Tyler James Inc, ugamurph
Thread Tools Rating: Thread Rating: 211 votes, 2.70 average. Display Modes
Old 02-18-2020, 11:53 AM #30106
G_Raw G_Raw is offline
G_Raw is on a distinguished road
Homemade custom cell phone mount...no more bouncing out of the holder while offroad
P35 LED relay so no more hyperflash turn signals
G_Raw is offline   Reply With QuoteReply With Quote
Old 02-18-2020, 01:01 PM #30107
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is just really nice 4Runner4Leon is just really nice 4Runner4Leon is just really nice 4Runner4Leon is just really nice 4Runner4Leon is just really nice
Real Name: Leon
Any pics?
'97 4Runner Limited 4WD E-Locker ~195k
'99+ Headlights, Floor Console, Dash Bezel, Heated Side Mirrors, Storage Compartment | '01 Homelink Sun Visors, Taillights, Sport Hood | OEDRO LED Bulbs
265/75/16 Falken Wildpeak A/T3W | Pro Comp 69 16x8 | OME 2906 Springs | B&M 70264 Trans Cooler | GlowShift Trans Temp Gauge
SPIKER Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 02-18-2020, 01:19 PM #30108
Originally Posted by 4Runner4Leon View Post
Any pics?
Use a small piece of steel. Cut and angled to match contour of dash. Drilled a hole through it and modified a cell phone holder to run a flat screw through its back plate and secured with a nut on backside of the plate. I initially used Velcro to attach to dash but moderate offroading with weight of phone cause it to fall. So now I've removed Velcro and attached plat to dash with small screws.
What Did You Do To Your 3rd Gen Today?-15820458165941842817203-jpg  What Did You Do To Your 3rd Gen Today?-15820459621991856195459-jpg
Old 02-18-2020, 06:04 PM #30109
Real Name: Leon
Real Name: Leon
Very nice! I had the same design idea, but was trying to avoid drilling through the dash. Does it seem strong enough to support the phone with just screws in the dash (I assume the plastic part of it)? I was pondering using some type of inserts to make it a bit stronger.
Old 02-18-2020, 06:51 PM #30110
I should have taken photos and done a writeup...
The phone mount has a rubber washer between it and the plate. Flat lock washer between the screw and internal part of phone holder. Cap screw nut on back side. The rubber washer dampens vibration and any rattle noise. Haven't tested it off road but have driven like a maniac in my neighborhood (hitting pot holes, driving up onto curbs, etc) so far so good. I also put my phone in the holder before installing it and shook and threw it around and it held the phone the entire time. Won't be able to hit trails for a week to really test it ( maybe longer if my UCAs come in, I'd really like to get rid of tire rub).
This phone mount has a rubber back and feet that hold the phone. The side arms are pressure fit and have an angled hug like hand on each side. Small button on the backside spring releases the arms to remove phone.
Old 02-18-2020, 11:19 PM #30111
eddielasvegas eddielasvegas is offline
Real Name: Eddie
eddielasvegas will become famous soon enough eddielasvegas will become famous soon enough
Real Name: Eddie
Replaced my ancient spare tire with a purdy new Wildpeak A/T 3W.
I'd hate to be in the middle of the desert and have my spare fail due to age when the problem could be solved for cheap money.
Eddie
P.S. Decided to stick with the fugly steel rim as getting an alloy one was just too much hassle.
2001 T4R SR5 - 169k miles and counting.
eddielasvegas is offline   Reply With QuoteReply With Quote
Old 02-19-2020, 12:08 PM #30112
dcshipwreck dcshipwreck is offline
Real Name: Dan
dcshipwreck is on a distinguished road
Real Name: Dan
don't judge my dirty runner lol but i installed a 99+ center console and now have cup holders, yay
dcshipwreck is offline   Reply With QuoteReply With Quote
Old 02-19-2020, 03:28 PM #30113
cooker cooker is offline
cooker is on a distinguished road
I let my son drive it to work. BUT, I have an opportunity to buy a '96 Limited tomorrow! I'd love some advice and opinions.
158,000 miles, been garaged. not been registered since 2018 (husband died). used as a vehicle for vacation home. Looks like it has never been vacuumed. Front leather seats torn and hammered. Probably doesn't have service records. Few dings in bumpers but no body damage. Tires have a lot of tread but probably so old they need replacing. Tranny fluid looks good. Oil a bit dirty, airfilter mostly plugged. Very minor surface rust on frame/underbody.
Going to drive it tomorrow and probably make offer. Hopefully all the 4wd systems work including rear locker. taking a creeper to do a thorough inspection.
any suggestions are welcomed! Thanks
cooker is offline   Reply With QuoteReply With Quote
Old 02-19-2020, 03:32 PM #30114
good on ya. Easy to forget the spare condition. I've seen some that were petrified...
Old 02-20-2020, 03:57 PM #30115
Tyronmar Tyronmar is offline
Tyronmar is on a distinguished road
I mounted my 40" light bar. I'm very happy with it.
Tyronmar is offline   Reply With QuoteReply With Quote
Old 02-20-2020, 04:11 PM #30116
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe will become famous soon enough Kanoe will become famous soon enough
Kanoe's Avatar
You don't say where. Don't get caught by rust. Check out that frame. That'd be my #1 concern.
As others have said in the past, factor in a grand or two to get everything back up to tip top unless it is documented.
-1996 4Runner. 3RZ 5-Spd. 4x4 Base model. OME2906 rears with 2004 Tacoma Dual Rate Fronts on Bilstien 4600s.
-1993 Corolla Wagon 7AFE
Kanoe is offline   Reply With QuoteReply With Quote
Old 02-20-2020, 04:15 PM #30117
Kanoe's Avatar
Kanoe's Avatar
Stealth oil change...
Stealth oil change in a gravel pit. Hate that sh!t but what else to do on the road? I've got it down pretty fast and non-spill so I don't feel too bad about using the space for a while.
Walmart is kind enough to take used oil back so that's one thing taken care of. I wonder what they think of the Amsoil bottles? Hard to pretend I bought it there...
Old 02-20-2020, 05:02 PM #30118
nbach218 nbach218 is offline
nbach218 is on a distinguished road
Hey guys I did my own timing belt and all accessories to go with it today! It was original at 265k. Replaced crank shaft and cam shaft seals too.
It took me 2 partial days and could not have done it without the help of Timmy the toolman! I am a female who loves working on this truck! I also cleaned maf sensor and replaced radiator. Going for the 300k mark this year. 👍😎
nbach218 is offline   Reply With QuoteReply With Quote
Old 02-20-2020, 05:05 PM #30119
Sounds like with a little tlc, you have found a good rig! Frame is the bigges issue check the weld spot on the passenger side next to the muffler. Check and see when the timing belt was done and if it has not been done, figure that into your coat to purchase.
Old 02-20-2020, 08:17 PM #30120
The_official_seppi The_official_seppi is offline
The_official_seppi is on a distinguished road
Tint
The_official_seppi is offline   Reply With QuoteReply With Quote
Going to look at a 3rd Gen today Diverse4runner 3rd gen T4Rs 31 03-09-2020 08:38 AM
Saw this today... StreetCreeper 3rd gen T4Rs 47 06-25-2019 12:52 AM
Today 11/6 only!!! YotaDan Wheeler's Off-Road 0 11-06-2014 04:31 PM
Weird Problem today with my 4Runner today. myT4RisGREEN 3rd gen T4Rs 9 05-18-2013 10:07 PM
605/5 5th Gen today? expatoz So Cal 3 02-13-2013 10:38 PM
