Originally Posted by PitbullRescuer
Are you sure it's not a CV joint going out?
I didn't think so since the axles aren't turning with the manual hubs and they have only seen road miles since I put them on last year. No leaks there either. I'll look again today.
Originally Posted by JayRolla
Double then triple check the ball joints. If they where replaced with oems you should be fine but if not they are most likely the issue. Get your finger into the grove of the ball joint boot and see if there are any rips at all. I have had this issue on many different vehicles.
OEM ball joints and TREs. No obvious leaks there either but I'll get under there again today to give a closer look.
Thanks guys. Anyone else have some thoughts?
