Old 02-07-2012, 05:19 AM #1
Suprareal's Avatar
Suprareal Suprareal is offline
Suprareal is on a distinguished road
Suprareal's Avatar
Suprareal's Build Thread ( Pic Heavy )
This will be my build thread, adding little by little as i can. Wait i think im done... 4wd conversion might be in future plans though.
1998 2wd Auto 3RZ 4 cylinder ( City DD ) 3.90 stock gearing.
[B][SIZE="4"]CURRENT AS OF MARCH 2013
This is what i came from... 89 Buick Electra V6 FWD and i loved it believe it or not. Wish i still had it. Ran like a champ just looked like it did not.
Here she is when i first layed eyes on the craigslist add in October 2010
Bought it at $3500. 184,000 miles including Full suspension setup in almost new condition and brand new tires.
When i got home i could not stay away from the thing
When i bought the truck i never intended to mod it further than window tint but this site broke my bank and changed my mind.
First thing i did was install my sound system and tinted windows
35% windshield/fronts and 5% limo the rest.
I've always loved black rims so knew i would do that from the beggining.
I then discovered the oil pan gasket was leaking so i replaced all the Gaskets, seals, o-rings, filters you name it, in that area and never had a drip since.
Out of all the parking this guy decided to make me look like a Hot wheel at work, i said awh man what a $#%^, then he came in and i had to make his pizza...
Then i discovered clear corners and blinkers and bought a set on ebay
And fixed the broken antenna by replacing the plastic rod and actual antenna
Before
Clear
Then to translucent black blinkers
The first disaster i encountered happened the first time it rained... i guess i was missing a roof bar bolt and it let water in and filled up the sides of the headliner and somehow dripped and filled a pair of shoes and soaked the rear carpet. i ended up vacuming a equivilent of about 3 water bottles of water out. Still amazed to this day how bad it was.
Here i am airing it out ( smelled horrible for weeks)
You can tell how mad my dog was that this happened to me "AWHH"
Suprareal is offline   Reply With QuoteReply With Quote
Old 02-07-2012, 08:12 AM #2
Singtoe's Avatar
Singtoe Singtoe is offline
Singtoe will become famous soon enough
Singtoe's Avatar
cool color. I didn't get where Supra comes from though.
I was looking forward to some twin turbo goodness.
1999 Limited 4runner in Silver - 9th and 10th Injected TRD Supercharged 4.7 2UZ-FE swap - AISIN Manual hub lockers - Retrofitted E-locker - Downey Off road Coilovers & adjustable Pan Hard Bar - Whelen PA - 2" Personally made Body Lift - Eclipse Navigation Radio - Spider Trax - Custom Hidden Winch - Triple Electric Fans - Running boards off then back on again - Ghetto Cold Air Intake - Sequoia Brakes - V8 Badge (for extra horse power)
2002 SR5 Tacoma Extended Cab also in Silver On 37's and Guns for sale
Singtoe is offline   Reply With QuoteReply With Quote
Old 02-07-2012, 10:47 AM #3
fightman80's Avatar
fightman80 fightman80 is offline
fightman80 will become famous soon enough fightman80 will become famous soon enough
fightman80's Avatar
Good start man! I also love that color on the 4Runner! BTW, you should post a pic you and your Rig on our thread!
http://www.toyota-4runner.org/3rd-ge...er-thread.html
1998 4Runner SR5, ISR and Deckplate Mods, Painted Intake Manifold, TRD Tundra Struts, Diff Drop, LC 8 Wraps w/ Skyjacker shocks, Panhard Drop Bracket, Rear Tire Carrier, Maxxis Bighorns, Procomp Wheels, Custom Front Valance, Sport Edition Skidplate, Upgraded Exterior lighting
fightman80 is offline   Reply With QuoteReply With Quote
Old 02-07-2012, 03:41 PM #4
Suprareal's Avatar
Suprareal's Avatar
I wish! haha
The names something I made of from skateboarding a while back, used it on eBay and other sites so I went ahead and used it here.
Old 02-09-2012, 02:33 AM #5
Suprareal's Avatar
Suprareal's Avatar
I then started liking the look of smoked tails so i did them and plasti-dipped my emblems adding a trd emblem. if your paying attention yes this did come before the tint, i forgot
Replaced the front sway bar bushings with Polyurethane
Changed oil and whatnot around this time also
All of a sudden my paint started oxidizing on the top of the door. Had to fix that quick before it got worse.
I ordered a touch up paint pen from the stealer reduced it with lacuer thinner and shot it through a airbrush, then applied auto clear coat from a can. matched perfect and holds up.
After
I changed the cluster lights and corners to pure white LED's
Wade In-channel window visors front only
I knew i needed more HP so i painted my calipers red and added the high temp TRD decal which hold up extremely well.
I wanted my truck sound deeper than stock but not loud, after alot of research i finally went with the MagnaFlow 18'' welded up to stock pipes. Amazingly it was the exact sound i was looking for and i have never had any problems with it.
Surf185 came to the rescue with a front bumper 100% better than mine and a grille ready for the satoshi mod.
At the same time i added aftermarket glass 99 and up headlights from ebay ( great quality) and some hella 500 flood fogs i got for christmas.
After scanning craigslist for forever i found a set of BFG all terrain 265/75/16's for 50$ right around the corner with Very decent tread. I needed to find 16's for them so i ended up trading my dad for his off his tundra for some other rims and tires i bought for him on craigslist. (chrome sequioa 3 split ) and i painted the black of course.
I was trying to figure out the noise (errrt) that is made from shifting from reverse to drive so i replaced both U-joint's, did not solve the problem but feels smoother after replacing
I went with the best ones from orielly auto parts with zerk fittings of course
I replaced my brake pads before i started modding but i finally got around to matching my shoes, i have wagner thermo quiet on all four's
My dash was coming apart and got worse over time, i was sick of looking at it and ended up buying a whole other dash from Crossroads auto dismantelers AKA where 4runners go to die.
Old 02-09-2012, 05:44 AM #6
Zachpins34's Avatar
Zachpins34 Zachpins34 is offline
Real Name: Zach
Zachpins34 is on a distinguished road
Zachpins34's Avatar
Real Name: Zach
Looks good and nice work. Have any pics of the gauges w/ the white LEDs?
My Build Thread
1999 Highlander Edition w/ Factory E-Locker: Alarm/remote start, FN 5 star wheels, 285/75/16 Duratracs, King 2.4 Ext Travel C/Os, LC shocks/8 wraps, 1" Diff drop, Airaid Intake, Dual B&M 70264's, Satoshi grille, 01 Tails, shackles, Rear diff breather extension, Blue wire mod,Taco whip antenna, Window tint, Bi-xenon Morimoto Mini Stage III projectors, 231mm Tundra Brake Upgrade, Interior LEDs.
Zachpins34 is offline   Reply With QuoteReply With Quote
Old 02-09-2012, 01:17 PM #7
Hepar's Avatar
Hepar Hepar is offline
Hepar is a jewel in the rough Hepar is a jewel in the rough Hepar is a jewel in the rough Hepar is a jewel in the rough
Hepar's Avatar
Looking good. Always loved that color.
2001 4Runner 4WD Sport Package, Millennium silver, 110,000 miles, 2nd gen TRD Supercharger, Toytec BOSS coilovers, 890 OME rear springs, Bilstein 5125 rear shocks, custom Baldlands front bumper, PIAA 520 driving lights and fogs, 4x Innovation Sliders (welded on!), 18" Magnaflow muffler, JDM corners, 65" Thule bars, 20% tint, 16x8 FJ80 wheels on 265/75-16 Duratracs, Husky mats w/ cargo, rear diff breather mod, 3M clear bra, remote start, Pioneer AVIC-8200NEX
Hepar is offline   Reply With QuoteReply With Quote
Old 02-09-2012, 02:25 PM #8
JadatheRottweiler's Avatar
JadatheRottweiler JadatheRottweiler is offline
JadatheRottweiler is on a distinguished road
great deals on CL....I like your progression
JadatheRottweiler is offline   Reply With QuoteReply With Quote
Old 02-10-2012, 02:20 AM #9
Suprareal's Avatar
Suprareal's Avatar
updated! check again
Old 02-10-2012, 03:42 AM #10
Zachpins34's Avatar
Real Name: Zach
Zachpins34's Avatar
Real Name: Zach
Damn they look sick! That's what I plan on doing next. I dont see any hot spots either. where did you order the bulbs? v-leds?
My Build Thread
Old 02-10-2012, 04:45 AM #11
Suprareal's Avatar
Suprareal's Avatar
on ebay i have this style eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices i tried a couple different ones and these worked the best. i did use a small piece of foil as a deflector across the front 2 leds just to dim them down a little
Old 02-10-2012, 04:53 AM #12
Zachpins34's Avatar
Real Name: Zach
Zachpins34's Avatar
Real Name: Zach
sweet thanks dude. Your gauges look sick, I think Im gonna go with white leds for the whole interior.
My Build Thread
Old 02-10-2012, 05:05 AM #13
Suprareal's Avatar
Suprareal's Avatar
ive wanted to do that but other things have been coming first, post up some pictures if you do !
Old 02-10-2012, 09:49 PM #14
tony2no's Avatar
tony2no tony2no is offline
tony2no is on a distinguished road
tony2no's Avatar
Is this a 4cyl?
tony2no is offline   Reply With QuoteReply With Quote
Old 02-10-2012, 11:25 PM #15
Suprareal's Avatar
Suprareal's Avatar
Originally Posted by tony2no View Post
Is this a 4cyl?
yes sir
E-Man's build thread E-Man 4th Gen T4Rs 5 09-05-2011 08:55 PM
Build thread?? Presta24 General Discussions 1 02-09-2011 09:31 PM
