Thread Tools Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
Old 04-02-2013, 04:36 PM #16
TRDteen's Avatar
TRDteen TRDteen is offline
Real Name: Matt
TRDteen is on a distinguished road
TRDteen's Avatar
Real Name: Matt
Great write up! Thank you for the very detailed pictures and specifications. You did a very good job!
Tread lightly and see you guys on the trail.
'99 Build Thread: http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'98 Build Thread: http://www.toyota-4runner.org/3rd-ge...ld-thread.html
TRDteen is offline   Reply With QuoteReply With Quote
Old 04-04-2013, 06:27 AM #17
spongerx's Avatar
spongerx spongerx is offline
Real Name: James
spongerx is on a distinguished road
spongerx's Avatar
Real Name: James
Originally Posted by Bryan1 View Post
Do these LBJ's come pre-greased?
Yes they do.
1997 SR5 5spd
SS 1.2 - Deckplate - MT Classic II's
ISR - True Flow - Magnaflow - 285/75 BFG AT
spongerx is offline   Reply With QuoteReply With Quote
Old 04-09-2013, 05:34 PM #18
Crashnrondo Crashnrondo is offline
Crashnrondo is on a distinguished road
Tag so I can find it later.
Thanks for the great write up!
Crashnrondo is offline   Reply With QuoteReply With Quote
Old 05-29-2013, 11:49 PM #19
Cjtapp's Avatar
Cjtapp Cjtapp is offline
Cjtapp is on a distinguished road
Cjtapp's Avatar
FYI for anyone doing LBJ's yourself..
I attempted doing my lower balljoints today. Had the drivers side lifted, tie rod removed, and LBJ castle nut removed and was on my third LBJ mount bolt. I was using a two foot breaker bar and snapped the head of the nut off with the first tug.
For the record I had not used any PB blaster because I have little to no rust under my vehicle and assumed I would not need it. All bolts came off easy, and the third one did too I guess...
Long story short
>Use PB Blaster and prep the bolts especially if the bolts are old.
>And be a little more graceful when breaking the nut lose because those 14mm bolts are not bulletproof by any means.
Very frustrating day because I had to take it to a shop to see if they can get the bolt out. The reverse drill bits I had at the house wernt cutting it..
1996 4Runner SR5~33x12s~Locked-Sold/Dead
2005 4Runner Limited V8~2/1 Lift~BFG 265/70r17~Helo Maxx 6 Wheels 17x9 -12 Offset~Volant CAI~Flowmaster 40
2006 Harley Davidson Streetbob FXDB
Cjtapp is offline   Reply With QuoteReply With Quote
Old 06-22-2013, 06:33 PM #20
hrt4me hrt4me is offline
hrt4me is on a distinguished road
Long story short
Very frustrating day because I had to take it to a shop to see if they can get the bolt out. The reverse drill bits I had at the house weren't cutting it..
what was your ultimate resolution for this issue?
hrt4me is offline   Reply With QuoteReply With Quote
Old 07-11-2013, 10:44 PM #21
Cjtapp's Avatar
Cjtapp's Avatar
The shop had some sharper reverse drill bits and were able to get it out. They finished the install for me. Prior to the install of my new lower balljoints I had a loud clunking sound coming from the front end. Turns out I only had 3 lower mounting bolts holding my driverside lower balljoint on (there is supposed to be 4).....
So im gonna take a wild guess in saying it had probably weakened the mounting bolts all together. Im lucky I didn't have any bigger problems than a head breaking off, when I could have very easily been in a ditch upside down.
Old 07-11-2013, 10:56 PM #22
The shop had some sharper reverse drill bits and were able to get it out. They finished the install for me. Prior to the install of my new lower ball joints I had a loud clunking sound coming from the front end. Turns out I only had 3 lower mounting bolts holding my driver side lower ball joint on (there is supposed to be 4).....
So I'm gonna take a wild guess in saying it had probably weakened the mounting bolts all together. Im lucky I didn't have any bigger problems than a head breaking off, when I could have very easily been in a ditch upside down.
yes, very fortunate indeed!
Old 08-10-2013, 02:23 PM #23
BOSSIND BOSSIND is offline
BOSSIND is on a distinguished road
That looks like the lift time warranty ball joint NAPA sells, I bought their 1 year warranty one and it only last 2 months and was worse than the one I replaced. I upgraded it to the lifetime one, hope it lasts longer and is built better... wonder sometimes if the only difference is the cost and how long they warranty them.
Anyone have any luck with other brands?
BOSSIND is offline   Reply With QuoteReply With Quote
Old 10-18-2013, 03:23 PM #24
Mel0's Avatar
Mel0 Mel0 is offline
Mel0 is on a distinguished road
Mel0's Avatar
Getting ready to switch out my LBJ's and I'm curious too about whether or not I should just spend the extra coin on some Original Toyota parts or go with aftermarket stuff. Also I would like to know what size tie rod end puller you need need to get the job done?
Mel0 is offline   Reply With QuoteReply With Quote
Old 10-18-2013, 03:44 PM #25
AZMIGHTYMULEYS AZMIGHTYMULEYS is offline
AZMIGHTYMULEYS is on a distinguished road
Moog's is a great OEM LBJ brand !! I also bought Moogs adjustable Stabalizer Bar end Links !!
AZMIGHTYMULEYS is offline   Reply With QuoteReply With Quote
Old 10-18-2013, 03:55 PM #26
I wouldn't waste my time on a puller for tie rods, little leverage and a shock to the dog ear with a hammer and it'll pop right out.
Old 10-18-2013, 04:41 PM #27
awthorn's Avatar
awthorn awthorn is offline
awthorn is on a distinguished road
awthorn's Avatar
One word of advice because i just did mine the other week and noticed a loud, harsh popping sound at full wheel lock. Grease the steering stops that are on the LBJs and it will help prevent that from happening or scaring the crap out of you and making you think you did something wrong .
BUILD THREAD | Flickr
97 2.7 4x4 5spd, OME 881 / 890, Cooper Discoverer A/T 3, blacked out 16" split 3s, Savage Sliders. LCE Street Headers, Marlin HD Clutch.
awthorn is offline   Reply With QuoteReply With Quote
Old 10-18-2013, 04:45 PM #28
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
My tie rod end puller is exactly the same size as a great big hammer. Unthread the castle nut, flip it over and thread it back on a couple turns, and smack the crap out of it. If you don't care about saving it as a trail spare, you don't have to bother with flipping the castle nut.
If it's stubborn, get the propane torch and heat it until it's smoking, then smack it again.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
KidVermicious is offline   Reply With QuoteReply With Quote
Old 12-06-2013, 07:13 PM #29
gmv4k gmv4k is offline
gmv4k is on a distinguished road
OK, I need a little help.
I can't seem to find an easy way to get the OTRE and the ball joint to separate. I've been using a NAPA rented puller and a 5 lb sledge hammer. I use the puller to add some force and then whack at it, I think this time it took 20 blows, it's frustrating. But does anybody have a link or a part number to a puller that will fit our trucks? I now have 2 different pullers but both won't fit and I'm sick of going to NAPA and renting one that doesn't really work.
I've had to take my lbj's apart twice now, since I snapped a head (1 of the 4) and can't get it out. I put everything back together because I ran out of time the last time. I did the same thing today, but I didn't finish because it got too cold. This time I got a map gas torch (ts8000 is pretty sick) but I was too scared to heat it up too much, stuff was starting to burn. I placed some roxul insulation, I had, behind it (but the torch got that stuff to melt). I tried to melt candle wax into it. I kroiled it for days/weeks. No luck. So I put everything back together. I think I'm either going to try to reverse drill it out or take it somewhere. I'm running out of time before it gets really cold.
So anybody know of a puller that'll work? I can tell you that this won't work
OEM 27022 Tie Rod/Pitman Arm Puller
OEM 27022 Tie Rod/Pitman Arm Puller - Amazon.com
The inner diameter isn't wide enough. I'd grind it out if I had a way to grind it out.
1998 4runner Ltd - 4x4 E-locker - TBU 199mm - B&M Tranny Cooler - Ultra-Guage - Rust Bucket
gmv4k is offline   Reply With QuoteReply With Quote
Old 12-06-2013, 07:41 PM #30
So Many Roads's Avatar
So Many Roads So Many Roads is offline
So Many Roads is on a distinguished road
I used the Napa tie rod puller to separate the OTRE from the ball joint without any issues, fit perfectly.
NAPA AUTO PARTS
The Napa Pitman arm puller worked great to separate the ball joint from the lower control arm. It is slightly wider than the tie rod puller.
NAPA AUTO PARTS
'99 SR5, 5 spd, Bilstein 4600, elocker mod, TBU
So Many Roads is offline   Reply With QuoteReply With Quote
replacing lower ball joint? Will_4R Engines / Suspension / Wheels / Tires / Audio / Accessories 14 03-25-2013 01:14 AM
lower ball joint question vthokie 3rd gen T4Rs 10 07-30-2011 03:18 AM
When to replace lower ball joint? Border411 Engines / Suspension / Wheels / Tires / Audio / Accessories 3 12-02-2010 08:03 AM
lower ball joint install beallen21 3rd gen T4Rs 2 01-29-2009 01:57 PM
