Tyler James Inc, ugamurph
Thread Tools Rating: Thread Rating: 217 votes, 2.72 average. Display Modes
Old 04-19-2024, 01:14 AM #35521
2TH4IST's Avatar
2TH4IST 2TH4IST is offline
2TH4IST has a spectacular aura about 2TH4IST has a spectacular aura about 2TH4IST has a spectacular aura about
2TH4IST's Avatar
Pulled out the cs144 alternator to replace the voltage regulator with a set point of 14.8v for my agm battery and to swap to a 1.9 inch pulley as it wouldn't charge with the stock pulley (rotor speed was to low) at engine idle. So with a crank pulley diameter of 6.247 inches and a 1.9 inch pulley it spins at 2460 rpm at idle and 18040 rpm at red line. Perfect! Tossed it back into the car and checked the work. Fantastic! Cold charging is 14.8v and hot charging is 14.6v, bingo!
Next moved onto the wench (winch). Got all the wires I made last week installed and tightened down. Sweet. I ended up taking the apex 12k control box apart and took the solenoid and installed it in the passenger wing of the coastal off road bumper. It's tight, but fits and works perfectly. Wired up the cable and wireless control stuff. Accidentally switched the wires so when you hit out it pulled in lol. Quick fix and it works fantastically. With that, all my electrical for now are complete! For now lol. Got to re thread the wench line as I ditched all metal on the line.
Next up is redoing the rear disc conversion. Ditching the Ford calipers for some lc80 rear calipers and wilwood mc4's for the parking brake, seriously need a good parking brake. And at the same time tossing in a lc80 master and booster too.
Then the rear swing out, hope to get these done in the next few months as I want to take a nice 3-5 week vacation offroad trip across country.
To busy working to get pics, sorry.
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
2TH4IST is offline   Reply With QuoteReply With Quote
Old 04-21-2024, 12:30 AM #35522
fatherohenry's Avatar
fatherohenry fatherohenry is offline
Real Name: Mark KN6TZI
fatherohenry is a jewel in the rough fatherohenry is a jewel in the rough fatherohenry is a jewel in the rough
Body Mount Bushings
Bought Toyota bushings from Amayama last January. Cost was about $300. Finally made the time to swap them.
No body lift, just bushings so I didn't have to worry about the bumper or rag joint. And my '96 doesn't have the center mount by the b-pillar. 14 bushings total. The old ones didn't look too terrible but they were sure hard.
I could feel the difference as I left the driveway. Shitty roads and manhole covers feel noticeably softer. Feeling only whelmed after all of my suspension work, this might be the missing piece!
'96 T4R SR5 | 4WD | Auto | 199 TBU | 268k+
Last edited by fatherohenry; 04-21-2024 at 09:11 AM. Reason: Remove unrelated info.
fatherohenry is offline   Reply With QuoteReply With Quote
Old 04-21-2024, 01:35 PM #35523
BuffaloBass BuffaloBass is offline
BuffaloBass is on a distinguished road
was thinking of replacing those during my '99 resto. Decided to forgo that as they looked ok, but now i may...is Amiyama the place to go? Anyway, have to open another phase of this resto up.....found this during needle scaling of the rear frame. I knew there was some "chooch" lurking behind that tank. My handy dandy POR15 rust sealant wont fix that!
I DID NOT expect this. Now instead of finishing frame prep for powertrain reinstall, i have to pull this baby back out to the shop where the 220v TIG machine lives. Son is a excellent welder fabricator thankfully. We will get it right. It will be a YEAR since i picked up the reman 5VZ until it fires up! DANG IT!
What Did You Do To Your 3rd Gen Today?-left-frame-rot-jpg
BuffaloBass is offline   Reply With QuoteReply With Quote
Old 04-21-2024, 04:07 PM #35524
toverturf toverturf is offline
toverturf will become famous soon enough toverturf will become famous soon enough
Originally Posted by fatherohenry View Post
Body Mount Bushings
I'm tempted to replace mine now. Anything to improve the ride quality is a plus.
1999 Limited with rear locker.
Sherpa Matterhorn | Sonoran Steel Diff Drop | SPC UCAs | DuroBumps Front and Rear | OME 890 Springs and Black Tokico Shocks | Eimkeith Reinforcements and PCK | King Coilovers | OCD Sway Bar Links | Opt Offroad Rear Arms | Lil Skips Gas Tank Skid Plate | FGP Rock Sliders | 4x Innovations Rear Plate Bumper with tire carrier
toverturf is offline   Reply With QuoteReply With Quote
Old 04-22-2024, 03:58 PM #35525
Thatgoodfellow Thatgoodfellow is offline
Thatgoodfellow is on a distinguished road
Installed some Bilstein 4600’s with moogs on the front and also new inner and outer tie rods saturday.
The front is definitely higher than the rear now even with the new shocks in the back so I have some 906’s on the way to even it out. Looking forward to finishing up this suspension work.
What Did You Do To Your 3rd Gen Today?-img_1410-jpg
Thatgoodfellow is offline   Reply With QuoteReply With Quote
Old 04-23-2024, 11:49 AM #35526
Zhehan Zhehan is offline
Zhehan will become famous soon enough Zhehan will become famous soon enough
Not to be pedantic, but shocks (not a coilover like the front) have nothing to do with ride height. Springs hold the vehicle up, shocks control the mothion of the springs. Bushings also play a role in control, especially in the rear, but those are the basics. 906's should lift up the rear to a good height and deal with a load far better than the stock springs ever did.
2000 4Runner SR5 Manual Trans Federal Emissions - Eibach Pro-Truck coilovers, LC 7.5/Tokico Black, JBA UCA, SPC 25945 RLLs, Mevotech Supreme RULs, TrakMotive Xtended Travel CV Axles TO-8043ET, South Bend Rally Clutch, ES & Whiteline Bushings, MagnaFlow Cat-Back, Deck-Plate Mod, 4.56 Yukon Gears, Yukon Grizzly Rear Locker, Bushwacker Flares, 16x8 Wheels w/ 285/75 General Grabber AT2, 229K+ Miles
Zhehan is offline   Reply With QuoteReply With Quote
Old 04-23-2024, 02:10 PM #35527
The Moog front springs are taller than the OEM '99 talls - what he is experiencing is normal... especially if the rear springs are still stock.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 04-23-2024, 08:14 PM #35528
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
Upgraded my bumps to some sick Perry Parts 3D printed ones!
Writeup
JZiggy is offline   Reply With QuoteReply With Quote
Old 04-24-2024, 11:38 AM #35529
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
so factory talls ( highlander) sit 1 inch higher than the non talls ( non highlander)
moog sells the stock height and also the talls
so are the stock moog taller than OEM talls, or the moog talls higher than oem talls
Old 04-25-2024, 02:35 PM #35530
I don't know the specifics, but the post referenced has no model years, and other years are lower from the factory than '99, even the 'not-tall' '99's. (my '99 2WD was over 20" hub to fender lip with the factory suspension/weight, even after 15+ years)
The Moog PNs that float around here are generally for the "99 Tall" version, so that's my assumption as to what was purchased.
Old 04-26-2024, 09:19 AM #35531
Kmurt's Avatar
Kmurt Kmurt is offline
Kmurt will become famous soon enough
Kmurt's Avatar
I just went through the same thing and had the same exact spot rust on mine as well. Can't see it because the gas tank covers up most of that side.
Make sure you blow out as much rust and debris in the frame as you can before repairing that area. Then when all is said and done, spray a lanolin coating on the frame like Fluid Film or Woolwax to prevent rust.
You can see it in this thread I posted: Gas Tank Replacement Journey
2001 4Runner SR5 4x4
2019 4Runner TRD Offroad 4x4
Kmurt is offline   Reply With QuoteReply With Quote
Old 04-26-2024, 10:31 AM #35532
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
DANG IT!
Know your pain. You'd have to repair the rust you have doesn't hurt to add some extra beef. Lower Link Mount Skids/Reinforcement – eimkeith.com
96RedRunner limited 4x4 5VZ auto not stock 374k miles totaled 2018.
2001 limited 4x4 5VZ auto work in progress.
2011 Audi S5 Prestige 4.2 V8 6 spd MT.
Old 04-28-2024, 06:38 PM #35533
Real Name: 3 Bears
Real Name: 3 Bears
Installed the suzuki 105 amp alternator today.
Wasnt planning to do it today....but my alternator crapped out last night. Only had time to do the alternator, have all the parts to do the big 3, but no time.
under full load, everything on , at idle my volts stayed right up there and never dropped below 13.4 according to my torque pro app
im pretty sure phattyduck turned me on to this mod
1st gen 105 amp bolt in alternator. | Tacoma World
Old 04-28-2024, 09:09 PM #35534
Jammies Jammies is offline
Jammies is on a distinguished road
Found some junk parts
Jammies is offline   Reply With QuoteReply With Quote
Old 04-28-2024, 09:21 PM #35535
Donor '99 Taco
look at those toytec spacers
3rdgen4runner , 4xinnovations , magnaflowoverland , 3rd , gen
Saw this today... StreetCreeper 3rd gen T4Rs 48 01-30-2022 08:52 AM
Weird Problem today with my 4Runner today. myT4RisGREEN 3rd gen T4Rs 12 12-11-2021 08:17 PM
Going to look at a 3rd Gen today Diverse4runner 3rd gen T4Rs 38 03-23-2021 09:57 PM
Today 11/6 only!!! YotaDan Wheeler's Off-Road 0 11-06-2014 04:31 PM
605/5 5th Gen today? expatoz So Cal 3 02-13-2013 10:38 PM
