09-07-2020, 05:55 PM
#31156
Real Name: Joe
Real Name: Joe
Finally replaced the upper ball joints that I purchased from camelback 5 1/2 years ago! Now the ABS is kicking in at slow speeds when coming to a stop. I'm thinking it's the driver side speed sensor that was pretty much rusted to the hub and required lot of twisting and pulling to remove. Hopefully a better cleanup and better seating into the hub will fix it.
Also did driver side cv axle and front passenger side differential oil seal due to a previous cv axle change 4 years ago.
'99 T4R SR5 V6 4WD Imperial Jade Mica | 199mm TBU
09-07-2020, 06:45 PM
#31157
Real Name: Devan
Real Name: Devan
Originally Posted by midcoma
Not quite today, but recently.
F*ckin heavy duty!! Boulder ready if I've ever seen it.
Really like those A Arms. Been thinking about doing mine since the stock ones don't provide much droop it seems, but it's quite the pricetag
09-07-2020, 07:35 PM
#31158
I found this mess on Friday morning, the beginning of a long overdue 4 day weekend. I knew that I had a small hole in the back of the muffler just 2 months ago, I have no idea when it got this bad or when the tail pipe snapped off. I never heard a rattle, just a little more exhaust noise.
When I took off the remainder of the muffler, I found out how bad this has gotten over the past 4 months. Time to do something about it. I'll update my build thread w/ details.
'99 Limited, 225K miles, 3.4/automatic, multi-mode, e-locker, broken sunroof, no DRL's. 265-75-16 Hankook Dynapro ATM. New Moog rear springs, KYB Monomax F&R.
09-07-2020, 08:47 PM
#31159
Still chasing misfire on ctlinder 6. But also threw in some 5w30 for the truck...then threw a good russian imperial stout aptly named 5w30 into myself
99 Limited: 4wd conversion, OME 883/891, Built Right UCAs, Armored and winch up front, 285's with 4.88s and dual locked.
09-07-2020, 10:28 PM
#31160
That looks great! Can we get some details on the hardware under there? Curious what you used on the chassis as well.
1998 SR5
09-08-2020, 01:22 PM
#31161
Real Name: Eric
Real Name: Eric
1984 SR5, 1989 DLX, 2011 SR5 4wd
09-08-2020, 01:44 PM
#31162
Replaced the driver rear bumper extension that came with the car. Just bought it on Saturday so first official wrench on the truck...first of many to come I'm sure.
1997 SR5, 3.4L, Manual
09-08-2020, 07:00 PM
#31163
Tried to figure out why the wiring harness is burnt. Under the dash
09-08-2020, 08:31 PM
#31164
Can you give any more details? Specifics about your 4runner, whether this is a new development and if there were any symptoms evident before you noticed that things were burnt, a more clear description of what is burnt, maybe some pictures?
09-08-2020, 11:33 PM
#31165
Installed eimkeith's PCK. Pretty amazed at how much of an improvement it is
Sent from my SM-G975U using Tapatalk
09-09-2020, 12:03 AM
#31166
Real Name: Devan
Real Name: Devan
Do modern cars use fusible links? That's where I would start looking if so, their whole purpose is to burn out from a short or what-have-you so your main harness/car doesn't catch fire
09-09-2020, 01:02 AM
#31167
It's a full SoloMotorsports front end. LT kit, fabricated spindles, heim steering. It's their newer version that uses Dana 44 hubs. Then 2.5" King coilovers and 3 tube bypass shocks with 2" bumps.
I had to tub a little bit of the cab to fit 35s, so the plastic inner fender won't fit any more. I had to paint from where I did the cutting and welding anyway so I decided to spray the entire inner fender with Raptor Liner. Matches what I already have on the lower half of the body and around the wheel wells.
09-09-2020, 01:43 PM
#31168
Well no wonder I didn't recognize it! I hadn't even heard of that kit before. Looks absolutely bulletproof!
Oh, so that is Raptor liner. I've been deciding what to do with inner fender when I rebuild my suspension. Looks good!
1998 SR5
09-09-2020, 06:00 PM
#31169
Im having a hard time uploading photos maybe need to use a computer. I recently bought the 4 runner 3 windows didnt work. I figured it was regulators or window switches that was not the case everything tested out to be fine. After hours and hours of troubleshooting I realized the drivers door was not grounded. Traced the white wire with black stripe from the master switch in drivers door. The white and black wire was broken in the door hinge. I replaced the wire everything started working great. I figured problem solved put everything back together. Few hours later the master switch started blowing smoke. The wire i replaced that was broken (wht/blk) was scorched insulation burnt off. Master switch melted and the connector under dash melted. When investigating that i notice the connector which sends wiring to the rear of the vehicle was also burnt. I think its the primarily for the window in the back hatch. Not sure if that connector was burnt prior to the window switch issue or not.
09-09-2020, 06:41 PM
#31170
Here's some photos still trying to figure out the forum. Not sure if this is the right place or way to post
