03-06-2012, 08:55 PM
Real Name: Phil
Real Name: Phil
Marker and corner lights suddenly not working
So I just noticed a few minutes ago that my front marker and corner lights are not working. All four of them are out. I have no idea why. No recent changes, other than my headlight housing. Didnt change the bulbs though. I mean I changed them about two months ago. But all I changed last week were the actual headlight housing assemblys. So what would have caused this, just a fuse?
267/75/17 Cooper ATs - Level 8ZX wheels matte black - EBC rotors/ pads - 99 coils/ Bilstein 5100s - deckplate - Sotashi/custom emblem - Hella micro DE fogs - Kenwood/Alpine/Infinity system - sound deadened interior - color matched bumpers - LED tails - Safari LTD rack - Husky floor liners - clear corners
03-06-2012, 09:04 PM
Real Name: Phil
Real Name: Phil
By the way which of these are the front marker and corner light fuses? Im guessing the two 10A left and right Head fuses are the marker lights, but which are the corner lights?
03-07-2012, 02:35 PM
Real Name: Phil
Real Name: Phil
Somebody wanna help me out with this? I checked all my fuses and they all look good
03-07-2012, 03:20 PM
Do the running lights in the tails still work? Turn signals?
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
03-07-2012, 04:08 PM
The front parking lights run off the TAIL fuse and the TAIL relay (at least on 2002's with no running lights--that diagram has always been right on for my '99.)
http://www.ncttora.com/fsm/1996/SIL/...emci/024tl.pdf
So yeah, check your tails.
My Backyard Frame Swap
03-07-2012, 04:29 PM
Start pulling the relays, something could have been tripped.
03-07-2012, 04:39 PM
Real Name: Phil
Real Name: Phil
Alright, so everything works except for my front corner lights. I was mistaken about the front bumper lights. For some reason I thought they were always on. But they are only the turn signals, and they work fine. So I just dont have the corner lights. I'll be honest, I know nothing about lighting, wiring, relay, etc, so when I look at those diagrams without anyone to explain them I just get confused.
Anyways, everything on the tails work as well. So the 98 must be different than 99+. So any other ideas?
03-07-2012, 04:41 PM
If its just the corner lights that aren't working, I'd start by going back over your headlight swap, and make sure all the wiring harnesses in that area are connected tightly, no wires pinched, etc. Grab some new bulbs and make sure they didn't just burn out (maybe you shorted something while working on the headlights and popped them?).
03-07-2012, 05:48 PM
The '98 parking lights are also on the TAIL fuse according to the Owner's manual. I'm posting the page, but it usually does not work. Here is the link: https://docs.google.com/viewer?a=v&p...OTlhOWY1NjQ3Mg It's on p.245.
...so it's not a fuse. I doubt it is a relay, as something else would not work if it were. Number 1 suspect is two bad bulbs. Try a good one on both sides and report back.
01-15-2013, 10:06 PM
Were you ever able to figure this out? I have a 2000 and am having the same problem...fuses look good, bulbs are not blown and no lights?!
01-16-2013, 12:14 AM
I have the same problem
SOLD Red 98 SR5 - 400k miles
NEW Super white 2015 SR5 4WD 20" MOTO METAL wheels, Nitto Grapplers, TRD grill, hidden features mod, MESO LED 2-color cabin light, rubber mats & animal bars COMING SOON: VIOFO A139 front/rear camera hardwire install, new headunit, speaker & tweeter upgrade.
10-16-2015, 05:55 PM
Sorry for necro bump. Same problem. Anyone fixed this? I had no clue mine were out until I put in clear corners and they didn't turn on lol
2001 Toyota 4Runner SR5 Sport
Imperial Jade Mica
231mm Tundra Brakes
5100 Bilstein / TRD / OME 890 3" Lift
285/75/16 BFG KO2s
10-16-2015, 06:22 PM
Did you try new bulbs? Preferably ones that you can test and see light up making them "Known good."
10-16-2015, 08:15 PM
Real Name: Phil
Real Name: Phil
For me it ended up being the trailer wiring. Some of my wire housing had melted and the wires were touching.
