Originally Posted by Tarp Man
I have a similar problem with my 99 Limited. I worked the rubber boots off and found multiple broken wires in the loom. Is it possible to replace the whole wiring loom? I can't seem to get anywhere with my local Toyota dealer here in Victoria BC.
Looking at the wiring diagram for my 2000, it looks like the answer is possibly, but only with a huge amount of work, and the replacement loom isn't available to buy. The wiring for the rear hatch runs uninterrupted from the drivers kick panel through into the tailgate, and the wires in the loom come from multiple connectors located in the kick panel area, so you would need to repin the connectors if you wanted to replace the loom. So while the answer isn't technically no, the answer is effectively no, you can't replace the loom.
