11-27-2020, 11:39 PM
#31516
Real Name: Devan
Real Name: Devan
Originally Posted by norcalassassin
Installed and wired up my coastal bumper. Grille coming soon.
Attachment 372682
Roof camper? Is our roof actually strong enough to lay on?
11-28-2020, 09:38 AM
#31517
Real Name: Mark
Real Name: Mark
It is, as long as you lay on the rails that rack attaches to, I wouldn't lay between them.
11-28-2020, 06:44 PM
#31518
Decided that since the mechanic was already going to be doing the suspension, I ordered 2 new OEM lower ball joints and the flanged bolts.
Looking back, so far I have:
$4000 - Price of 4runner
$2132.22 - Brakes and Control arms
$160.31 - Fluids and exhaust repair
$75 - ECGS Bushing
$85 - Driver side CV Axle
$88 - MAF
$125 - Replacement Stock Air Box (Had a crappy Cold Air Intake on it)
$15 - Upper Air Hose
$299 - OEM lower ball joints
$572 - New springs, new bilstein 4600 shocks/struts
Not including labor on the instal of the ball joints or springs/shocks...
Around $7500 invested in this thing so far.
Id be lucky to get $6k for it if I sold it hahahaha.
11-29-2020, 02:52 AM
#31519
Finally got around to installing the JBA UCA's
I truly underestimated just how much fighting I'd have to do to get the ball joint press-in adapters in; this one-day job turned into two and I may have cooked my impact in the process, lol. Pretty sure I also did something to at least one of the ABS speed sensors from stretching because one of the front wheels trips it (without the ABS light) when braking and low speeds. It's somewhat random when it does decide to engage (i.e. flex, low speed corners, straight line medium pedal pressure), so I'm going to pull the sensors and clean them just in case that may help. Additionally, I got done too late to get an alignment, so I don't know if that is factoring into this.
Driving it back from my shop (about 7 miles) it felt great! The old UCA's and their bushings looked like they were the original, which most likely explains the excessive bump-steer; that is now a thing of the past! Overall, I'm happy with them already and I've learned from my mistakes along the way... and there were a whole lot of them.
'00 'Get Lost' Build
IG: get_lost_fiffa
11-29-2020, 03:53 AM
#31520
Same thing happened w/ my ABS after getting the lift kit put on, still haven't figured it out.
Meanwhile, today was deckplate mod along w/ getting ready to put the air raid system in plus some rough draft of my wiring plans.
11-29-2020, 12:23 PM
#31521
Real Name: Tom...but don't tell.
Installed Alpine ilx-w650...
...and back up camera. I had a tough time fishing wire through the tailgate - and I mean hours of a tough time. Finally, after taking layers of skin off the back of my hands and a wire hanger, I was able accomplish it .
I used an Auto-Vox Cam 6 back up camera - cable it came with was long enough, so no extension needed, but it's connector to the camera is larger than an rca so I had to cut the rubber "tunnel" connector between the truck and the tailgate to run it through (something I saw 'Timmy the Toolman' do). However, my tapping it back together wasn't as clean has his. Think I will try to replace or at least redo it.
I also installed the micro bypass for the parking brake.
Finished it all about 12:45 am, still need to test and tune in the phone and I ordered a Batige Single Square port USB connector so I can take advantage of the USB port on the Alpine.
11-29-2020, 12:29 PM
#31522
Hey, can you post a link to which video that was? I think I will be needing to do this very soon and Tim has a billion videos now so it's difficult to find some of the obscure small fixes like this
11-29-2020, 04:26 PM
#31523
It was actually in regards to repairing the rear hatch wiring, but I remembered it when I was trying to stuff that camera lead through it.
Rear Hatch Wiring Repair (3rd Gen 4runner) - YouTube
11-29-2020, 07:05 PM
#31524
tried to remove stripped bolts in skid plate
been a while since i've had skid plates off and the two center ones heads are trash, guess i'll have to drill them, what a pia. I did manage to change oil/filter and drain/refill tranny (amsoil)
11-29-2020, 08:19 PM
#31525
Real Name: Devan
Real Name: Devan
Lost the fat flip and now part of the cool kids club. All I'm missing is my grille (on the way) and my tire carrier and build is almost "complete" - until I finally shoot for a locker that is! Gonna fit some perforated aluminum to cover up the front and make it look a little cleaner
Bumper and fab work was all done by my buddy Luis, believe this was one of the first he ever made from well over a two years ago. Sells a lot of them now on the 4runners of Washington page on FB.
Also today my CV boots slipped off at some point on the trails and splattered grease everywhere, but it's all yellow and heavily contaminated with water, so in a way I'm glad it did cause now I finally have an excuse to get new axles
11-29-2020, 08:55 PM
#31526
Real Name: Devan
Real Name: Devan
$75 - ECGS Bushing
$88 - MAF
That is an awful lot for brakes and control arms, did you get OEM right from a dealer or something? Should've been able to do it for $1000 or less, at least by my count
11-29-2020, 11:33 PM
#31527
Help !!!
Hello all i have a 1998 toyota 4runner 2.7L
A check engine light came on P0120 throttle position sensor. I replaced the sensor with oem and checke engine light came back. I cleaned the mass airflow sensor , and same problem. I tested the circuit, found good power and found signal to be good. Found good. Ground. I did an ohms check from the power circuit to the ecm found 2.2 ohms. Found the wire had to much resistance. So i ran a wire from the throttle position sensor to ecm. Found the .7 ohms.
I started the truck and found check engine light came back, but with a different code. P 0450 evaporative emission control pressure sensor. Found the vapor pressure sensor share the same power and same ground as the throttle position sensor from the ecm. Do they both share the same power and ground from the ecm ?? I am lost ?? Some guidance will be appreciate it
Thank you guys
11-30-2020, 12:19 AM
#31528
Hey All,
Long time lurker mainly in the 6th Gen forums. Randomly came across this new to me '99 SR5 3.4 V6 with 224k for $4k in excellent condition. I needed something for camping, fly fishing, MTB, Winter...
Not new to building cars, but very new to building trucks! I'm super excited to learn something new about a proven platform if cared for.
Not enough post for a build thread yet. There are a few things done to it already from the previous 2nd owner.
Some pics from before picking it up:
Flickr
Flickr
Flickr
Flickr
First things first!!
Flickr
Two other Toys!
https://www.flickr.com/gp/186301944@N08/750f6b
Plasti Dip Removed.
https://www.flickr.com/gp/186301944@N08/0B77U3
Bug/Rock Guard going on tomorrow. Much more to come!
Thank you all for the different ideas and inspiration to create your own ish rig...
99' SR5 3.4 V6
Front Plate LED Bar || 285/75/16 || Interior/Exterior LED's || Kenwood HU || Rockford Fosgate P300 - 12T || 2" Lift || AVS Hood and Window Deflectors
11-30-2020, 12:26 PM
#31529
Nice find for $4k! That would be a $7-8k car here in the Bay Area.
Is that an R32 in the garage?
11-30-2020, 02:09 PM
#31530
Such is the life of owning an older car, lol. I always hate when I look at how much I've spent versus what it's worth.
I'm making progress on the front end and have officially deemed this operation scope creep.
Untitled by 99blkx, on Flickr
Upper arms are also out now.
Driver side doesn't look good...
Passenger side was bad. The boot was full of fluid.
Waiting to hear back from a local stealership on the price and then I'll either order a new rack local or go have one shipped. The good news about pulling the rack is now it won't be in the way of the cam bolts, lol.
1999 4Runner - 4wd - E-Locker - Sport hood - 270k miles and counting - OEM+ ish "build" in progress
Build Thread
