Old 03-16-2012, 05:34 PM #1
004runnerLtd's Avatar
004runnerLtd 004runnerLtd is offline
004runnerLtd is on a distinguished road
Fuel Gauge Reading Inaccurately
I tried searching through the forums, but only came across people having fuel pump issues, not necessarily fuel gauge issues.
So as the title says, my fuel gauge reads inaccurately.
After 15-25 miles, I'll already be at 3/4 tank after a fill up.
When I get to a quarter tank of gas, that's when I like to fill up. But I'm only putting 9-10 gallons in, out of a 18.5 gallon tank. To me, it should be reading more like 1/3 of gas left.
I talked to my mechanic, and he said a new fuel pump would cost me $700-800.
Any suggestions?
Is a new fuel pump what's needed?
I've done some research, and it seems some aftermarket ones make buzzing noises?
2000 Toyota 4Runner Limited, White/Silver
Tundra TRD Coils/Bilstein 5100 adjustables (front) -- OME 906s w/ Tundra 5100s (rear) -- Tundra 'Big Brake' Upgrade -- FJ Cruiser Wheels (265/70R17) -- Sound deadened/barrier -- Deck Plate Mod
004runnerLtd is offline   Reply With QuoteReply With Quote
Old 03-16-2012, 06:15 PM #2
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
I'm having the same issue. I was on E but when I filled up I was only able to put 12 or so gallons in. I know that's not right! I don't drive the truck that much but having an accurate gas gauge is pretty important on long trips.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 03-16-2012, 07:00 PM #3
Mano1124's Avatar
Mano1124 Mano1124 is offline
Real Name: Manolo Rodriguez
Mano1124 is on a distinguished road
Mano1124's Avatar
There's a bulletin about inaccuracy fuel gauge.
http://www.google.com/url?sa=t&sourc...HXygstKNMGI7rw
Mano1124 is offline   Reply With QuoteReply With Quote
Old 03-16-2012, 07:44 PM #4
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
It is the gauge. Welcome to the party.
The pump replacement sounds a little steep, but for a dealer fix for the gauge, the number is about the norm.
I'd suggest investing in a Scangauge II for $160 for a true gas reading and much more.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 03-16-2012, 09:24 PM #5
PitbullRescuer's Avatar
PitbullRescuer PitbullRescuer is offline
PitbullRescuer is on a distinguished road
You didn't search hard enough. There are numerous threads about how notoriously bad the gas gauges are in 3rd Gens. Just figure out your average MPG and then reset the trip at every fill up.
'98 SR5 4x4, cheap DD http://www.toyota-4runner.org/3rd-ge...im-addict.html '99 SR5 Highlander 4x4/5 Speed... http://www.toyota-4runner.org/3rd-ge...eed-build.html '97 SR5 4x4/5 speed, another new project... http://www.toyota-4runner.org/3rd-ge...new-build.html '00 SR5 4x4, new project, stay tuned... http://www.toyota-4runner.org/3rd-ge...ld-thread.html '97 Limited 4x4, freshened up quite a bit... http://www.toyota-4runner.org/3rd-ge...d-3rd-gen.html '99 SR5 Highlander 4x4... http://www.toyota-4runner.org/3rd-ge...ce-thread.html
PitbullRescuer is offline   Reply With QuoteReply With Quote
Old 03-17-2012, 01:32 PM #6
Full_Throttle's Avatar
Full_Throttle Full_Throttle is offline
Full_Throttle is on a distinguished road
can the scangauge really give fuel level? COOL! I will have to go check it out. is it a built in code or do you have to add it in?
Full_Throttle is offline   Reply With QuoteReply With Quote
Old 03-19-2012, 01:13 PM #7
Martinjmpr's Avatar
Martinjmpr Martinjmpr is offline
Martinjmpr will become famous soon enough
Martinjmpr's Avatar
It doesn't give you the fuel level but it can estimate the amount of fuel remaining and calculate a Distance-to-Empty (DTE.) I run an ultra-gauge for now (Scangague will be here this week) and it does the same thing.
The way it works is like this: Your OBD computer can monitor fuel flow. Once you input a bunch of data into your Scangauge (calibrate distance using a GPS, calibrate fuel consumption based on a couple of tanks, input tank size) the gauge can then give you an estimate of how much fuel remains given your current MPG and thus your approximate DTE.
You can re-calibrate at every fill up but I have found that mine is pretty accurate. For example, yesterday after a weekend trip pulling the teardrop trailer in heavy winds, my average MPG calculated at 15.1. The DTE showed 78 miles to empty. Doing basic math would mean that at that point I had almost exactly 5 gallons left in the tank (78 miles / 15.1 MPG = 5.16 gallons left in the tank) which would mean that I should fill up with right at 13.5 gallons.
Filled up the tank and it took 13.56 gallons. So pretty darn accurate, I'd say. I normally never let it get below 30 miles DTE and really I like to fill up when it's around 50 miles DTE. At 17.5 mpg average that means I'm filling up with roughly 2.5 gallons in the tank, putting in about 15.8 to 16.1.
Martin AKA Zapp Branigan - No longer a 4runner owner!
Martinjmpr is offline   Reply With QuoteReply With Quote
imposible to fix floater gas gauge error reading in 4runner 99 jakov 3rd gen T4Rs 18 08-26-2017 11:23 AM
Outside temp gauge not reading right bgravy 3rd gen T4Rs 3 03-02-2012 06:33 PM
engine temp gauge reading The 0ther Asian Classic T4Rs 4 01-02-2011 02:46 AM
fuel gauge 03vrod Classic T4Rs 5 11-06-2009 01:17 AM
Temp Gauge Reading bohemian 3rd gen T4Rs 6 08-19-2009 02:32 PM
