Originally Posted by ABlockOfCheese
I'm considering what to do about the god awful paint. Lots of dead clearcoat all over the roof, and the hood is a lost cause. I might just repaint if its not crazy expensive, even threw around the idea of wrapping it.
Find a painter (or several, an independent will probably be best) and ask them for options. Typically, the majority of the cost is in the prep work, so if you're willing to remove trim, help sand and just generally take on the piddly labor chores yourself, you might find a big discount. Obviously, if you want to do a color change it'll be a whole lot more expensive.
The other option is if it's just clear failure, is to wet sand it back to paint and re-clear only. This is a fairly easy DIY project and you could do it panel by panel if you wanted. Just spend the money on better clear (2-part, commonly called 2k). Again, the quality out is determined by the time spent in prep.
'99 Limited 4x4, Millenium Silver ~
Maintenance Thread
