Originally Posted by ryhi
try putting the bulb in the other way (rotating it 180 degrees).
Isn't the good old 1156 a single contact bayonet bulb?
If it is, rotating it will not change the polarity. Tip and base will still connect the same way. Assuming the issue is polarity, you would need to reverse the plug that goes to the socket, if that is possible, or swap the wires before the plug (cut and splice). I have a '99 so I can't be sure on this.
On an 1156, tip should be positive and base should be negative (ground). I would assume all LED's are made that way too. I would take a test light from chassis ground to the socket and it should light when you touch the tip contact. Then connect to 12v+ (at the battery or elsewhere) and see if it lights when you touch the body of the socket (base contact). I bet it fails this test. Either polarity is reversed, or one of tip or base is not getting hot or ground, respectively.
EDIT: thekid snuck in front of me while I was typing. Yeah, what he said^^^^
My Backyard Frame Swap
