10-22-2021, 05:58 PM
#32956
Real Name: Alex
Real Name: Alex
Lil' Skip's!
2000 SR5 3.4, Manual, 4x4
Icon 2.5 extended coilovers & 2.0 rear, JBA UCAs
265/75R16 General Grabber X3 on LC80s
Full Skid Plates
10-22-2021, 06:19 PM
#32957
Replaced washer Jets
Replaced my Anemic washer fluid jets(windshield) with a Honda PN#76810-TK8-A01
After a little Aiming they shoots like a charm.
Magnaflow, Rigid D Series 4" 50231/Rigid E Series 20" 12231 LED Bar ,K&N FIPK,3"Toytec ultimate, OEM 231MM brake upgrade, LED Interior upgrade,Bushwackers,Savage Rock Rails,Shock works front bumper,PERKINS NON PERFORMANCE REAR BUMPER 33'Duratracs,Kenwood DNX891HD JL Audio C5's
Currently 194K
Cheers
10-23-2021, 07:06 PM
#32958
New lower ball joints. The old ones have about 70 - 80K on them? Just preventative maintenance.
The old ones probably had some more life in them, but better safe than sorry.
10-23-2021, 10:35 PM
#32959
On a newly acquired '01 SR5 with 144K miles, we paired two new key fobs, replaced the driver's door lock actuator, soldered three broken conductors located at the rear tailgate hinge and which were preventing the rear window from rolling down and the rear door lock from locking, inspected and (hopefully) resealed the charcoal cannister (due to P0440 and P0446 codes), sanded and painted some rust spots on the hood, drained and refilled the rear diff fluid, and changed the oil.
10-24-2021, 07:35 AM
#32960
Sounds like a good start, but why no the front diff, transmission, coolant, brake and power steering fluids too? They are all consumables too...
Might want to give some Serious thought to replacing the lower ball joints (LBJ) as they are a failure-prone design and when they fail, the front wheel falls off. And then the radiator, which doesn't fail as often but when it does, it takes out the transmission (trans cooler is integrated, failure mixes coolants with ATF). About $350 in parts (you need new bolts for the LBJ) and a couple hours time.
10-24-2021, 08:35 AM
#32961
Thanks Brian.
Unfortunately its a 2wd 4runner. Coolant has been replaced by PO (new radiator) and I forgot to add that I also flushed the brake fluid when I put on new rotors and pads. I'm going to take it in to the dealer for them to flush the trans - after reading some threads about the process I'll save that job for them. I'll do the power steering fluid too at some point.
Thanks for the tip about the lower ball joints too!
'01 4Runner, '01 Tacoma, '12 Sequoia
10-25-2021, 12:27 AM
#32962
Real Name: Riley
Real Name: Riley
Started building a storage/sleeping platform
10-25-2021, 01:58 PM
#32963
Replaced leaky power steering pump and put some undercoating on the frame.
10-25-2021, 06:19 PM
#32964
Real Name: Riley
Real Name: Riley
Finalized (maybe?) the aiming and wiring for my headlight retrofits utilizing OEM E46 Xenon projectors
10-26-2021, 06:43 PM
#32965
Originally Posted by 99 W/ Kids
Purchased a new front bumper, ARB 3423040, from Bumper Superstore. In stock, will be here next week confirmed.
Purchased all new control arms, ball joints and tie rod ends. Just went out and sprayed everything w/ PB blaster in anticipation of the work.
If anyone has any builds for those two projects that would be cool to see some links. But I’m sure I’ll be ok.
I'm in the market for my 2001 3rd Gen Runner and noticed your ARB number is for a Tacoma. Will that fit ? Does it require some major mods if it does?
I've been searching all over for options.
thnx
10-27-2021, 10:15 AM
#32966
thnx
Some cutting and grinding and ideally some welding and painting.
The part number in the video is different, but the modifications needed should be basically the same:
ARB Bull Bar Bumper Install on a Toyota 4Runner (ARB PN: 3423020) - YouTube
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
10-27-2021, 05:52 PM
#32967
My 96 limited 4x4 got the AT/P light only when I put it in park. Google showed that light comes on when transfer case is in neutral and transmission is in park. But the transfer case is in HI and light only comes on in park. No other issues would anyone have any advice to offer?
10-30-2021, 01:21 PM
#32968
Today's journey of 4runner problems was the lovely 4LO system. It decided to stick in low and not come out until taking out fuse and switching back while it was out then putting it back in
10-30-2021, 10:21 PM
#32969
Pressure washed the shit out of it after running trails this week post storm. Relubed all heim joints and uniballs. Regreased all zerks...driveline and control arms. Pressure washed all the clay/mud to the grass...hate myself for doing it haha. Guess I'm reseeding the lawn in spring.
99 Limited: 4wd conversion, OME 883/891, Built Right UCAs, Armored and winch up front, 285's with 4.88s and dual locked.
10-31-2021, 12:33 AM
#32970
Fall cleaning. Removed the throttle body. Cleaned it and the idle air control valve. Replaced a faulty throttle position sensor.
This was my first Saturday off in months and, even though I didn't solve my problem, it was a great way to spend the afternoon.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
