06-15-2021, 09:41 PM
#32506
Real Name: Devan
Real Name: Devan
Originally Posted by Endlessblockades
Huh. I'm running the engine and tranny set. Probably 80+ lbs but it doesn't bother me - I know I am well protected down there.
Welp, the problem could be that I'm just realizing the other skids were 3/16, not 3/8... they probably weigh nearly twice as much as 1/8 skids because they're twice as thick
pic related!
06-16-2021, 09:14 PM
#32507
Changed the rear upper and lower control arm bushings, and panhard bar bushings with Whiteline poly bushings on my non-lifted ‘02 today.
I’ve been trying to narrow down the wiggly feel I get when driving on grooved concrete sections of the freeway. Also felt like I had bump steer when braking on bumpy surfaces. It just always seemed like a front end issue. Tried about everything I could think of since purchasing the vehicle two years ago. New front and rear brakes (maybe sticking caliper?), poly rack bushings, adjusted rack guide screw, poly front and rear sway bar bushings, new shocks all around, new rear springs, new Cooper AT3 4S tires, new OEM lower ball joints, and finally an alignment! Everything was an improvement, but nothing corrected the real problem. Well, finally found the culprit today! The rear control arm and track bar bushings! They looked fine during visual (on car) inspection, but not so good when off. It’s an amazing improvement. Like driving a brand new car now, and the poly bushings don’t seem any more harsh riding than before. Smooth, yet firm!
2002 4Runner SR5 4WD 3.4L Thundercloud
2001 Tacoma Xtracab TRD 4WD 3.4L Black Sand Pearl (original owner)
1971 El Camino (second owner, purchased in ‘81)
2010 Cadillac DTS
Too many cars, but love them all!
06-16-2021, 11:13 PM
#32508
Real Name: 3 Bears
Real Name: 3 Bears
brought home a new to me 2000
06-17-2021, 09:09 PM
#32509
How difficult was the replacement?
2001 SR5 4WD
06-17-2021, 09:20 PM
#32510
Real Name: John
Real Name: John
Originally Posted by cl4Rk
Awesome man! Thanks
John
2002 TCM Grey Sport Edition
06-17-2021, 10:28 PM
#32511
Wasn’t bad at all taking the arms off and re-installing. I don’t have a press, so getting the old bushings out of the lower arms took removing the rubber by heating the outer part of the arm with a propane torch, then used a two jaw puller to push out the rubber. Then sliced the remaining metal sleeve with a hack saw to make a relief and then knocked it out with a chisel. Was careful not to score the inside of the arm, though I don’t know if it would matter much if I had, since the outer portion of the bushing doesn’t move during operation. The first one took the longest. After that the rest went quick. The upper arm bushings and panhard bushings don’t have the metal sleeve. They just pushed out using the puller. Very easy for all of those. With my son’s help, the whole job took maybe 2-3 hours.
2010 Cadillac DTS
06-17-2021, 10:48 PM
#32512
Installed the front sway bar bushings... What a f****** mess to install as every single bolt is rusty and both bolts on the passenger side holding in the bracket sheared off. I'm glad I ordered new hardware for the brackets.
Driving it with the new bushings, I could immediately tell the difference. I can corner with confidence now and it's a much stable ride. These are Energy Suspension Bushings and they are great! I didn't have time for the end link bushings so thats another day
2000 4Runner Limited 4x4 V6
06-19-2021, 11:37 PM
#32513
Real Name: 3 Bears
Real Name: 3 Bears
on my new to me 2000, new airbox ( used) and air filter, original was cracked, cleaned maf, replaced PCV and grommet new front sway inks, one was broken, replaced one side light and put in LED's on both. DRL delete. From my 2001 I swaped my 6 month old battery and swaped the tail lights and put in LED brake and back up bulbs ( put the 2001 tail lights on the 2000, and 2000 on 2001,2001 ones look better)
few days ago order a Denso radiator, toyota thermostat, toyota LBJ's., magnafine trans filter. But might be a few weeks b4 I can get to install all that. Gonna do a tranny flush at the time. ( timmy style)
With wheels off today I noticed so I ordered OTRE's also orderd NGK wire set, new plugs., fuel filter and all 3 drive belts and new fog light bulbs, one was burned out.
Tomorrow gonna inspect rear brakes and then adjust flush and bleed brakes, ( hope this cures my spongy pedal) swap my semi new KO2's from the 2001 and these older geolanders to the 2001
tuesday or wednesday plan to put the 2001 up for sale.
06-20-2021, 11:57 AM
#32514
Originally Posted by rkntoy
May just leave it with the industrial look
Think i saw something like that on Criminal minds...Might be good for hanging your Fishing lures from so you dont sit on em
Magnaflow, Rigid D Series 4" 50231/Rigid E Series 20" 12231 LED Bar ,K&N FIPK,3"Toytec ultimate, OEM 231MM brake upgrade, LED Interior upgrade,Bushwackers,Savage Rock Rails,Shock works front bumper,PERKINS NON PERFORMANCE REAR BUMPER 33'Duratracs,Kenwood DNX891HD JL Audio C5's
Currently 194K
Cheers
06-20-2021, 06:10 PM
#32515
Swapped driver and passenger seat cushions. What a difference. Now I’ll look for a junkyard passenger cushion.
‘98 T100 SR5 4X4 5spd (sold)
‘99 4Runner SR5 4x4 5spd E-Locker Unicorn
06-21-2021, 09:37 AM
#32516
Nice to have room for a thermos.
06-21-2021, 09:56 AM
#32517
official vendor
official vendor
Someone needs bigger tires .
06-21-2021, 12:22 PM
#32518
My 3RZ disagrees, and informs me that I can forget ever getting 20mpg again if I do that
06-21-2021, 07:53 PM
#32519
What do you guys pay for a gallon down there?
Currently 194K
Cheers
06-21-2021, 10:09 PM
#32520
Sicmods and stuff
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
