12-19-2011, 08:59 PM
#46
Fabricated a better antenna mount and washed it.
My Junk
12-19-2011, 09:13 PM
#47
Admired the crap out of it.
#48
Built my Panhard drop bracket!
I should add, without Ripcord's help with the dimensions, I would have not been able to do this mod.....thanks man!
1998 4Runner SR5, ISR and Deckplate Mods, Painted Intake Manifold, TRD Tundra Struts, Diff Drop, LC 8 Wraps w/ Skyjacker shocks, Panhard Drop Bracket, Rear Tire Carrier, Maxxis Bighorns, Procomp Wheels, Custom Front Valance, Sport Edition Skidplate, Upgraded Exterior lighting
12-19-2011, 09:16 PM
#49
Fit it into my garage!
12-23-2011, 12:04 AM
#50
I need this, anybody want to pass the dimensions to me? Ripcord perhaps.
12-23-2011, 12:06 AM
#51
12-23-2011, 12:19 AM
#52
Real Name: Jim
Real Name: Jim
Off the top pf my head i want to say its 3/16" steel and 2.25" between hole centers. The numbers are in my messages inbox and im on my phone and lazy. Maybe fightman can chime in to confirm the numbers.
'13 Tacoma TRD-OR: The Spruce Goose. BUILD
'02 Sport Ed.- V2.0: The better build. Totaled BUILD 2.0
'02 Sport Ed.- V1.0: The college build Sold BUILD
12-23-2011, 02:34 AM
#54
i wouldnt say what i did today but over the last 4 days i put 1200 miles on it, frist drove from chico to LA with about 400lbs + 1200lb jetski trailer. next day drove 4 people plus ski gear, stuff and food for 3 days to go to mammoth and back.
2002 SR5 4WD
deckplate + ISR, Airlift 1000, OME 881/890, Goodyear Wrangler Duratrac 265/75/16C
Tundra 231mm Brakes - yes they DO fit the stock 5 spoke rims - Stubbs Welding HD-SKO sliders.
12-23-2011, 02:44 AM
#55
Smogged. Passed CA emissions test. Not bad for a 15 yr old truck with 245k and the original cat...
'96 4Runner SR5 2WD Auto, 30x9.5x15 Treadwright Puma, ISR mod, B&M Trans Cooler (Rad. & Trans. Separate), Magnefine (Transtar) Inline Trans Filter, 255K miles
12-23-2011, 03:01 AM
#56
Fixed the source of the water leaking into the interior from the sunroof issue.
Project LEXUS GX470 Build 6 /Radflo 2.5 Full Suspension Extended Travel ~ All Pro 3.5" Springs ~ SPC UCA ~ SCS SR8 Wheels ~ Metal Tech Rear Spring Isolators\ Daily Driver/Weekend Warrior
12-23-2011, 11:26 AM
#57
Fixin' to do a TB/WP change, install new rad, install new Airraid tube, remove elbow in the fender, do DP mod, & install some LED interior bulbs...
1999 4runner SR5, V6, auto., 184,000 mls.. DP mod, AIRRAID intake tube.. Running on 265 75 16 General Grabbers HTS (it's the ole ladies DD) . . . .................................................. .... ..... 1977 Jeep Cherokee Chief.. 401, auto., 35 Pro Comp's
12-23-2011, 04:50 PM
#58
Moderator
Real Name: Dylan
Moderator
Real Name: Dylan
nothing as i am currently 2000 miles away from it
The Rock Turtle Lifted, Locked, Boosted, Armored, TacoBoxed, and awaiting destruction.
12-23-2011, 05:14 PM
#59
Ran mine out of gas 10 km away from Banff coming back from Louise. Broken gas gauges suck. On the plus side, AMA only took 45min and I had my iPhone to keep me entertained.
1999 Limited 4wd E-locker
Yakima Megawarrior - Thule Snowsports Flat Top
Hella 500ff's
Goodyear Duratrac's 265/75/16 C
Neurotically cleaned and maintained
12-23-2011, 06:45 PM
#60
Finally got around to properly installing my stereo with butt connectors. I installed it rather quickly before a 12 hour trip this past summer and just used electrical tape. Nothing special, just gives me a little peace of mind.
