Originally Posted by MattDyer94
Just curious..I'm no genius mechanically at this stage yet. I'm planning to learn a lot when I get this 4runner but what should I be looking for when you say "check it out real good"? My dad knows a fair share so I'll mention it to him but would the mechanic not be able to catch this?
Regardless, I'll take this as a learning experience. What should I look for?
Timing belt and water pump replaced?
Check coolant and tranny fluid real well.
Check rear heater lines.
Check for play in the lower ball joints and outer tie rod ends.
Look under it real well for rust.
Drive it and listen for noise in the differential. (humming noise while moving)
Obviously use all the electric windows,sunroof, rear hatch glass, locks, etc.
Check all the body panels for a VIN sticker. (otherwise most likely hit before)
Test the 4 wheel drive.
