01-05-2012, 04:14 PM
rear diff fluid question
What gear oil should I put in a '97 3.4 with the factory locker?
The haynes say's SAE90, but in my research many people on here say 75W-90 for rear, t-case and front...
01-05-2012, 04:27 PM
I used 75W-90 to change mine, works fine for me.
01-05-2012, 04:29 PM
^ Ditto, no problems to report.
1996 SR5 Automatic V6
Deckplate, ISR, B&M 70268, Tundra/5100's & LC 7.5 wraps/Tokico's, 265/70/17 Terra Grappler's on Tundra Split Spokes, Tundra 231mm brakes
01-05-2012, 05:38 PM
75W-90 over here as well.
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
01-05-2012, 05:46 PM
I was just at the dealership to pick up the crush washer and they looked in the computer and said 80W-90 so I bought that. Sounds like either one will work just fine.
I think the book actually says the rear diff gets 80w90 and the other two get 75w90..
But I did like the other posts, I just used 75w90 in all three. Just makes it easier when buying it. You will be fine with the 75w90..
01 SR5 - 187k+/- 285 BFG A/T KO2 - 99 talls & front Trekmasters / Rear KYB - Hella fogs - Taco Mod - Fixed gaping hole in frame {SOLD}
02 Taco - 197k +/- BFG A/T KO2 285s + rims from 4Runner - saving up for suspension - House gets priority over Taco (for now)
01-05-2012, 06:04 PM
redline 75w90 in all 3 no problems
99 4runner W/01-02 conversion
JDM Headlight Retrofit w/ custom LS460 bi xenon projectors,ODL Bumper,japan spec conversion ,Hella Twin Supertone horns,Kings 2.5" External Resi Compression Valved front and rear, Camburg UCA's,Addcco Sway bars,TRD supercharged,AFE Intake,Custom apexi catback,TRD Trans Cooler,Lots of Jaos Goodies,16x8 Volk Racing TE37X's BFG KO2 265/75/16 Stoptech Big Brake Kit
01-05-2012, 06:25 PM
I used Royal Purple's 75W-90 in all 3 of mine; loving it.
'99 Millennium Silver Metallic T4R Limited Auto 4-Speed
3.4L 5VZ-FE V6 4x4 with Rear E-Locker
YODA Build Thread
01-05-2012, 11:28 PM
Real Name: Alex
Real Name: Alex
I used Mobil 1 75-90 synthetic in all 3 of mine.
Where are you stationed?
2006 Lexus GX 470 Sport- RR Diff Lock, Metal Tech Sliders, RCI Aluminum Skids, Front Runner Slimline II Rack, SCS F5s, 255/80R17 ST Maxx , OME BP-51s, Dirt King UCAs, Metal Tech RR Lower Links
2016 Lexus IS300 F Sport- F-Sport Air Filter RR Racing tuner
01-06-2012, 12:19 AM
80W90 is the dino, 75W90 is synthetic. Either are fine, I put in synthetic.
01-06-2012, 03:34 AM
Do you guys use 75w90 shockproof? superlight, heavy, or lightweight?
'04 GGM 4Runner SE-V8 4x4/XREAS/Auto Dim-Compass rear view/homelink/RSCA curtain system/Pioneer deh-x8500bs/Grabber AT2/Gibson CBE/HCF Delete/Gobi Ladder/yellow HID Fogs.. awdjunkies build thread
Shout out to Stuck_CAPS For this GEM: http://www.toyota-4runner.org/4th-ge...iy-videos.html
01-06-2012, 10:46 AM
2000 SR5 3.4L V6 Automatic 4x4, e-locker, 175k Miles, Rust
Imp. Jade Mica with Oak Leather Interior, Field Monitor Unit - B&M Tranny Cooler - SG2 - New (to me) rear axle assembly - Goodyear Duratrac 265/75-16 - 1.8" Ironman Front Lift, OME 906/Procomp 9000 Shocks
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
01-06-2012, 11:07 AM
Truck has the heavy shockproof in everything. Most of my cars i run the lightweight shockproof. you will probably be find with either though. Best gear oil you could ever run. Especially for a manual trans.
01-06-2012, 01:39 PM
Awesome!! Thanks, and yes, I too run LW in my cars as well.
01-09-2012, 03:41 AM
Does anyone know if we should use any special additives in addition to the gear oil and does it matter what type of gear oil? (GL4, GL5...)
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
