Old 03-29-2012, 01:33 PM #1
Stallion Motors Stallion Motors is offline
Stallion Motors is on a distinguished road
1997 4wd light flashing/beeping
Hello everyone, this is my first of many posts about our new to us 1997 4runner limited. On our test drive the previous owner said 4wd works great, hit the button while going 50-55, and it engaged and the dash light came on like it should. Today I was driving and figured I would do the same drill, nothing happened. On the freeway at 65mph, i tried again and the dash light began to flash and beep and would not shut off unless I took it out of 4wd. The lever I have is 4lo-n-4hi only. The lever is pulled back as far as I can get it. Thoughts? Broken?
Thanks in advance,
Tom
Stallion Motors is offline   Reply With QuoteReply With Quote
Old 03-29-2012, 01:39 PM #2
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
Does it work as it should when going slower, say 40mph?
65mph may be too fast for the 4runner to engage 4wd.
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 03-29-2012, 01:44 PM #3
40mph, 4wd button depressed, and the dash light will not come on, making me think it isn't engaged.
Tom
Old 03-29-2012, 07:26 PM #4
I've read all other similar posts, some of them mention a faulty actuator, any ideas what I'm looking for?
Old 03-30-2012, 10:28 AM #5
Anybody have any thoughts on this? I really don't want to take my new runner to the dealership. I still have no 4wd light, Eeek!
Old 03-30-2012, 11:39 AM #6
opie74 opie74 is offline
opie74 is on a distinguished road
Sitting in your driveway or parking spot, turn the key on so everything comes on but do not start the motor. Push the 4wd button and you should hear things happening under your runner. From there, you will need to find out if everything is working or only a few things are working correctly.
If you hear no sounds, youve got issues.
opie74 is offline   Reply With QuoteReply With Quote
Old 03-30-2012, 01:31 PM #7
Thanks. I will try as soon as I get home and report back.
Tom
Old 03-30-2012, 04:10 PM #8
Key turned, engine off, 4wd button depressed I hear nothing. Zero, zilch, nada.
Old 05-23-2012, 04:27 PM #9
Grenvilleter Grenvilleter is offline
Grenvilleter is on a distinguished road
I'm really hoping to find out more regarding this and similar issues. I just procured a '97 4R and the 4x4 fails to engage. I, however, get a click happening on the actuator but transfer case does not actually engage.
I'm hoping it is just stiff from lack of use however, I am uncertain how to go about freeing it up so it works properly if indeed this is the problem. No light happens on the dashboard and as mentioned, a little click happens on the solonoid mounted on the transfer case but no 4WD happening.
Anyone have any hints on what to check for first ?
Thanks,
Terry
Grenvilleter is offline   Reply With QuoteReply With Quote
Old 05-23-2012, 07:53 PM #10
I followed the all data directions to test the 4wd. It was a pain, but basically you jump the switch and force it to engage into 4wd. After everything tested fine I put it back together and now i test it once a month.
Tom
A/C light flashing?? webshot Problems & Warranty Issues 138 07-26-2020 11:37 AM
Check engine light, slip indicator light & flashing 4 Lo light croat5280 5th gen T4Rs 19 06-11-2020 05:16 PM
Flashing A/C light 4everunner 5th gen T4Rs 8 01-15-2012 11:40 PM
Flashing Key Light, What does it mean? vn_aviator Maintenance/Detailing 21 01-25-2008 12:30 AM
Flashing A\C Light fix a77boy Problems & Warranty Issues 0 03-14-2007 10:34 PM
