06-03-2020, 10:34 AM
#30661
Originally Posted by austindenny
New hat and shoes went on last night. Did a janky chop job on the bumper this morning, which I'm going to replace soon anyhow. Sitting in the garage are some new SPC control arms to hopefully eliminate the pinch-weld rubbing.
- Rack from Sherpa Equipment Co
- SCS F5 16x8 -25mm/3.5BS
- Yokohama Geolander G003 M/T 285/75r16
Niceee. Saving up my chips for those SCS. Got any photos showing how far they stick out beyond the flares?
I stick out about 1.5 in and SPC helped a ton. Still rubs at full compression, so I ended up chopping the firewall. You should be fine if you grind the pinch weld down, heat the liner back a bit, and don't plan on doing any serious wheeling.
06-03-2020, 11:08 AM
#30662
Real Name: def not austindenny
Good to hear that SPC helped you out. Once I've got those on and the cams adjusted forward, I'm planning to get the final alignment. If after all that and the pinch-weld smashing it still rubs, I guess I'll begrudgingly tub the firewall. If I go that route, though, I may tub all the way to clear 35s so I never have to do it again. There's no accounting for tire decisions future me will make.
Here's a look at the current tire stance – in my opinion, it's just right. Really, it's just the angled face of the sidewall sticking out. Think most of the main tread is still under the fender. Without the flares, it would have been way too aggressive for my taste.
2000 4Runner 4x4 5-speed
instagram.com/austinoutside
06-03-2020, 09:09 PM
#30663
Airlocker popped the freeze plug on the cast hole of my third member. Globbed it up with fipg. Gunna hit the auto store this weekend for a better fit ( tighter fitting freeze plug). This current one went in easy...too easy I guess. Oh obviously refilled the diff.
99 Limited: 4wd conversion, OME 883/891, Built Right UCAs, Armored and winch up front, 285's with 4.88s and dual locked.
06-03-2020, 10:40 PM
#30664
Some love for the 99
Timing belt kit from AirCabinMan, new radiator hoses, coolant flush and tomorrow the trans gets a new filter and a flush
99 T4R SR5. OME 906s rear.Stock front springs with 1/4" spacers and Bilstein HDs all around. B&M trans cooler. Deck plate mod and rear diff breather mod. Blacked out bumpers and graphite wheels. Cobra CB in the ashtray. Tundra 199 brake upgrade. Pioneer MVH360BT head unit.
Necessity is the mother of invention.
Recent studies have shown that aggressive therapy combined with owning Toyotas, can be affective in breaking the cycle of Jeep addicition.
06-03-2020, 10:58 PM
#30665
Scored a factory aluminum rim and later years’ headlights from the salvage yard yesterday and installed them today. Just got back from the test drive, and much better visibility at night!
06-04-2020, 11:14 AM
#30666
What haven't I done.........
Got the unit in Denver and drove it home to Albuquerque. Been working on it since. Biggest accomplishments: Got the rear window dash switch to work (severed wire at taigate conduit), had the HVAC controller rebuilt, Rebuilt the temperature control servo (by myself at NO COST) installed a new head unit with backup camera, programmed remotes, installed hood support struts, new front tires to match the rears. On the list: replace lower ball joints, front brakes with rotors, get the CRUISE CONTROL WORKING! I ordered a module for the c/c but can't find the piece in the truck! Any help?
06-04-2020, 11:29 AM
#30667
I've been sitting on a load of new Whiteline bushings for the rear control arms for the last six months. After driving some trails in Sedona, some rear-end creaking on starts and stops emerged. Swapped all of the bushings last night but the noise is still there. Nonetheless, needed to be done – I suspect these were the original bushings. Next up, going to detach the lower shock mount to grease the bushing a little bit and power wash under the spring at the perch. We'll see.
06-04-2020, 12:12 PM
#30668
Finally finished my front bumper.
1st Runner Build Instagram @ prjt4rnr
06-04-2020, 04:58 PM
#30669
Real Name: Patrick
Real Name: Patrick
What year is your 4Runner? On my 2000 Limited its on the right fender between the airbox and ABS pump. Should have a cable going to the throttle body.
06-04-2020, 05:02 PM
#30670
Lookin good! Is this the Coastal Offroad bumper?
06-04-2020, 05:45 PM
#30671
Bolted up a set of Limited 5 Star wheels I picked up a couple days ago then gave it a quick detail and a coat of wax. The low-tread 285s look soooo much better than the almost bald and dry-rotted 265s.
06-04-2020, 06:31 PM
#30672
It's not there. 2000 is cable operated. 2002 and 2001 are drive by wire... no cable.
06-04-2020, 07:56 PM
#30673
Real Name: 3 Bears
Real Name: 3 Bears
looks good...what tire ?
06-04-2020, 08:56 PM
#30674
Real Name: David
Real Name: David
2000 2.7l t4r
Bought a 2000 2.7L T4R last Saturday. Been parked most of the week since original radiator need to be replaced and misfired on cyl 4.
Tomorrow installing new Radiator, Hoses, New Spark plugs and new ignition coils. Cant wait to get this on the road! I'll post a pic when after the R&R and clean it up.
Side note: is it worth lifting a 4cyl?
06-05-2020, 09:47 AM
#30675
Uh, yeah! Best engine in the 3rd gen platform!
