02-20-2012, 11:03 PM
Last suspension question I promise!! Front strut bolts?
2001 4runner SR5 / 170KM / Bilstein 5100 with stock coils & OME906 / toyo 265/76/16 / 1.25" spidertrax
1997 S/C 4runner / 276km / 3" OME lift / 285-75-16 duratracs / rock crawler's
SOLD
1999 limited 4runner / 255km / 4" LC lift / 285-75-16 pro comps / and a million dollars in mods
SOLD
02-20-2012, 11:09 PM
Are they going to fall out? Doubtful.
Should you replace them? I would.
You don't need to go to the dealer to get replacements. Take a bolt to a good hardware store, they should have a replacement. The bolt head should have a number on it (like 10.9). This is the class of bolt (strength). Don't get a lower number. Make sure the nuts are the same class too.
2000 4runner Sport, SAS/4wheel Underground 3 link, Diamond axle, 14" Radflo coilovers, double locked, Custom rear 3 link, 12" Fox shocks, full armor Gerdo's Build Thread
Real Fuel Tank Skidplates for sale Lil' Skip's OffRoad
Rear control arm mount skids and Hi-Lift adapter for sale Lotus Development
02-20-2012, 11:14 PM
Okay thanks. Any reason why they fit originally? Or why it looks like they weren't threaded any further but I believe we're flush against the mounting bracket when I took em off
SOLD
SOLD
02-20-2012, 11:16 PM
The nuts used to be where the shiny part was. You only have them tightened to the rusty part which was definitely exposed before. They must be cross threaded.
戦争イーグル
Cory J
Wheel converter,
You're looking at the pictures the wrong way bud. The clean threads that you're having trouble back onto are the ones that have been covered by the nut. They're not clean because they've been exposed to the elements all these years. Do it right, way too important not to.
02-20-2012, 11:17 PM
I have no idea why they aren't sucking up.
I have removed mine a dozen times and never had any issues. I have also done a half dozen other rigs, also without issues.
02-20-2012, 11:20 PM
You could either
A) Get new bolts
OR
B) Chase the threads on the bolts to try and clear the threads.
戦争イーグル
Cory J
Wheel converter,
02-20-2012, 11:24 PM
Real Name: Ervin
Real Name: Ervin
That lower shock bolt appear to be metric, now are you using the same for the nut? Did you have the shop redo the front strut/coil assembly?
97 4Runner SR5 TRDSC URD Yukon Camburg Toytec Trekmaster 4Crawler SonoranSteel Level8 Nitto SavageOff-Road ARB Smittybilt MasterPull Powertank SpiderTrax B&M Jaos Gobi Flowmaster Cobra Firestik Alpine CompuStar Hella PIAA RigidIndustries WeatherTech
my build http://www.toyota-4runner.org/3rd-ge...formation.html July 2012 T4RoTM / 2012 T4RoTY
02-21-2012, 12:00 AM
Originally Posted by cj80cruiser
You could either
A) Get new bolts
OR
^ This.
Once you buy a tap and die set, you'll be using it frequently.
02-21-2012, 12:12 AM
Any shiny part of the bolt was not exposed to the elements previously, you don't have that nut on as tight as it was before. I'm guessing it's cross threaded as well. Just get some new hardware and call it a day.
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
02-21-2012, 12:27 AM
hahaha ya woah sorry 12 hours working straight then coming home to this i had my north and south confused, yes thanks haha the bolt was to where it looks new hence its not dirty, okay i agree i am going to try and match the hardware at a specialty store otherwise the dealer.. could it have been having to bang them in and out? maybe it folded the thread.. i have the original nuts on there, and yep took the struts back and had them aligned up perfect, any advice on putting the panhard back in.. ive tried to majority of options out there.. should i connect the panhard before putting in the rear shocks? im trying the ratchet method next.. for the time being i dont have a panhard drop and need the truck back on the road!!
SOLD
SOLD
02-21-2012, 12:29 AM
I would say that Blckpgsr is on to something... are you using the right sized nut?
98' 3rd Gen. SR5 Dune Silver. Supercharged 3.4L. Camburg 2.5" coilovers. 890 old man emu rearcoils on 1.5" Daystar rear spacer w/ procomp 9000. K&N cone intake w/ flowmaster exhaust/ 255/85/R16
02-21-2012, 12:55 AM
It may not be neccessary but get a grade 8 bolt. Or if you wanted you could go to the dealership and pic up the hardware. No doubt the hardware store would be cheaper though.
戦争イーグル
Cory J
Wheel converter,
02-21-2012, 02:11 AM
You can get them at Toyota for cheap:
90170-14026 Nut $2
90105-14104 Bolt $7.60
I know this because I fubard the threads on one side of mine when I pounded it back in. You may have done the same. The picture tells me the nut is correct and on too far to be crossed.
But fix that pronto and torque to spec.
SOLD!99 SR5 V6 - SS 1.2 Lift, 1" BL, 231mm TBU, LTX M/S2s, Savage Sliders, Skids and Bumpers, Lots of LEDs, 70266 ATF Cooler with 5757 Gauge, Homemade Roof Rack, VHF & CBs, Various Off-Road Goodies '10 Trail Edition - WeatherBeaters, VentShades, Prodigy P3, TruCool 4589 ATF Cooler, E Rated LTX M/S2s, Booster Seats with a hint of kid puke '16 Tundra TRD SR5 - ATC Cap, AirLift Bags and WirelessAir Controller, Prodigy P3, LineX, E Rated Defender LTXs
02-21-2012, 02:23 AM
90170-14026 Nut $2
Yeah, you're probably right about that nut being too far on to be cross threaded. I bought those bolts and nuts from the dealer but please tell me I didn't spend that much .....You can get a grade 8 from a bolt store for a dollar or 2.
戦争イーグル
Cory J
Wheel converter,
