Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 11-13-2019, 02:52 PM #436
T4R3G T4R3G is offline
T4R3G is on a distinguished road
Nice!
Originally Posted by 406LOVE View Post
New wheels and tires
265 70 17
Bilstein 5100 w/tundra coils front
Bilstein 5100 w/OME 890
Spidertrax 1.25" Spacers
Yes they rub slightly. Considering removing spacers or trim the well and flattening the pinch weld.
You have a sweet looking rig! I'm thinking of installing the same suspension as yours to get a mild lift.
T4R3G is offline   Reply With QuoteReply With Quote
Old 11-13-2019, 06:18 PM #437
Nice Rig
Originally Posted by Rpreme View Post
16" TRD FJ Trail Team's wrapped in 285/75/16 Falken Wildpeak AT3W's. More of my permanent set up for both on highway and trails..
That's a sweet ride. I like how you gave your wheels some contrast with the different color caps. I just ordered a set of the gunmetal ones. How do you like the ride comfort with that tire size. Also, I'm looking into upgrading to the Tundra brakes. Do you happen to have that done to your ride? I'd like to know if these wheels will clear the 231mm calipers without having to use spacers.
Mike
Old 11-15-2019, 12:54 PM #438
Rpreme Rpreme is offline
Rpreme will become famous soon enough
Mike
Thanks, I appreciate that. These wheels are now for sale and went back to my original set up.
As for the Tundra Brakes. They will fit these wheels no problem.
Here are a couple links from some members here.
https://www.google.com/search?newwin...4dUDCAs&uact=5
TRD Wheels with Tundra Brake Upgrade
Rpreme is offline   Reply With QuoteReply With Quote
Old 11-18-2019, 02:38 AM #439
henlybenderson's Avatar
henlybenderson henlybenderson is offline
Real Name: Ben
henlybenderson is on a distinguished road
Real Name: Ben
Just saying thanks, this made up my mind to just refinish my 5star wheels, graphite I think.
henlybenderson is offline   Reply With QuoteReply With Quote
Old 11-18-2019, 11:43 PM #440
ckhirnigs113 ckhirnigs113 is offline
ckhirnigs113 is on a distinguished road
I found a great deal on these 5th gen wheels locally. I also scored these practically new Michelin LTX M/S2 tires from a guy that took them off his 2019 Wrangler after a few hundred miles. He was selling all 5 tires for such a good price that I didn’t even mind they were a little narrower than I was looking for (245/75R15). I was coming from the tiny factory 15” wheels, so it’s a big improvement nonetheless.
OEM toyota wheel options/pics for 3rd gen 4runner *post em up*-c7364ced-6b9e-44d9-ab57-6e9e02122ddb-jpg  OEM toyota wheel options/pics for 3rd gen 4runner *post em up*-8d3991b3-b102-45b8-ba42-80220af6e8bf-jpeg
ckhirnigs113 is offline   Reply With QuoteReply With Quote
Old 11-19-2019, 12:43 AM #441
levee-11's Avatar
levee-11 levee-11 is offline
Real Name: Levi
levee-11 is on a distinguished road
levee-11's Avatar
Real Name: Levi
I have the stock 2000 4Runner rims on my 1998 4Runner, and you have probably head this a thousand times, but I plasti-dipped mine, and I love them. If you do a good job, you can not even tell they are plasti-dipped, and the rubber peals off so you protect your rim's paint from rocks and stuff when off roading.
levee-11 is offline   Reply With QuoteReply With Quote
Old 01-02-2020, 02:23 PM #442
chumso chumso is offline
chumso is on a distinguished road
Will TRD Pro 16" (PT7583517002) fit?
Hi All,
Thank you in advance for your assistance!!!
I need help seeing if these TRD wheels (PART# PT7583517002) for a 3rd GEN Tacoma would fit a 3rd GEN 1998 4Runner. Based on all the specs I don't see why the wheel won't fit but I've called multiple dealerships and they couldn't give me a definitive answer. The part fitment guides online says the TRD wheel are almost identical with the exception of the Tacoma having a hub center bore size of 106.1mm versus the 106mm that's on the 4runner. Will the .1mm cause issues? I have also found that some sites leave out the .1 when reporting the Tacoma bore size, so I'm wondering if that is also the case for the 4runner as the following site states the 4runner is 106.1mm Toyota 4Runner Bolt Pattern, Wheel Size, Lug Pattern and Rim Specs
Apologize ahead of time for the over-explanation. I just really want to know if the wheels will fit before ordering them.
The tires I have on now are BFGoodrich KO2 265/70R16.
The 3rd gen 4runner wheel specs are:
STOCK WHEEL SIZE: 7Jx16
OFFSET: 15MM
BOLT PATTERN: 6x139.7mm or 6x5.5"
THREAD SIZE: M12 x 1.5
CENTER BORE: 106mm or 106.1MM??
TRD Pro 16-In. Alloy Wheel - Gloss Black
Part Number: PT7583517002
Supersession(s): PT758-35170-02
WHEEL SIZE: 7Jx16
OFFSET: 13MM
CENTER BORE: 106.1mm
PT7583517002 - Trd pro 16-in. Alloy wheel - gloss black. Circle, caps, greater - Genuine Toyota Accessory
chumso is offline   Reply With QuoteReply With Quote
Old 01-03-2020, 01:39 AM #443
APhelps APhelps is offline
APhelps has a spectacular aura about APhelps has a spectacular aura about
Originally Posted by chumso View Post
Hi All,
OFFSET: 15MM
WHEEL SIZE: 7Jx16
OFFSET: 13MM
The TRD pro is a nice looking wheel but why waste your money on them? I can't understand why anyone would buy a 16x7 wheel when the factory wheel is that. I suppose if you never plan on upgrading tires or going past a 285/75/16.
A 265/70/16 should fit just fine on that. The offset is a minimal amount of difference or at least would seem to me. You could verify how much spacing you have though between the UCA and wheel.
APhelps is offline   Reply With QuoteReply With Quote
Old 01-03-2020, 11:11 AM #444
Hi APhelps,
Thank you for your response.
I am not the original owner and the factory wheels were replaced with some unmarked aftermarket wheels that were powder coated to hide corrosion. I just recently discovered the corrosion issue a few days ago when tire pressure on one wheel would go down to ~12 PSI over night, which was what my local shop told me after trying to repair the tire/wheel with some bead seal and was unsuccessful.
Why go with TRD, well... I like sticking to factory as much as possible. I love the classic but most factory wheels aren't available in black and I'm not familiar nor have any desire to have wheels painted/powder coated. I honestly don't mind the 16" wheels. I also checked TireRack but didn't find anything I liked. Now aftermarket rims on my supra makes sense.
Thanks again!!!
Old 01-03-2020, 11:36 AM #445
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
I run these ALY75189 Tacoma rims. They look to have the same spec as the pro’s.
When I was a younger wheeler we ran 15” rims and big tires with massive side walls. Those side walls were a part of the suspension and traction. Now days they sell trucks with 20” rims and low profile tires. I can’t imagine they are good off-road or on the backroads.
16” rims are plenty big to clear the rigging. After that I want side wall.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 01-03-2020, 12:48 PM #446
Thank you Dieselchessy!!! I checked Toyota's compatibility list and it also lists those ALY75189 are not compatible with our 3rd gen 4Runners, so this makes me believe that their compatibility database is incorrect in regards to not fitting and more of an issue with nobody bothered to enter compatibility data for our gen.
Your response makes me super happy. Thank you very much!!!
Old 01-03-2020, 01:07 PM #447
Page 29 of this thread post #424 dude has pics of the rims I run. Lots of folks run them on our 3rd gens.
No one told me they wouldn't fit, but then again I never asked.
Old 01-21-2020, 07:12 PM #448
Tha Krazy One Tha Krazy One is offline
Tha Krazy One is on a distinguished road
I wonder if anyone in this thread could help me. Just got an 02 SR5 this past weekend and has the stock 225/75/15" wheels on it. I looked at the sticker on the door and it had the option of 265/70/16 wheels as an option. I see most runners rocking stock 16's and a few with newer gen or Taco OE 17's. I don't plan on doing much play in the dirt or any heavy hauling with the truck. I would like to upgrade to 16's or 17's with some decent all season tires and if possible use OE rims. Most I see on this thread is beefier tires and raised. It's only a 4x2 so no need to raise it and off-road it out. It will be more for daily drive use or trips from the LA area to the Central Valley in CA so also some freeway use. The tires on it are almost ready to be changed out so if I need to do the full set, I might as well change rims as well. Any input would be greatly appreciated
Tha Krazy One is offline   Reply With QuoteReply With Quote
Old 01-21-2020, 08:39 PM #449
Endlessblockades's Avatar
Endlessblockades Endlessblockades is online now
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
3rd Gen noob here. I just picked up a 2000 Limited. What is the common name of this wheel design?
The nice old golfer I got it from had just put on a set of Toyo street tires. I hate that you are expected to pay to have perfectly good tires 'disposed of' when upgrading. Definitely going to try to pass them on to someone one way or another. Ideally for a set of meaner-looking rims I can put some real tires on. Maybe I'll offer them to one of the used tire shops in the city. I know a lot of people feel that murdered-out rims are played out, but my 3rd gen in 100% stock trim looks feeble. Also, coming from a 2nd Gen w/15s it's a bit of a shock that tires in 16" are $100 more per tire.
Endlessblockades is online now   Reply With QuoteReply With Quote
Old 01-21-2020, 09:03 PM #450
VernySanders's Avatar
VernySanders VernySanders is offline
Real Name: Werner
VernySanders will become famous soon enough VernySanders will become famous soon enough
Real Name: Werner
Hi All,
OFFSET: 15MM
WHEEL SIZE: 7Jx16
OFFSET: 13MM
I am not going to lie, I know this sounds like i am being rude but i completely promise you I am not. From the bottom of my heart, next time just actually look up some sort of reference for how small .1mm is.. it would be common sense that this would work for either or if one is considering how small of a variation that is.
VernySanders is offline   Reply With QuoteReply With Quote
Post pics or your 4Runner with 265/75/16s vol4runner 3rd gen T4Rs 131 09-08-2022 03:39 AM
Do you wash your 4runner before you post pics? cmar Polls 4 05-31-2016 01:01 PM
1990 Toyota 4runner wont go into 4 wheel drive just 2 wheel and need help? Big Dog Alaska General Discussions 2 03-30-2010 12:13 AM
2000 4runner Wheel Options -- flyinlynx 3rd gen T4Rs 7 06-11-2009 03:02 PM
1997 4runner Wheel ? Tire Options???? wmkeele Engines / Suspension / Wheels / Tires / Audio / Accessories 0 12-28-2007 09:55 AM
