08-03-2020, 10:14 PM
#31036
Finally got around to cleaning up the engine bay! This has been irritating me for quite a while. It had definitely been several years since it was cleaned. There was so much grime on the engine I was afraid I was going to uncover a leak, but it's solid as a rock.
1998 SR5
08-03-2020, 11:25 PM
#31037
Real Name: 3 Bears
Real Name: 3 Bears
looks good
08-04-2020, 11:50 PM
#31038
Real Name: Zac
Real Name: Zac
Originally Posted by Endlessblockades
Pardon my ignorance, but is this a common mod or are you the pioneer? These seats are not too wide? Mounting rails need much modding?
Thanks!
Not sure if anyone has done this particular seat swap, I removed the (foot) brackets off my stock seats and welded those to the subaru seat rails.
The seats aren't too wide and the rails are within 1/4" width of the 4runner rails. It's easy to power them as well. I tied mine into an aux fuse block under the seat.
1998 SR5 5 spd 4x4 3.4L + some other stuff
1985 Tercel 4WD SR5 6spd, 4A swap
2006 Saab 9-2x Aero 5spd (saabaru)
IG: r0amerr
https://www.toyota-4runner.org/3rd-g...ce-thread.html
08-05-2020, 12:08 AM
#31039
Real Name: Devan
Real Name: Devan
Originally Posted by norcalassassin
Seat swap final touches..
2006 Subaru Legacy GT front seat swap.
Soo comfy
Hot damn, those match pretty well. If those had tan colored bases, they would totally complete the interior
08-05-2020, 09:12 PM
#31040
Today my local alignment guy installed new tie rods, upper and lower ball joints, links, bushings, shocks and springs.
New tires and newer wheels went on Monday.
Happy happy happy!
08-05-2020, 09:40 PM
#31041
Real Name: 3 Bears
Real Name: 3 Bears
Happy happy happy!
on all 4 corners.....must drive real nice now
08-05-2020, 11:05 PM
#31042
Finished up the deckplate mod yesterday. I had actually forgotten that I installed it, and a short drive didn't really remind me even though driving it did just feel a bit better. But I've been doing a lot of preventative maintenance, so things have been feeling better anyway.
But when I went to pass someone, I noticed the louder note right away. It definitely sounds more aggressive. I can't say that the power difference is noticeable, but it does feel just a bit snappier from a stop. Either way, I like the sound!
1998 SR5
08-06-2020, 02:40 PM
#31043
Wow!! That looks really good!! What products do you recommend so I can make my look that pretty?
08-06-2020, 03:10 PM
#31044
Removing the timing belt AGAIN because of an oil leak out of passenger side cam seal on first start after replacing everything... must have not been 100% straight when I pushed it in with a pvc pipe? Purchased a cam/crank seal set off amazon for try #2!
08-06-2020, 04:03 PM
#31045
Thanks! I used this 4.5 inch hole saw and this deckplate. The saw was the absolute perfect size, as the deckplate port just perfectly snugged in with some force. I used Permatex Ultra Grey and some clamps to seal it overnight, then skipped the screws because it is in there solidly, and the only force on it will ever be suction anyway.
1998 SR5
08-06-2020, 07:30 PM
#31046
Installed a cargo net divider to keep things in the back from becoming projectiles in the front...
08-06-2020, 08:12 PM
#31047
ARB Bumper Install
Put this bumper on last night and stared at it all day today
08-06-2020, 08:18 PM
#31048
You are a brave person for trusting amazon products that deep in the engine.
For me it's OEM from the dealer unless the labor to change it again is like 5 minutes and the part is not critical. I've got moog sway bar links and that's about it.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
08-06-2020, 10:53 PM
#31049
Originally Posted by det107
1) Rack & pinion (Cardone unit) from Rokauto
2) Lower Ball Joints from Partznet
3) Rear axle seals
Will need shocks on 4 corners and LCA bushings. To be continued....
... 2 struts from Rokauto up front
... ALN Suspension bushings for LCA (Amazon)
... Camber bolts (Pair from Rokauto but retained the indexed wheel tabs)
... KYN rear shocks (Amazon, these took the longest time to get here)
Off for alignment on Sunday....
08-06-2020, 11:11 PM
#31050
What headlights are these?
