05-02-2024, 05:43 PM
#35551
Real Name: Throws like a girl
Originally Posted by Spiker Engineering
Thanks for sharing these, this is horrible. It looks like the ARP bolts had some basic black oxide coating, which would not be good for an undercarriage or anything else exposed to weather. The Toyota ones have much better plating. I might update my posts in the study to reflect this. Did you switch to the "black" bolts?
Would you be OK if I shared your photos, and can you send me some more if you have them? I think you have my contact info; if not, just ping me on PM.
Yep, the black ones 663-1004.
I've still got the bolts, they're out of the truck and covered in b'laster stuff. They didn't give me too much trouble coming out- I didn't even try until they'd had a couple of days to think about their situation.
Will get pics to you one way or another, will try to do it tonight (central time).
EDIT: just realized I didn't answer your question. I went with the ones for the 96 Toyota 90080-10066, the flange bolts that match what's on the left side.
'96 4Runner SR5, assorted baubles and doodads. Stuff happened to it. Stuff is still happening to it. Okay, now the stuff is just getting ridiculous.
'99 4Runner SR5 Highlander, manual w/locker. Stuff is starting to happen to this one too...too much stuff! Too much stuff!!
http://www.yotatech.com/f200/habaner...thread-201751/
Originally Posted by PWD4R
I know this is a weird ass question but do you shave your legs or something?
05-03-2024, 10:01 AM
#35552
official vendor
official vendor
Originally Posted by phattyduck
The ARP's on my LBJ's here in SoCal are rusting too - not *quite* that bad, but still fully rusted top and bottom. They will definitely have to be brushed and soaked before removal in the future. Looks like whatever makes those bolts strong also makes them prone to oxidation...
Charlie, would you mind sharing a photo? You know that parts are substandard when they rust in So Cal!
05-03-2024, 10:12 AM
#35553
official vendor
official vendor
Thanks for the pics. I guess that's not super surprising given that they are finished in black oxide, not plated.
I'm going to update my recommendations based on this feedback, I think the Toyota black bolts are a better choice, since they were essentially tied with ARP, but are plated and won't rust like these did.
If I can dig up my test setup I might run some tests on ARPs stainless bolts, like the 761-1004. They are 300 series, so a tad weaker than the chrome moly bolts, but they won't rust. That may be a good alternative:
05-07-2024, 12:28 AM
#35554
Real Name: Nelson
Real Name: Nelson
Finally able to log back in here as anyone else had an issue ? Anyway changed front brake pads and rotors at 383,988 then changed oil at 384,987
Off road runner
-Toyota 4runner
05-07-2024, 02:27 PM
#35555
05-08-2024, 06:04 AM
#35556
Changed the left shock using the truck as a spring compressor.
I'm silly pleased with how well this worked.
A few pics with explanations, description of the entire job was a few posts back.
I'm still not a mechanic, but I can whip up a whole lot of school lunches!
Floor jack to lift the loosened lower control arm and compress the spring so I can remove the shock.
Using a wrench to push and guide the shock shaft into place, part of installing the new one.
and there you go, ready for the bushing, washer, and nut
05-09-2024, 04:23 PM
#35557
Real Name: Blair
Real Name: Blair
Originally Posted by clearock
Can't wait to see this beast completed.
05-09-2024, 07:20 PM
#35558
Started the work on the land cruiser rear caliper brackets and wilwood mc4 parking brake bracket. My co workers dad is a carpenter and he planed me down some hard wood to use for the bracket template. I used the ford caliper bracket to get the axle housing bolt pattern, then started mocking everything. Started with the caliper, was going to use some penny's to space the caliper bracket off the rotor, but I used some zip ties taped to the rotor and it worked perfectly. Got the caliper bracket as close to centered as I could (I don't have any m12 shims at the moment).
The caliper fits perfectly. Moves freely and the line and bleeder are perfect! Next up was the parking brake. It was a bit more tricky as the lever and cable brackets stick out a bit. Since I was only mocking up on the passenger side (brackets are the same left to right) I had to get it to clear the panhard mount and bump stop (I'm changing to perry parts bumps) so I'll have a bit more room then the oem bumps.
Got it mounted to the bracket. Now the big test is wheel clerance. It fits perfectly. About 1 inch all around on a oem 5 star 16 inch rim. Sweet. Tidied up the template by removing material where it's not needed. I'll use 3/8" steel for the brackets. Cutting them out will be fun though.....sigh....
Here are some pics.
Edit to add: I'll be swapping to a lc80 brake booster and master cylinder as well.
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
05-11-2024, 04:29 PM
#35559
Real Name: Devan
Real Name: Devan
Sick as hell
05-13-2024, 12:04 AM
#35560
windshield replaced body repainted
Anyone know a skilled body shop place in the north Idaho area? Broke my mirror, dented my frame around the window.Wondering if someone knows of a guy who can do body work/replace window as well? Don't want frame to rust
05-13-2024, 07:17 PM
#35561
Paint, Tires, Rims, Tint
Almost to the end of my 1997 4runner build. I started this project in 2021 to build the best 3rd gen I could, almost full restoration. I'm moving to my final project, a full engine rebuild. This last month, I got most of the car painted, new rims and tires, and nano ceramic tint.
Link to the full build sheet with costs and links -
4runner build - Google Sheets
1997 4runner | Build Sheet
Reason: added images
Yesterday, 06:29 AM
#35562
Originally Posted by Jcol8896
Almost to the end of my 1997 4runner build. I started this project in 2021 to build the best 3rd gen I could...
Google Sheets[/url]
Wow...I do NOT want to know what the (still on-going) total for all the...ummm... maintenance of and for my 96!
The spreadsheet is a good idea, and the truck looks great.
Yesterday, 10:57 AM
#35563
Almost to the end of my 1997 4runner build. I started this project in 2021.
This is a great build. Back to new 4runner. Spread sheet details shows immensity of material and labor. Neice work.
