Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Old 02-17-2012, 04:15 PM #46
Baja Runner's Avatar
Baja Runner Baja Runner is offline
Baja Runner is on a distinguished road
Wow! Nice photo!
2005 Limited V8 4x4 4Runner
2005 SR5 V8 4Runner
1997 40th Anniversary FZJ80
2001 Ford F350 w/ FWC Hawk
Baja Runner is offline   Reply With QuoteReply With Quote
Old 02-18-2012, 03:42 AM #47
Jon's Avatar
Jon Jon is offline
Jon is on a distinguished road
Jon Jon is offline
Jon's Avatar
35x12.50R17 Pibull Rockers, love em! I threw in the new Camburg UCAs so now that they clear I can start pounding/cutting sheet metal.
And the first attack with the jigsaw and sledge. Gonna continue the black to follow the old lines and the use either the 3M coating or maybe Monsterliner.
(SOLD and missed) TRD S/C'd/5spd trans swap/locked w/4.88s/on board air/Toytec 3.5"front/Superfex springst+1.5" spacers rear/35x12.50R17 Pitbull Rockers/AOR tube bumper/XRC8 Winch/custom snorkel/6000K HID Heads/18" LED light bar/Herculined floors and lots of stickers for added horse power
Build Thread
Jon is offline   Reply With QuoteReply With Quote
Old 02-23-2012, 01:33 PM #48
fire931 fire931 is offline
fire931 is on a distinguished road
Quick question for you guys running 35's...
What did you do with the washer fluid tank to prevent rubbing on it? Mind hits towards the bottom of it pretty good, I tried just removing the pump but it still contacts the tank as well. Ideas??
fire931 is offline   Reply With QuoteReply With Quote
Old 02-23-2012, 07:34 PM #49
TFJ-4runner's Avatar
TFJ-4runner TFJ-4runner is offline
TFJ-4runner is on a distinguished road
Got a pic of where its hitting? I dont have this problem, whats your back spacing and such?
Project LEXUS GX470 Build 6
/Radflo 2.5 Full Suspension Extended Travel ~ All Pro 3.5" Springs ~ SPC UCA ~ SCS SR8 Wheels ~ Metal Tech Rear Spring Isolators\
Daily Driver/Weekend Warrior
TFJ-4runner is offline   Reply With QuoteReply With Quote
Old 02-23-2012, 07:35 PM #50
Can't wait to take it wheeling Saturday with the 35's
Old 02-23-2012, 08:51 PM #51
No pic. It hits down on the bottom outside corner near where the pump mounts. Running stock 5 star's with 1.25" spacer.
Old 02-24-2012, 12:45 PM #52
Bandit Runner's Avatar
Bandit Runner Bandit Runner is offline
Bandit Runner is a jewel in the rough Bandit Runner is a jewel in the rough Bandit Runner is a jewel in the rough
I haven't had this problem either. Maybe my 1.5" body lift makes the difference?
Jon & T4J-4runner: Nice pics.
Glad to see this thread is still alive.
Bandit Runner, 2021 TRD Off Road Premium
Build Thread: https://www.toyota-4runner.org/5th-g...ild-2-0-a.html
Bandit Runner is offline   Reply With QuoteReply With Quote
Old 02-24-2012, 02:06 PM #53
J-money$$$'s Avatar
J-money$$$ J-money$$$ is offline
J-money$$$ is on a distinguished road
J-money$$$'s Avatar
I had to take the washer tank off. My 35's were just going to rip it off. So no window spray anymore. I just dump a water bottle on the window and use the wipers.
check out my build thread My Build
J-money$$$ is offline   Reply With QuoteReply With Quote
Old 02-24-2012, 04:27 PM #54
Dirtco's Avatar
Dirtco Dirtco is offline
Real Name: Jeremiah
Dirtco is a name known to all Dirtco is a name known to all Dirtco is a name known to all Dirtco is a name known to all Dirtco is a name known to all Dirtco is a name known to all
Dirtco's Avatar
Real Name: Jeremiah
I removed mine too, there was no way it was going to clear the tires. I have an aftermarket P/S fluid reservoir that I'm going to use with an inline pump. My 4Runner is my daily driver, and we get a lot of snow, so I need something. It will not hold as much as the stock unit, but it should be enough to get me where I'm going without stopping half a dozen times.
Dirtco is offline   Reply With QuoteReply With Quote
Old 02-24-2012, 05:21 PM #55
brian2sun's Avatar
brian2sun brian2sun is offline
brian2sun has a spectacular aura about brian2sun has a spectacular aura about
brian2sun's Avatar
I only had to remove the pump for the rear window sprayer, but I was able to keep the fluid reservoir and the front pump and I don't have any rubbing there anymore. I just plugged the hole for the rear pump with a wine cork.
I have the 315 Cooper STTs (they run 34.5" tall and 11.75" wide at 30 psi - as J-money$$$ mentioned earlier). I also have a 1" BL, stock 5 star wheels, and 1" wheel spacers. I do rub on the frame when fully turned, but it isn't that bad. There isn't much I can do about it anyways. I also rub the UCAs when it's fully drooped and turning, but it just wipes the dirt off, no big deal either. But... that's all after I cut my fenders back ~1" and pounded the firewall back about 1.5". That's my 315 MTR spare in this pic BTW. The old MTRs run the same size as my Cooper STTs. The new MTR Kevlars (like J-money$$$ and Dirtco have) are about .5" taller and .5" wider..
After trimming about 2" off the back of the inner lip on each rear fender, the only thing I rubbed in the rear was the gas filler tube cover (in the D/S wheel well). That is until it got torn off during the last wheelin trip. No rubbing anymore. I also extended my rear bump stops 1.5". I cut a 3" rubber mallet in 1/2 and used the 2 halves as spacers..
Here's some more pics...
1997 4Runner 4x4 SR5 - Geared, Locked & Armored
**CLICK FOR '97 BUILD THREAD**
2021 Tacoma 4x4 TRD Off Road Double Cab Short Bed (my DD)
2017 4Runner 4x4 Limited (the wife’s)
brian2sun is offline   Reply With QuoteReply With Quote
Old 02-24-2012, 07:36 PM #56
City_Rider City_Rider is offline
Banned
City_Rider is on a distinguished road
Banned
You are gonna have to do a write up this - I am rubbing my 33" tires on my reservoir too. I think they clear with my body lift in but when I get 35"s they certainly won't.
The black plastic covering mine is pretty shredded... Living where there is snow and lots of road grime I can't live without a wiper reservoir.
City_Rider is offline   Reply With QuoteReply With Quote
Old 02-24-2012, 08:40 PM #57
Yea I figured I would have to start looking around for something a bit smaller. Only thing I want to try first is to heat it and see if I can kind of remold that bottom corner where it rubs. Anyways, got the lift and tires on today!!!
Old 04-03-2012, 06:13 PM #58
runner38's Avatar
runner38 runner38 is offline
runner38 is on a distinguished road
runner38's Avatar
I have a 96 runner with 38 inch boggers on it.can't figure out how to put a pic up.
runner38 is offline   Reply With QuoteReply With Quote
Old 04-03-2012, 06:20 PM #59
4Running Daily's Avatar
4Running Daily 4Running Daily is offline
Real Name: Connor
4Running Daily will become famous soon enough
Real Name: Connor
Click advanced then click the paper clip.
1996 Toyota 4Runner 4x4 w/ 5 speed- Lifted, Locked,Painted,Armored
Build: http://www.toyota-4runner.org/3rd-ge...ld-thread.html
Originally Posted by invisible4Runner View Post
Highlander = minivan, purses, soccer practice
4Runner = testosterone, steak, dirt
4Running Daily is offline   Reply With QuoteReply With Quote
Old 04-03-2012, 06:51 PM #60
runner38's Avatar
runner38's Avatar
Can I put a pic on using a Droid? I'm new to this.
mall crawling , small tires
Official Wheel Paint Thread cj80cruiser 3rd gen T4Rs 257 10-27-2020 08:46 PM
The Official Build Thread kregg 3rd gen T4Rs 228 05-03-2020 12:27 AM
my official intro (new to 4runners) bent77 3rd gen T4Rs 2 09-30-2011 10:41 PM
Official Carnage Pics Thread Jesse1983 5th gen T4Rs 84 05-01-2011 04:39 PM
**Official MD/VA/WV/DC T4R Sighting Thread!** md4runner Maryland / Virginia / WV / D.C. 9 03-13-2007 10:05 PM
