Old 02-14-2012, 10:39 AM #1
bgravy bgravy is offline
bgravy is on a distinguished road
Should I change transmission fluid or not?
Hello everyone,
This is my first post and my question is should I change my transmission fluid or just leave it. I have a 2002 4runner Sr5 w/ 3.4L 2wd. I bought the truck with 146k miles and now have 185k mi and I'm not sure about the service history of the tranny. I feel that overall the truck was well maintained and there are not any issues with the tranny at this point. I used my 4runner for boat towing last summer (3900lbs) and will be again this summer and want this runner to last. I contacted multiple dealerships and got multiple answers... 1) don't change it. 2) do a drain/fill. 3) Flush the whole thing. Can anyone help? Thanks in advance
bgravy is offline   Reply With QuoteReply With Quote
Old 02-14-2012, 10:46 AM #2
DC runner DC runner is offline
DC runner is on a distinguished road
Yes. I forget what the service recommendation is, but it is usually 25k or 35k and always shorter if you tow.
Your auto transmission is easily the most expensive and important part of your car, either equal to or right behind the engine. You would never
"not change your engine oil" for fear of hurting it.
It goes like this: Changing fluid on a good, healthy transmission will ONLY help it last longer. And 2nd, changing fluid will only hurt a already zombie transmission that is close to death. It may speed it up, but it didn't cause it.
You get a lot of people who fear changing their fluid because they know their transmission is dead and the only think keeping it going is the sheer grit of metal shavings in the fluid. They know it is bad.. that transmission slips horribly and gives off all kinds of warnings. In this situation, if you are broke and cannot afford at the moment an expensive tranny repair.. sure, drive on.
Hope that helps.
DC runner is offline   Reply With QuoteReply With Quote
Old 02-14-2012, 10:46 AM #3
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
I like to drain and fill. You are only changing 30% of the fluid so it won't affect much either good or bad. It's just matainance. Do it again in 6 months or next year.
Doing nothing is not a good idea and people have concerns about the flush. I personally think you'd be fine with a flush too. However, you can't argue with a simple drain and fill, it's just a good safe idea.
I use Mobil 1 and have nearly 100% synthetic in my trans. You can use a synthetic or just get regular Dextron III.
You do not need to drop the pan or mess with the filter at all.
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 02-14-2012, 10:47 AM #4
IanB's Avatar
IanB IanB is offline
IanB has a spectacular aura about IanB has a spectacular aura about IanB has a spectacular aura about
IanB's Avatar
Do a drain and fill a couple of weekends in a row, that will get the majority of the old fluid out, and you should be good to go. Get a new crush washer for the drain plug on the tranny.
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
IanB is offline   Reply With QuoteReply With Quote
Old 02-14-2012, 10:48 AM #5
Yea. Second that. It sounds very healthy and I wouldn't worry about a fluid exchange or even a flush, but if you really ARE worried; then do a few drain and fills.
Just make sure you pop the pan down and take a look and replace the filter with OEM. There is a thread in here about the crappy quality of NON OEM filters. So, go REAL and get one from Toyota.
Old 02-14-2012, 10:55 AM #6
HCurphy's Avatar
HCurphy HCurphy is offline
HCurphy is on a distinguished road
HCurphy's Avatar
I wouldn't worry about the filter as much, it is a good idea but these transmissions don't have "filters". They have a metal screen.
If I were you I would do drain and fills at every oil change until the ATF is nice and deep red then just do drain a fills every other, or every third oil change. This is how I treat my tranny and she treats me pretty well in return.
side note: 270k faithful miles and my tranny doesn't miss a beat.
'96 SR5 2wd 275k miles
TBU 231's-Brembo Rotors, '99 Tall coils, Billsteind HD 4600 series, FJ Cruiser 17", 265/70/R17 Terra Grapplers [ all original other then tune-ups, oil changes, front o2, u-joints, and axle seals ]
HCurphy is offline   Reply With QuoteReply With Quote
Old 02-14-2012, 11:39 AM #7
Excellent! I can't thank you all enough for the input, you guys are great. I'm going to go with a drain and fill and change the rear diff. fluid in the near future.
Old 02-14-2012, 11:51 AM #8
IanB's Avatar
IanB's Avatar
Change the front diff and transfer case fluid while you're at it, and always remember to loosen the FILL plug before the drain plug. And grease your driveshaft.
Old 02-14-2012, 12:30 PM #9
the great him's Avatar
the great him the great him is offline
Real Name: Isaac
the great him is a name known to all the great him is a name known to all the great him is a name known to all the great him is a name known to all the great him is a name known to all the great him is a name known to all
Real Name: Isaac
The OP is only 2wd Ian... So no transfer case or front diff
if a*sholes could fly this place would be an airport -2004 GX470 spm -97 SR5 3.4, SCS Stealth 6's w/305 70 17s MTRs, Icon 2.5" RR w/700#coils, OME861s w/Icon tacoma 2.0 RR, ARBs w/nitro 4.88, PIAA LED lights, 170amp CS144, ARB snorkel, ARB bumper w/xd9000ce, CBI swingout loaded, BudBuilt skids, lil skip tank skid, sliders, LCE 231s(d&s), first gen roll bar mod, LED interior/dash lighting, B&M 70624+perma cool w/electric fan, dual electric fanshttp://www.toyota-4runner.org/3rd-ge...ld-thread.html
http://www.metaltech4x4.com/
the great him is offline   Reply With QuoteReply With Quote
Old 02-14-2012, 12:40 PM #10
TX4Running's Avatar
TX4Running TX4Running is offline
TX4Running is on a distinguished road
TX4Running's Avatar
Which type of ATF?
Which type of ATF do you guys recommend? Also, how often does the crush washer need replaced and where to get one? Only at Toyota dealer? I've seen crush washers at auto parts stores but question the quality. I need to start draining and filling just as the OP and want to get what's best for my truck. Thanks.
TX4Running is offline   Reply With QuoteReply With Quote
Old 02-14-2012, 01:05 PM #11
IanB's Avatar
IanB's Avatar
I must have missed that, lol!
The crush washers are cheap, buy a dozen and have them on hand forever, costs you a couple bucks. Replace them anytime you remove the drain plug, they are designed to be single use, quality is not a concern IMO. Tranny fluid is Dextron III for these trucks I believe, but your tranny dipstick will say on it as well.
Old 02-14-2012, 01:25 PM #12
HCurphy's Avatar
HCurphy's Avatar
no greasing of the drive shaft either for the 2wd'ers...unless they rebuilt at some point with greasable u joints.
Old 02-14-2012, 01:40 PM #13
IanB's Avatar
IanB's Avatar
Well then...disregard much of what I've said here then, lol. Thanks for keeping me on my toes guys!
Old 02-14-2012, 01:43 PM #14
HCurphy's Avatar
HCurphy's Avatar
Will forgive you, Ian. But just this time. More mistakes like this and I think will have to bring down the BANHAMMER.
Seriously though, it makes no ****ing sense not to have greasable u joints. So, I don't know why you would have known that particular tidbit.
Old 02-14-2012, 01:55 PM #15
IanB's Avatar
IanB's Avatar
Ya, no kidding! I have no personal experience with 2wd or any of the gas engines for these things, but I like to help out where I can.
Transmission fluid change @ 60K? alaskaman 4th Gen T4Rs 21 11-12-2011 09:43 AM
transmission fluid change The Wanderer Maintenance/Detailing 10 10-06-2010 09:16 PM
transmission fluid change? meooem1 4th Gen T4Rs 8 01-11-2009 01:20 PM
Transmission Fluid Change help faxmachine Maintenance/Detailing 1 11-12-2008 07:26 PM
Transmission fluid change on an 04? SR5XM Maintenance/Detailing 3 10-01-2008 06:53 PM
