Documentation and Reference Thread, I wanted to assemble all the different ABS threads into one that we could load in there, so here goes:
ABS Disable on E-locked 4Runners - '96-'00 and some pre-wired non-locked's)
AKA the Yellow-Blue Wire Mod
ABS Switch - Easy, effective and simple
ABS Disable on non-E-locked Runners - '96-'00 (2 methods)
ABS Disable on older 3rd gens
Updated thread:
ABS disable V2.0 for older 3rd gens (On/off on the fly)
ABS, VSC, TRAC Disable on '01-'02
Disable VSC, TRAC, and ABS without damaging factory wiring
VSC, and TRAC Disable on '01-'02
Disable VSC/TRAC Only
Disabling VSC & TRAC - 2001-2002 4Runner with VSC & TRAC Systems - YotaTech Forums
Disable VSC and TRAC but not ABS on '01-'02
AndyMod 2.0. ABS Remains Active. - YotaTech Forums
A couple guys mention disabling VSC withouth disabling ABS or TRAC, If anyone has a write-up for that, post it and I will add it. Same for any other methods of disabling any of these, post them here and I will add them.
2000 SR5 3.4L V6 Automatic 4x4, e-locker, 175k Miles, Rust
Imp. Jade Mica with Oak Leather Interior, Field Monitor Unit - B&M Tranny Cooler - SG2 - New (to me) rear axle assembly - Goodyear Duratrac 265/75-16 - 1.8" Ironman Front Lift, OME 906/Procomp 9000 Shocks
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
Nelsonmd is offline   Reply With QuoteReply With Quote
Old 12-30-2011, 09:06 PM #2
chrisdowling84's Avatar
chrisdowling84 chrisdowling84 is offline
chrisdowling84 is on a distinguished road
Just got done with this mod yesterday, i love it! I was so disappointed the first time i went out to "play" and figured out there would be no fun to be had with the 4runners nanny mode. Only took about 35 mins to complete!
chrisdowling84 is offline   Reply With QuoteReply With Quote
Old 02-11-2012, 07:22 PM #3
Maritimer's Avatar
Maritimer Maritimer is offline
Maritimer is on a distinguished road
Maritimer's Avatar
Good job. I have to do this soon, as sliding through intersections in the snow is way not fun.
2001 SR5 4X4, V6, 3.4L
Maritimer is offline   Reply With QuoteReply With Quote
Old 12-12-2012, 02:44 PM #4
dhalsey dhalsey is offline
dhalsey is on a distinguished road
Has there been any update to this? Has anyone found a way to disable just the VSC alone on the 01-02?
dhalsey is offline   Reply With QuoteReply With Quote
Old 12-12-2012, 03:49 PM #5
98OzarksRunner's Avatar
98OzarksRunner 98OzarksRunner is offline
98OzarksRunner is on a distinguished road
I just did this one. Took 15 minutes and works great. Disables VSC and TRAC but not ABS.
2002 T4R Limited, 191K miles - OME 883 front - LC 7 wrap/2nd gen sway bar links rear - Detroit Truetrac Diff - Cooper A/T3s - Warn M8000 - ARB Bumper - homemade (er, 'custom') rear bumper w/tire & can carrier - BajaRack - Diff Breather Mod - Hayden trans cooler - Yaesu 2M, Cobra CB - Fridge, off-road trailer with Tepui RTT (real expo poser)
In Africa they say: "Buy a Land Rover and it will take you anywhere. Buy a Toyota and it will take you there ... and bring you back home." jannikt on wranglerforum.com - I'm guessing he didn't make many friends there with that line.
98OzarksRunner is offline   Reply With QuoteReply With Quote
Old 12-12-2012, 03:52 PM #6
So Many Roads's Avatar
So Many Roads So Many Roads is offline
So Many Roads is on a distinguished road
Nelsonmd - Thanks for consolidating these links... My ABS was f'ing with me just yesterday & I can't wait to disable it.
I read the first two links - it didn't look like anyone was able to get the Yellow-Blue wire mod to work...? Dylan's writeup (second link) looked like the best option for 2000 and earlier 4R's.
'99 SR5, 5 spd, Bilstein 4600, elocker mod, TBU
So Many Roads is offline   Reply With QuoteReply With Quote
Old 12-12-2012, 05:35 PM #7
ddking's Avatar
ddking ddking is offline
ddking is on a distinguished road
ddking's Avatar
Second that!
ddking is offline   Reply With QuoteReply With Quote
Old 12-12-2012, 05:39 PM #8
Nelsonmd's Avatar
Nelsonmd's Avatar
Updated the first post. Thanks for the addition.
Glad people are finally noticing this thread. I thought it was useful, but it got very few views at first...
Old 01-29-2013, 03:28 PM #9
4RUN0326 4RUN0326 is offline
4RUN0326 is on a distinguished road
So does the andy mod 2.0 not work on 2000 4runner with elocker??
2000 4runner limited w/ e-locker and 4.30 gears 180k miles. OME 883/891, diff drop, 4innovations front steel bumper, cbi rear. Stock 265/70/16 cooper discovery h/t on 5 star limited wheels, new wheels and tires to come soon. Audio modifications: Sony HU, 10inch JL subwoofer w/ JL ported basswedge box and Rockford P300.1 amp.
4RUN0326 is offline   Reply With QuoteReply With Quote
Old 01-29-2013, 03:58 PM #10
mcaz5's Avatar
mcaz5 mcaz5 is offline
Real Name: Mikhail
mcaz5 is on a distinguished road
mcaz5's Avatar
Real Name: Mikhail
There is no reason for the Andy Mod on a 2000 4runner as it did not come with the VSC/TRAC
-2001 Sport Edition 4runner 4x4 2nd gen Supercharged-
-1985 Toyota Hilux (Pickup) DLX Turbo - 4x4 5speed w/2LT Turbodiesel
Build Thread
mcaz5 is offline   Reply With QuoteReply With Quote
Old 01-29-2013, 07:15 PM #11
TheeMikeB's Avatar
TheeMikeB TheeMikeB is offline
TheeMikeB is on a distinguished road
TheeMikeB's Avatar
You can also just remove the ABS fuse if you are not good at doing wiring. But then it's always off, I was having a problem with my VSC/Trac coming on randomly, I think I have a wheel sensor going out on one of the wheels.
Just remember that ABS fuse is bolted into the box and a bit trickey to remove. The dash lights are kind of annoying but I think i'm just going to pull the LEDs when i wire in my ARB compressor/locker.
ABS on these trucks is pitiful.
85 Xtracab, 3Link Front, Marlin Dual Ultimate, Double Locked on 37s
TheeMikeB is offline   Reply With QuoteReply With Quote
Old 08-17-2013, 08:46 AM #12
Danrob Danrob is offline
Danrob is on a distinguished road
Beeping truck..
So I'm new to the forum. I'm on my third t4r. A 1990 .. A '97 limited and now a 2002 badlands. The 02 seems to have more fancy computerized gadgetry than I used to...
I was out on some logging roads on the weekend (2002) and if I was a little too fast though washboard washouts the truck would beep at me.... Beepbeepbeep....annoying as ...... What system was doing this and how do I turn it off... Or should I leave the system on and disable the beep? The truck handled great.... Any ideas or comments from those of you that have been playing with this longer than I would be appreciated
Dan
ABS/VSC/TRAC Disable Master Thread-image-jpg
Danrob is offline   Reply With QuoteReply With Quote
Old 11-05-2013, 08:28 PM #13
TastyRunner's Avatar
TastyRunner TastyRunner is offline
Real Name: Sammy Swanstickler
TastyRunner is on a distinguished road
Unhappy
Do you have to put a switch in? i live in AZ where there is no snow, so I really don't need it on ever. I just want to cut the wire.
TastyRunner is offline   Reply With QuoteReply With Quote
Old 11-05-2013, 09:10 PM #14
EDIT: You just have to cut the wire.
Old 11-30-2013, 01:11 AM #15
I think you just have to ground the wire.
OK, that makes sense. Thanks!
Disable VSC, TRAC, and ABS without damaging factory wiring emelianenkov 4th Gen T4Rs 171 01-06-2022 02:04 PM
Master Video Thread. Lets see what your 4th gen has!!! TOYLUVA 4th Gen T4Rs 203 06-28-2016 02:43 PM
V8 VSC/TRAC Disable question Offroad Me 4th Gen T4Rs 9 10-16-2011 06:35 PM
Another ABS, VSC, TRAC, ABS lights + No Speedometer Thread moeronn Problems & Warranty Issues 5 08-09-2011 12:24 PM
New here and to 4runners 3rd gen VSC/TRAC Disable! jmoskow New Members 3 10-10-2010 07:47 PM
