Tyler James Inc, ugamurph
Thread Tools Rating: Thread Rating: 217 votes, 2.72 average. Display Modes
Old 01-11-2025, 06:28 PM #35881
Jdoglee8 Jdoglee8 is offline
Jdoglee8 is on a distinguished road
Originally Posted by AuSeeker View Post
If you have a bad knock sensor you need to replace it, if you have bad wiring, such as wires chewed by rodents going to the knock sensor you need to repair them!!
I have checked the wiring and it seems to be good, it has no symptoms of a bad knock sensor. I just don’t have the time or money to do a job like that.
Jdoglee8 is offline   Reply With QuoteReply With Quote
Old 01-11-2025, 06:52 PM #35882
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Uhhhh, the first symptom of a bad knock sensor is throwing the p0325 code, other symptoms aren't always present for a bad knock sensor or can come about later.
You can replace it or not that's up to you, it can however possibly do some serious damage to the engine or it could be fine, really not worth the risk IMHO!
I doubt the issue/code is going to go away unless you address the cause.
2004 Limited V8
Old 01-11-2025, 10:52 PM #35883
GhostRing's Avatar
GhostRing GhostRing is offline
GhostRing is a jewel in the rough GhostRing is a jewel in the rough GhostRing is a jewel in the rough
GhostRing's Avatar
Trying to get a properly functioning brake system going,
so installed the ol' "Scamazon special" brake booster.
So far, I'm....not really sure if it's worth it?
The install went rather smoothly, but the check valves
are different size (OEM is larger dia.) so I couldn't re-use
my newish Toyota one. The rubber grommet is also
way cheaper feeling. I even had to trim the vacuum hose to fit it.
(Gotta save that $500 markup somehow..!)
The biggest issue is the brakes feel even harder now.
Now, this could be my imagination, but with my TBU I would assume
the throw would be longer and a little more..progressive?
The pedal comes on really early and doesn't have the modulation
I was kind of expecting given the condition of the original booster.
This might get returned unless there is something else I am missing?
Also pictured are my new favorit-est Igarashi IPS Hyper Long Pliers.
Super nice for hose clamps and other hard to get connections.
Highly recommended!
What Did You Do To Your 3rd Gen Today?-img_4314-jpg
Build Etc...
If it ain't broke, fix it 'til it is.
GhostRing is offline   Reply With QuoteReply With Quote
Old 01-11-2025, 11:17 PM #35884
2TH4IST's Avatar
2TH4IST 2TH4IST is offline
2TH4IST is a glorious beacon of light 2TH4IST is a glorious beacon of light 2TH4IST is a glorious beacon of light 2TH4IST is a glorious beacon of light 2TH4IST is a glorious beacon of light
2TH4IST's Avatar
When I did just the tbu and still had rear drums, the pedal was a bit mushy, or progressive as it's called.
Maybe your old booster was bad, and you just got used to it. And now the new one is functioning normally and feels firmer. Does it feel like it's assisting or does it feel like there is no vacuum assist? Does the booster loose its vacuum with engine off and a few pumps of the pedal.
Did you need to adjust the boosters plunger (one that goes into the master)? It could be pushing the master in a bit thus a more firm pedal?
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
2TH4IST is offline   Reply With QuoteReply With Quote
Old 01-11-2025, 11:29 PM #35885
GhostRing's Avatar
GhostRing's Avatar
The pedal does firm up properly with the engine off and drops upon start.
When driving, I would perhaps initially describe it as lack of vacuum,
but not close to the panicky wtf-is-up-with-my-brakes sensation.
I spent a fair amount of time making sure the plunger and pedal bracket
matched the old booster - which as far as I can tell is original, so I
hope I did a good job, but don't forget my sigline...
It may just be the "new sneaker effect" where I was so used to
old ones, I forgot what a fresh pair feels like!
I really just did the install and drove a few miles home, so I will give it
the rest of the weekend to see what's what.
Build Etc...
Old 01-12-2025, 12:50 AM #35886
pa_robert pa_robert is offline
pa_robert is on a distinguished road
New Years Eve (and then Day) I got two wheels painted. Last Sat night/Sunday I got the other two done.
Tonight I removed the old rusty rear bumper and sides. Heat was extremely helpful, as well as PB blaster. Only broke three of the rear mudflap bolts and only one of the bumper "y" support bolts needed the small angle grinder to set it free.
Tomorrow she's getting a new rear bumper.
2000 SR5, 4x4, 3.4L, SafTCap poster child. Looks great on top. Underneath is freaking horrible.
pa_robert is offline   Reply With QuoteReply With Quote
Old 01-12-2025, 02:11 PM #35887
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
agree give it a few days
2002 tundra ac v8 4wd
1969 kharmann ghia
Old 01-12-2025, 02:55 PM #35888
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
Koyorad and Iconic Fab trans cooler bracket installed
If my company knew what I get up to in the parking lot on the weekends, I'm not sure if they'd approve! I probably shouldn't be allowed to work on vehicles at all it always turns into a yard sale. Since I had my previous trans cooler running in series, I didn't have to pull the 25 year old factory trans lines off the metal lines until now. Holy hell that was an adventure - plus it was dark by then, as I left that plumbing until the end. The funny thing I wanted to mention was that a co-worker did drive by and and asked "Do you need a jumpstart?" I wanted to say 'I need a lot more than that that, lady....' but politely declined.
Picture upload is failing....will try another way.
What Did You Do To Your 3rd Gen Today?-koyorad2crap-jpg
Y2K LTD/E 262K
Old 01-13-2025, 10:19 AM #35889
rglsr rglsr is offline
rglsr will become famous soon enough
Complete front/rear brake job with OEM Toyota parts, plus fluid flush.
Parts stash in the garage is nearly gone!
rglsr is offline   Reply With QuoteReply With Quote
Old 01-13-2025, 07:19 PM #35890
GhostRing's Avatar
GhostRing's Avatar
Decided the click/clack of the Johnny Joints needed to be addressed.
Lil' diy with a big ol' mudflap yielded a few washers that hopefully last.
I'm only doing the upper/frame joints as they have the least clearance
and I assume they are the ones making the noise. If not, I'll just pop
'em out again and make some more for the lowers.
I don't think it will pressure the joint to the point the jam nut is getting
affected, but I'll keep an eye on it. I also tightened down the zerk more.
What Did You Do To Your 3rd Gen Today?-img_4320-jpg
Build Etc...
Old 01-14-2025, 10:20 AM #35891
NenIviri's Avatar
NenIviri NenIviri is offline
NenIviri is on a distinguished road
NenIviri's Avatar
Not today but fairly recently
First time 3rd gen owner, got to work on the spark plugs and found that they weren't properly torqued to spec and were also autolite. No wonder I had a misfire, went and replaced them with Denso Iridium TT's and now the thing moves much nicer!
NenIviri is offline   Reply With QuoteReply With Quote
Old 01-15-2025, 03:28 PM #35892
OpenYota's Avatar
OpenYota OpenYota is offline
Real Name: Chris
OpenYota is on a distinguished road
OpenYota's Avatar
Real Name: Chris
Installed a 1/4" spacer on the drivers side front strut due to lean; it definitely helped a little bit but still have some small lean angle.
Did not take measurements but all is good for now until I get a better front suspension setup.
One thing I am a little peeved about though is that the spacer was $8 from wheelers but the shipping for that little thing was $25! Crazy.
Also bought a drivers side CV axle from NAPA and will install when the weather warms up a little bit, the inner boot on the axle currently installed has been ripped for about a year
2001 SR5 4WD
OpenYota is offline   Reply With QuoteReply With Quote
Old Today, 12:01 AM #35893
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
Nothing really, just cleaned up the corrosion on the terminals using a wire wheel/drill and sprayed the undercarriage and body. 250k and very stout, rarely have to look over the 4Runner my other cars keep me busy over the weekend.
2000 4Runner Limited 4x4 V6
3rdgen4runner , 4xinnovations , magnaflowoverland , 3rd , gen
Saw this today... StreetCreeper 3rd gen T4Rs 50 12-21-2024 01:33 PM
Weird Problem today with my 4Runner today. myT4RisGREEN 3rd gen T4Rs 12 12-11-2021 08:17 PM
Going to look at a 3rd Gen today Diverse4runner 3rd gen T4Rs 38 03-23-2021 09:57 PM
Today 11/6 only!!! YotaDan Wheeler's Off-Road 0 11-06-2014 04:31 PM
605/5 5th Gen today? expatoz So Cal 3 02-13-2013 10:38 PM
