Originally Posted by Endlessblockades
My VIN is in the affected range. It is still a little unnerving when the fuel gauge shows Empty and the light is on and your UltraGauge shows 2 gallons and you have it set to 16.5 max level because you read here the there are 2 unreachable gallons in the 18.5 tank.......
I don't let it get that low because of the nagging concern......
Dude, my 4Runner completely faked me out once because of this. Mine does the same thing, light on means I have about 4-5 gallons left. I started getting too complacent about it and let it run past E on the gauge knowing that I had about 100 mile range left in the tank. One day as I was thinking about getting gas soon the needle drops, and I mean DROPS and pegs at the bottom all the way as far as it goes. I immediately exit the highway and head for the closest gas station. As I enter the driveway the engine shuts off and I roll up to the pump with absolutely no gas left!
Ever since then I reset the trip odometer after every fill up to make sure I never do that again. I use the odometer to tell me when I need gas, not the gauge.
