What maybe causing battery light flash on and off. When light flashes instrument head lights and heater dims til light goes away. I checked ground on battery and it looks clean. Any suggestions.
My first inclination would be the alternator. Might want to have it checked asap. The funny sounding thing to me was that the problem went away, possibly the alternator is about to die or something.
Should be able to test it free at Advance Auto or the like.
98' SR5 4x4
Yaesu FT-8900 with Larsen NMO 150 Antenna
K&N Cold air intake
Koyo Radiator with B&M 70264 for towing
Amsoil fluid everywhere, except Radiator
Its likely that your charging systems not working properly. If you can, I would start by checking the voltage on the battery while at idle to determine if its the alternator causing the light to come on
2000 4Runner \\ F Bumper \\ Winch \\ Big 3 \\ Rockford Fosgate 400W Amp \\ 285/75r16 ST Maxx \\ Viair 88p \\ F: 5100s w/ 600lb R: 890 60028
just a warning .... if your alternator is not performing and your vehicle is still running but with the battery light going on / off, then it is possible the operation of the vehicle is actually draining the battery as you drive it. If all that is happening then it will just die while you are driving it somewhere.
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
definitely have the alternator checked out had a similar problem with a honda battery light was on and then everything went nutz on the gauge cluster ... good luck
