04-19-2024, 01:14 AM
#35521
Pulled out the cs144 alternator to replace the voltage regulator with a set point of 14.8v for my agm battery and to swap to a 1.9 inch pulley as it wouldn't charge with the stock pulley (rotor speed was to low) at engine idle. So with a crank pulley diameter of 6.247 inches and a 1.9 inch pulley it spins at 2460 rpm at idle and 18040 rpm at red line. Perfect! Tossed it back into the car and checked the work. Fantastic! Cold charging is 14.8v and hot charging is 14.6v, bingo!
Next moved onto the wench (winch). Got all the wires I made last week installed and tightened down. Sweet. I ended up taking the apex 12k control box apart and took the solenoid and installed it in the passenger wing of the coastal off road bumper. It's tight, but fits and works perfectly. Wired up the cable and wireless control stuff. Accidentally switched the wires so when you hit out it pulled in lol. Quick fix and it works fantastically. With that, all my electrical for now are complete! For now lol. Got to re thread the wench line as I ditched all metal on the line.
Next up is redoing the rear disc conversion. Ditching the Ford calipers for some lc80 rear calipers and wilwood mc4's for the parking brake, seriously need a good parking brake. And at the same time tossing in a lc80 master and booster too.
Then the rear swing out, hope to get these done in the next few months as I want to take a nice 3-5 week vacation offroad trip across country.
To busy working to get pics, sorry.
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
04-21-2024, 12:30 AM
#35522
Real Name: Mark KN6TZI
Body Mount Bushings
Bought Toyota bushings from Amayama last January. Cost was about $300. Finally made the time to swap them.
No body lift, just bushings so I didn't have to worry about the bumper or rag joint. And my '96 doesn't have the center mount by the b-pillar. 14 bushings total. The old ones didn't look too terrible but they were sure hard.
I could feel the difference as I left the driveway. Shitty roads and manhole covers feel noticeably softer. Feeling only whelmed after all of my suspension work, this might be the missing piece!
'96 T4R SR5 | 4WD | Auto | 199 TBU | 268k+
Reason: Remove unrelated info.
04-21-2024, 01:35 PM
#35523
was thinking of replacing those during my '99 resto. Decided to forgo that as they looked ok, but now i may...is Amiyama the place to go? Anyway, have to open another phase of this resto up.....found this during needle scaling of the rear frame. I knew there was some "chooch" lurking behind that tank. My handy dandy POR15 rust sealant wont fix that!
I DID NOT expect this. Now instead of finishing frame prep for powertrain reinstall, i have to pull this baby back out to the shop where the 220v TIG machine lives. Son is a excellent welder fabricator thankfully. We will get it right. It will be a YEAR since i picked up the reman 5VZ until it fires up! DANG IT!
04-21-2024, 04:07 PM
#35524
Originally Posted by fatherohenry
Body Mount Bushings
I'm tempted to replace mine now. Anything to improve the ride quality is a plus.
1999 Limited with rear locker.
Sherpa Matterhorn | Sonoran Steel Diff Drop | SPC UCAs | DuroBumps Front and Rear | OME 890 Springs and Black Tokico Shocks | Eimkeith Reinforcements and PCK | King Coilovers | OCD Sway Bar Links | Opt Offroad Rear Arms | Lil Skips Gas Tank Skid Plate | FGP Rock Sliders | 4x Innovations Rear Plate Bumper with tire carrier
04-22-2024, 03:58 PM
#35525
Installed some Bilstein 4600’s with moogs on the front and also new inner and outer tie rods saturday.
The front is definitely higher than the rear now even with the new shocks in the back so I have some 906’s on the way to even it out. Looking forward to finishing up this suspension work.
04-23-2024, 11:49 AM
#35526
Not to be pedantic, but shocks (not a coilover like the front) have nothing to do with ride height. Springs hold the vehicle up, shocks control the mothion of the springs. Bushings also play a role in control, especially in the rear, but those are the basics. 906's should lift up the rear to a good height and deal with a load far better than the stock springs ever did.
2000 4Runner SR5 Manual Trans Federal Emissions - Eibach Pro-Truck coilovers, LC 7.5/Tokico Black, JBA UCA, SPC 25945 RLLs, Mevotech Supreme RULs, TrakMotive Xtended Travel CV Axles TO-8043ET, South Bend Rally Clutch, ES & Whiteline Bushings, MagnaFlow Cat-Back, Deck-Plate Mod, 4.56 Yukon Gears, Yukon Grizzly Rear Locker, Bushwacker Flares, 16x8 Wheels w/ 285/75 General Grabber AT2, 229K+ Miles
04-23-2024, 02:10 PM
#35527
The Moog front springs are taller than the OEM '99 talls - what he is experiencing is normal... especially if the rear springs are still stock.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
04-23-2024, 08:14 PM
#35528
Upgraded my bumps to some sick Perry Parts 3D printed ones!
Writeup
04-24-2024, 11:38 AM
#35529
Real Name: 3 Bears
Real Name: 3 Bears
so factory talls ( highlander) sit 1 inch higher than the non talls ( non highlander)
moog sells the stock height and also the talls
so are the stock moog taller than OEM talls, or the moog talls higher than oem talls
04-25-2024, 02:35 PM
#35530
I don't know the specifics, but the post referenced has no model years, and other years are lower from the factory than '99, even the 'not-tall' '99's. (my '99 2WD was over 20" hub to fender lip with the factory suspension/weight, even after 15+ years)
The Moog PNs that float around here are generally for the "99 Tall" version, so that's my assumption as to what was purchased.
04-26-2024, 09:19 AM
#35531
I just went through the same thing and had the same exact spot rust on mine as well. Can't see it because the gas tank covers up most of that side.
Make sure you blow out as much rust and debris in the frame as you can before repairing that area. Then when all is said and done, spray a lanolin coating on the frame like Fluid Film or Woolwax to prevent rust.
You can see it in this thread I posted: Gas Tank Replacement Journey
2001 4Runner SR5 4x4
2019 4Runner TRD Offroad 4x4
04-26-2024, 10:31 AM
#35532
Real Name: Mark
Real Name: Mark
DANG IT!
Know your pain. You'd have to repair the rust you have doesn't hurt to add some extra beef. Lower Link Mount Skids/Reinforcement – eimkeith.com
96RedRunner limited 4x4 5VZ auto not stock 374k miles totaled 2018.
2001 limited 4x4 5VZ auto work in progress.
2011 Audi S5 Prestige 4.2 V8 6 spd MT.
04-28-2024, 06:38 PM
#35533
Real Name: 3 Bears
Real Name: 3 Bears
Installed the suzuki 105 amp alternator today.
Wasnt planning to do it today....but my alternator crapped out last night. Only had time to do the alternator, have all the parts to do the big 3, but no time.
under full load, everything on , at idle my volts stayed right up there and never dropped below 13.4 according to my torque pro app
im pretty sure phattyduck turned me on to this mod
1st gen 105 amp bolt in alternator. | Tacoma World
04-28-2024, 09:09 PM
#35534
Found some junk parts
04-28-2024, 09:21 PM
#35535
Donor '99 Taco
