Old 02-05-2012, 05:26 PM #1
djbrand1's Avatar
djbrand1 djbrand1 is offline
djbrand1 is on a distinguished road
djbrand1's Avatar
Tundra brake anti-rattle clips
Did the tundra brake upgrade this weekend.So did I put these clips in right? They don't seem secure in any method I've tried. I need to rebleed and flush the rest of the system before I can make a good evaluation, however right now I have a spongy brake pedal that is a bit worse than the factory brakes. Just ran out of time to flush and bleed everything again.
00 4runner
djbrand1 is offline   Reply With QuoteReply With Quote
Old 02-05-2012, 06:00 PM #2
ALBPM's Avatar
ALBPM ALBPM is offline
ALBPM is on a distinguished road
ALBPM's Avatar
WTF!!!!
Looks like you some how mangled 2 clips together on each caliper....
Here's what they should look like...maybe some one has a better picture.
2002 SR5 4x4, Dorado Gold
Suspension:Front:Toytec Coilovers w/ 5100 Bilsteins/RevTek Diff Drop, 231mm Tundra Brake upgrade. Rear: ToyTec Superflex coils/5100 Bilsteins.
Tires: 285/75/16 Bridgestone REVO 2's
The Rest:I.S.R. Mod upgraded to an Injen intake, Borla XR-1 muffler, ARB Bumper, Shrockwork's Rock Sliders, CBI Rear Bumper and a pair of Hellas. Plus a whole bunch of other accessories.Topped off with Zaino's Polish.
ALBPM is offline   Reply With QuoteReply With Quote
Old 02-05-2012, 10:08 PM #3
Brutus Brutus is offline
Brutus is on a distinguished road
That's not right. ALBPM's pic shows them right.
98 SR5 Desert Dune
300,000+ miles.
OME 881's and 90004 struts in front. OME 906's and 60028 shocks in rear. 265/75/16 Yokahama Geolanders. Deckplate mod. Tundra brake upgrade. 1-1/2 wheel spacers from WabFab. Few others doo-dads.
Brutus is offline   Reply With QuoteReply With Quote
Old 02-05-2012, 10:22 PM #4
BigFishAllDay's Avatar
BigFishAllDay BigFishAllDay is offline
BigFishAllDay has a spectacular aura about BigFishAllDay has a spectacular aura about BigFishAllDay has a spectacular aura about
WTF is right! Were you trying to weave something out of those things that would get you by?
Read the 231 TBU thread (link in my sig). There are close up pics and step by step instructions on how to put the pads into the calipers.
2001 SR5 Sport Ed. S/C'd V6 Auto 4wd (< Click for Build) ....everything but a kitchen sink (it's on the "to do" list)....
2003 Tacoma SR5 S/C'd V6 5-spd 4wd (< Click for Build) ....boost, armor, lockers, gears, etc....
2008 Sport Ed V6 Auto 4WD (< Click for Build) ....the Grocery Getter OEM+ build....
My Write ups: T-Case Leak? - 231mm TBU - Rear Axle Seals - Trans. Cooler Install - Suped Up Air Comp - Big 3
BigFishAllDay is offline   Reply With QuoteReply With Quote
Old 02-05-2012, 10:27 PM #5
xcmountain80 xcmountain80 is offline
xcmountain80 will become famous soon enough
Hahahahaha
xcmountain80 is offline   Reply With QuoteReply With Quote
Old 02-05-2012, 10:41 PM #6
jsmithjr732's Avatar
jsmithjr732 jsmithjr732 is offline
jsmithjr732 is on a distinguished road
They're wrong. See the pictures. You won't lose your pads, but they're probably rattling over every bump. If they're still on.
I highly recommend getting OEM clips. The ones that came with my Napa calipers broke and the Autozone replacements were too loose. I would hear my pads rattle on big bumps.
OEM fixed it right away.
jsmithjr732 is offline   Reply With QuoteReply With Quote
Old 02-06-2012, 10:57 AM #7
djbrand1's Avatar
djbrand1's Avatar
Haha, I figured they weren't right. I didn't weave them together though, just put them on each side and put towards the center. I'll fix em when I'm re-bleeding later. Now that I see a picture, that makes a whole lot more sense.
Other thing I found interesting trying to bleed the rear drums. I couldn't get any fluid out using one guy to pump the pedal, then opening/closing, releasing the pedal, repeat. Only time I was able to get fluid to bleed was with the engine running. Does the ABS system close or something with the engine off? First time I've ever bled drum brakes, but I'm no stranger to bleeding brakes. The front brakes I was able to bleed with the engine off as normal.
00 4runner
Old 02-06-2012, 10:58 AM #8
djbrand1's Avatar
djbrand1's Avatar
By the way, these clips were what came with the re-manufactured calipers I bought. Raybestos brand. I've been listening for the pads rattling cause I figured they weren't in right, so maybe I've been lucky thus far.
00 4runner
Old 02-06-2012, 11:56 AM #9
Mine started rattling a week or two after I initially installed them. Only that cured it was to get the OEM ones. I compared the OEM ones to the spare Autozone version I had--OEM was noticeably thicker and stronger.
If you start to hear rattling over bumps but they go away if you're on the brakes, that's the reason.
Old 12-26-2012, 11:23 PM #10
blizz86's Avatar
blizz86 blizz86 is offline
Real Name: Brian - 20
blizz86 is on a distinguished road
blizz86's Avatar
lolol
i just finished doing the TBU and i had extra "anti squeal" clips that i put on.. is it fine to have two on each caliper instead of just the 1?
2000 Limited 4x2 Build - OME lift // Tundra Brake Upgrade // Wet Okole // 265/70/16 Michelin X Radial LT2 // 3" FXR + 50 w Morimoto 5k // 1.25" Spidertraxx 4 corners
2012 SR5 4x4 [Magnetic Gray]: Stock suspension // OPOR TE sliders (trimmed rocker panels) // Husky Mudguards // CMG Roof Rack
blizz86 is offline   Reply With QuoteReply With Quote
Old 12-26-2012, 11:38 PM #11
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
It is OK, nothing detrimental will happen if you use two clips per caliper. I found that only using one clip(on top) actually helped stopping just a little quicker than if using two IMO.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 12-26-2012, 11:44 PM #12
blizz86's Avatar
blizz86's Avatar
Hmm okay. Ill probably take off the bottom one then, installing the passenger side tomorrow since it got dark pretty fast today. Thanks
Old 12-27-2012, 04:00 AM #13
Brilliant's Avatar
Brilliant Brilliant is offline
Brilliant is on a distinguished road
Brilliant's Avatar
bleed problems?>
Speed Bleeder Bleeding Brakes Bleeding Motorcycle Brakes Automotive Bleeder Screw Brake Bleeder They sell them at autozone.
Brilliant is offline   Reply With QuoteReply With Quote
Brake Parts - How many pins, clips and springs? BurghRunner 4th Gen T4Rs 2 02-19-2011 12:25 PM
Anti lock brake actuator Flintstone Classic T4Rs 5 01-22-2011 12:39 PM
Anti-Rattle Spring problem... Zander1205 3rd gen T4Rs 1 08-27-2008 04:53 PM
How hard is it to replace the anti-brake bulb? Lon Bauer Maintenance/Detailing 0 02-01-2008 01:52 PM
90 Anti-lock brake light killing me jeb 4th Gen T4Rs 0 10-24-2004 06:34 PM
