Old 12-28-2011, 05:12 PM #1
KHoffRunner's Avatar
KHoffRunner KHoffRunner is offline
KHoffRunner is on a distinguished road
2000 Limited Stock Radio Wont Light Up
I have a 2000 limited, as far as I can remember the stock radio and the buttons around it have never lit up since we bought it, but i was wondering if it was maybe a fuse or a problem with the radio. Also i noticed the additional 12v outlets below the ciggarette lighter dont seem to have a power out put, I checked the fuses didnt see any blown but then again I'm only 17. Any ideas on the problem I apreciate it, hopefully its something easy.
KHoffRunner is offline   Reply With QuoteReply With Quote
Old 12-28-2011, 05:19 PM #2
awdjunkies's Avatar
awdjunkies awdjunkies is offline
awdjunkies is on a distinguished road
awdjunkies's Avatar
Is it just the radio that doesn't light up? or is the auto climate control the same way? If it's the climate control as well here is the DIY: 99+ LTD Auto CC Light Replacement - YotaTech Forums
By the way, welcome to T4R.ORG
'04 GGM 4Runner SE-V8 4x4/XREAS/Auto Dim-Compass rear view/homelink/RSCA curtain system/Pioneer deh-x8500bs/Grabber AT2/Gibson CBE/HCF Delete/Gobi Ladder/yellow HID Fogs.. awdjunkies build thread
Shout out to Stuck_CAPS For this GEM: http://www.toyota-4runner.org/4th-ge...iy-videos.html
awdjunkies is offline   Reply With QuoteReply With Quote
Old 12-28-2011, 05:31 PM #3
Thanks for the reply. Its just the radio and surrounding buttons, the climate and clock still light up.
Old 12-28-2011, 06:25 PM #4
Brilliant's Avatar
Brilliant Brilliant is offline
Brilliant is on a distinguished road
Brilliant's Avatar
Does the radio work or just not 'light up'?
Did you try turning up your dimmer switch, knob on the dash next to your left hand? The radio is pretty dim when the dimmer is cranked all the way down.
The lower power outlets only work when the ignition is on ACC or ON, I forget which.
You mentioned couldnt see anything wrong with the fuses. Sometimes you cant see an issue. The best way to test a fuse is to use a mutlimeter, set it to continuity (light/beeper), and test over the fuse. The fuse has two small test points on the top and you can test all your fuses quickly without removing them.
Brilliant is offline   Reply With QuoteReply With Quote
Old 12-28-2011, 06:53 PM #5
Yeahh the radio works, it plays fine it just doesnt light up which has gotten annoying.2000 Limited Stock Radio Wont Light Up-2011-12-28_17-41-15_181-jpg
2000 Limited:250K, Icon 2.5 fronts, Toytec Superflex rears/Bilstein 5100's, Yokohama Geolander AT 285/75/16, diff drop.
Old 12-28-2011, 07:08 PM #6
Brilliant's Avatar
Brilliant's Avatar
Check the ACC fuse in the dash and the power outlet fuse in the engine bay fuse box. Use a multimeter, not your eyes.
2000 4runner wont start without clutch cancle jmcgahran 3rd gen T4Rs 2 08-26-2011 08:41 PM
FS: Stock CD Radio from 2000 Limited sonjason Classifieds - buy & sell (no commercial ads please) 0 03-04-2011 08:58 PM
Hmmm 2000 3.4L 4Runner wont start right after being turned off Y2KSR5 3rd gen T4Rs 2 01-16-2011 11:06 AM
2000 4Runner Limited radio backlight dimming ftatester01 Engines / Suspension / Wheels / Tires / Audio / Accessories 5 12-21-2010 11:52 AM
What are stock 2000 Limited speakers? tineman06 3rd gen T4Rs 5 07-24-2008 08:22 AM
