12-16-2011, 12:23 AM
Tacoma or Tundra 5100's?
Alignment shop said my shock bushings are too worn to be able to align it... so time for new shocks even though i wasn't planning on it for a few months.
I see guys don't like the tacoma ones because their too soft... and i've heard of people going with the tundra ones.
Which ones should i go with?
12-16-2011, 01:02 AM
Moderator
Real Name: Dylan
Moderator
Real Name: Dylan
Do you want a softer ride like factory or a firmer sportier ride?
The Rock Turtle Lifted, Locked, Boosted, Armored, TacoBoxed, and awaiting destruction.
12-16-2011, 01:35 AM
is there any difference in the shocks other than stiffness?
are the adjustments the same?
12-16-2011, 01:41 AM
Moderator
Real Name: Dylan
Moderator
Real Name: Dylan
The Tacoma ones have 3 where the Tundras have 4 settings. Are you going to be running your stock coils?
12-16-2011, 02:39 AM
i have tundra trd coils up front.
12-16-2011, 03:54 AM
Real Name: Zach
Real Name: Zach
Since you have tundra trd coils, I say go with the tundra 5100s for sure. That's what I have and it rides great on the 2nd setting.
My Build Thread
1999 Highlander Edition w/ Factory E-Locker: Alarm/remote start, FN 5 star wheels, 285/75/16 Duratracs, King 2.4 Ext Travel C/Os, LC shocks/8 wraps, 1" Diff drop, Airaid Intake, Dual B&M 70264's, Satoshi grille, 01 Tails, shackles, Rear diff breather extension, Blue wire mod,Taco whip antenna, Window tint, Bi-xenon Morimoto Mini Stage III projectors, 231mm Tundra Brake Upgrade, Interior LEDs.
12-16-2011, 04:16 AM
nice thanks for the input. i think i'll go with the tundra, but how stiff are they? do the ladies seem to mind with those?
1997 SR5, 217xxx, 5 Speed, 3" Eibach Springs w/ Tundra Bilstein 5100's, LC 8 Wraps, Bilstein 5125 in the rear, ISR, Elbow Removal mod, FJ Wheels, Tundra Brake Swap, 265/70R17 Goodyear Duratracs - SOLD
1999 SR5 220k, Automatic, e-Locker w/ blue wire mod, 3" Eibach Springs w/ Tundra Bilstein 5100's, LC 8 Wrap coils, Monroe Econo rear shox, 5th gen TRD Wheels, Tundra Brakes, Diff Breather, Satoshi Grill, Sport Hood
12-16-2011, 04:48 AM
Real Name: Zach
Real Name: Zach
I think Ive read online about people being unhappy with the tacoma 5100s being too soft and don't match well with the tundra coils. With the tundra 5100s its stiffer than stock, but my stock suspension felt like a boat. The 5100s feel nice and tight, but not hard or bumpy. and my gf has no complaints and I'm happy with em lol
My Build Thread
12-16-2011, 10:07 AM
I would get Tundra rears regardless, and with your TRD Tundra front coils I would get Tundra fronts as well.
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
12-16-2011, 12:08 PM
Moderator
Real Name: Dylan
Moderator
Real Name: Dylan
I agree with the above. But if you had stock coils, i would say go with the Taco 5100's.
12-16-2011, 12:37 PM
Tundra 5100's it is... do you guys think i can still use my top plates? i ran the toytec 3/4 spacer with ext studs. idk if i still have the original studs though. i'm ditching the top plate spacer obviously so i doubt i can use the extended studs with just 5100's and no spacer
12-16-2011, 06:45 PM
Real Name: Zach
Real Name: Zach
I'll buy top plate spacers when you get rid of em! I think you will be fine with the extended studs.
My Build Thread
12-16-2011, 10:12 PM
lol why would you want the spacers without the extended studs?
12-17-2011, 12:09 AM
I have Tundra 5100's with my TRD coils set on lowest perch setting and they're a perfect match for the progressive coils. It can't get any better than that as far as comfort and handling/balance goes. When I go off curbs and large dips, there is absolutely no bounce and makes it feel as of it never existed until the back end goes over it.
I'd say leave the 3/4" spacer in if you want to stay at that 1.2" additional lift height over the 2" TRD coils. I wouldn't recommend pre-loading the coil via the perch any more than a couple notches if you want to retain the ride comfort though.
'00 SR5 V6 4x4 - Tundra TRD/OME 890 Bilstein 5100; eimkeith PCK; B&M ATF Cooler; Addco Sway Bars; 231mm Brakes; 265/75R16; Bushwacker Flares; MD2S 3.0 Projectors - My other rides: '15 GX 460 & '13 LX 570
12-17-2011, 02:27 AM
Real Name: Zach
Real Name: Zach
I have extended studs that I bought a few months ago. I have so much damn rake and wanna level it out lol. I got 5.5" in the rear and like 2.25" up front. To get it near level I think I'll have to adjust the 5100s all the way on the highest setting and I don't think it'll ride as nice as it does now on the second setting, so I wanna throw in some top plate spacers. If you decide to sell, I'm your guy!
My Build Thread
