-01 Sienna steering wheel with swc and cruise control
-01 Sienna clock spring
-01 Sienna remote harness(behind the oem radio and 100% not necessary as you can splice the wires)
-3 additional Toyota wire terminals(i sourced these from the same Sienna)
-ASWC-TOY-LEX swc module
Direct bolt on and the airbag connectors are the same. 3 wires will be added to the 6 pin connector on the vehicle side to that clips into the clock spring.
I swapped the rear bezel and airbag brackets over to retain my black wheel. I painted the rear wheel bezel Kyrlon vinyl black(perfect match i might add)
Grey for 12v switch, green and black signal wires to Axxess module. Follow instructions per Axxess manual for auto program and connection. (two 12v switch and ground) The Sienna remote harness plugs into the Axxess connector directly or you can slice the wires together if you didn't find one.
If anyone needs further help with this, pm me. I should of taken pictures along the way. It's a super easy install. Its connected to an Apline ILX 650 and works perfectly.
I was able to obtain all parts from pick and pull. The Axxess AWC-Toy-Lec is from Amazon.
I have an extra 1stgen Sienna blue steering wheel with controls and cruise control for sale if anyone is interested. No clock spring.
Originally Posted by JZiggy
Very cool! Tell us more!
