Old 11-27-2011, 03:07 PM #1
ventureadict's Avatar
ventureadict ventureadict is offline
ventureadict is on a distinguished road
Advice Please: Poor braking performance with TBU 231mm
Finished my TBU with the 231s on my 2000 T4R, LTD. I did this upgrade because I haul a trailer from time to time, and I will be adding heavier components to prepare for overland expeditions this coming year. I wanted a better breaking system that would not get "wobbly" on long descents, and that would give me piece of mind while traveling fully loaded with my passengers.
Im at a loss here. I did my research and completed the project carefully and even had my brake-bleed job checked by a local brake shop, and it was done correctly with no bubbles and clear fluid.
Install went smoothly, no grinding needed on my 2000 rims. Cut the shield easily with a small cut-off wheel. I used all new parts purchased from AutoZone and flushed the old brake fluid completely.
After completing the install, I took my T4r for a spin to break in the pads using the 35mph-->5 X 4times, and then the 45mph-->5mph X 4times method. Brakes were smoking but I was told that was normal.
The braking that I get from my new Tundra 231s is not nearly as responsive as what I had on my T4Rs with worn out pads. When I slam on the brakes, the car rolls to a stop sluggishly. The pedal feels mushy. There is no quick "small child running out in front of me" braking performance what-so-ever.
So, I am at a loss. Here are the parts that I installed: Perhaps I got something wrong:
C9950 Duralast Disk Brake Caliper (13WL)
C9951 Duralast Disk Brake Caliper (13WL)
DGC976 Duralast Gold Cmax Brake Pads
31267 Duralast Brake rotors (2)
Prestone Dot3 synthetic brake fluid
As an added note, I also put new drums, shoes and springs in the rear using parts appropriate for my 2000 tr4. I had these checked and fine-tuned by a brake shop after complete installation. All was good.
Thank you for any help, advice or information.
2000 LTD, 4x4, TRD SC, e-locker, Toytec Ult, with OME 891 rear, diff drop, Yakima, custom shovel mount
Future...: ARB, Superwinch, CBI rear bumper w/ swing-out , Stubbs HD-SKO
2000 SR5, 200K+, 5-Speed. OME 2.5" Lift. ARB Front Bumper. Stubbs HD-SKO Sliders, LightForce. Custom shovel mount, custom GPS mount, Deckplate Mod, Nitto TerraGrappler 33s, Optima RedTop, Yakima Cage. (SOLD, and missed...)
ventureadict is offline   Reply With QuoteReply With Quote
Old 11-27-2011, 03:24 PM #2
Singtoe's Avatar
Singtoe Singtoe is offline
Singtoe will become famous soon enough
Singtoe's Avatar
Sounds like you got air in the ABS pump. Rebleed and try again
1999 Limited 4runner in Silver - 9th and 10th Injected TRD Supercharged 4.7 2UZ-FE swap - AISIN Manual hub lockers - Retrofitted E-locker - Downey Off road Coilovers & adjustable Pan Hard Bar - Whelen PA - 2" Personally made Body Lift - Eclipse Navigation Radio - Spider Trax - Custom Hidden Winch - Triple Electric Fans - Running boards off then back on again - Ghetto Cold Air Intake - Sequoia Brakes - V8 Badge (for extra horse power)
2002 SR5 Tacoma Extended Cab also in Silver On 37's and Guns for sale
Singtoe is offline   Reply With QuoteReply With Quote
Old 11-27-2011, 06:39 PM #3
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
Give it some more time. Mine were mushy for about a month and then began to firm up.
Are there any bubbles in the fluid when it is bled?
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 11-27-2011, 07:09 PM #4
IanB's Avatar
IanB IanB is offline
IanB has a spectacular aura about IanB has a spectacular aura about IanB has a spectacular aura about
IanB's Avatar
Take it on some gravel and see if you can get the ABS to cycle, this could force any air in the ABS pump out. You may need to rebleed regardless though.
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
IanB is offline   Reply With QuoteReply With Quote
Old 11-27-2011, 07:16 PM #5
No, no bubbles. How are your brakes compared to the old t4rs? Are you happy that you did the mod?
Old 11-27-2011, 07:32 PM #6
Absolutely. It helps with towing immensely. No more brake warping. Worth every penny.
Without bubbles, I am venturing out to say their isn't any air in the system. Did you replace the rear shoes with OEM pads? Members who have used other pads have reported problems with them. I'd check the rear brakes, to make sure they are close as possible to the drum.
But I still believe you need to give them about a month, then bleed them again.
Old 11-27-2011, 08:17 PM #7
Thanks, I will engage the ABS a few times and then re-bleed. hopefully that helps. Hopefully after a few weeks they will start working properly.
Is this poor mile performance? JuanSJO 3rd gen T4Rs 6 04-22-2008 12:59 PM
Poor de-mister performance on winshield magnumfan 4th Gen T4Rs 6 01-21-2008 11:14 PM
Poor Defroster Performance gapboi210 3rd gen T4Rs 6 01-20-2007 11:50 AM
Poor braking BLUEBUS 3rd gen T4Rs 8 08-25-2006 01:57 AM
How about poor braking . . . ? Sad4RunnerOwner Problems & Warranty Issues 15 12-06-2003 08:36 PM
