Old 04-04-2012, 06:36 PM #1
Armandi Armandi is offline
Armandi is an unknown quantity at this point
real time tranny problem
here are the last two weeks.
tranny cooler line fitting into radiator breaks. I replace the radiator. The same day I clean the throttle body and maf as i have done before. Two days later the car woould occasionaly stall on start up. Low rpm and want to stall unless given gas. But only stalling if I had been out of the car for a few minutes. Example: If had been driving and stopped in the store for a few minutes. Never on a cold start up.
Yesterday the tranny started slipping. Never a trans problem before. Drained and refilled this morning. Drove 15 miles fine then started slipping again. Got stuck in an intersection...turned the car off and started it back up. Went back into gear. Had it towed home and dropped the pan. Little but of sludge but zero shavings.
electrical?
any advice would help.
Armandi is offline   Reply With QuoteReply With Quote
Old 04-04-2012, 06:42 PM #2
quicksilvr's Avatar
quicksilvr quicksilvr is offline
quicksilvr is on a distinguished road
quicksilvr's Avatar
Tranny fluid is bright red and clear? No cloudy fluid?
2001 SR5~Thundercloud Metallic~3.4L Auto~4x4~260k miles~TRD 2gen black Supercharger~URD AFR Calibrator~B&M 70264~Bilstein Adjustable w/ tall '99 fronts~ProComp 3" rear springs~Nitto Ridge Grappler 285/70R17's on 17x9 Enduro's~Yakima RailRider w/48" bars~ScanGauge II
quicksilvr is offline   Reply With QuoteReply With Quote
Old 04-04-2012, 07:33 PM #3
fluid was def old. prob 65k on it. Mobil 1 syn atf.
Old 04-04-2012, 08:00 PM #4
Anyone?
Old 04-04-2012, 08:32 PM #5
Mano1124's Avatar
Mano1124 Mano1124 is offline
Real Name: Manolo Rodriguez
Mano1124 is on a distinguished road
Mano1124's Avatar
Check engine light on? Maybe the shift solenoid.
Mano1124 is offline   Reply With QuoteReply With Quote
Old 04-04-2012, 08:48 PM #6
No light :/
Old 04-04-2012, 08:49 PM #7
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
Explain the cooler line problem better. There's a couple of issues at hand. If the tranny ran dry then yes damage could have been done. If the cooler contaminated the transmission with coolant then the clutches may be toast if the tranny wasn't flushed. I think you glossed over that repair.
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 04-04-2012, 08:54 PM #8
RunninInGA's Avatar
RunninInGA RunninInGA is offline
Real Name: Macho Nacho
RunninInGA is on a distinguished road
RunninInGA's Avatar
What lead up to or how did you find out about tranny cooler line fitting breakage?
EDIT - Drcoffee just beat me to it.
RunninInGA is offline   Reply With QuoteReply With Quote
Old 04-04-2012, 09:22 PM #9
Ok so I noticed that I had a small leak at the fitting on the tranny cooler line that goes into the bottom of the radiator. It's a 90 elbow. I went to see if it was loose and it just popped of completely. Obviously at that point I had coolant and ome fluid leaking out. I had the truck towed to a radiator shop where they swapped the radiator for me. Drove fine for two weeks besides the stalling issue. Until this morning when it started slipping.
Started slipping immediately this morning. Drove down the block. At times the truck wouldn't move at all. After turning it off and back on it found the gear. Drained and refilled with Mobil 1 ATF and a bottle,of Lucas. Drove for 15 miles fine even at highway speed. Started slipping again. Pulled off the highway. Got stuck at an intersection. Turned her off and on and was ale to find gear and the pulled over for tow.
Old 04-04-2012, 09:34 PM #10
lem14's Avatar
lem14 lem14 is offline
lem14 is on a distinguished road
lem14's Avatar
Take a look at the ABS control module. I have never had this problem with the runner, but I definately had this with my volvo sedan. It would drive fine, then slip out of gear and the engine would rev. I had to pull over, turn the car off, and then when I restarted it, it would run normal for a while. Then it got to the point where it would not go into reverse. Also the speedo did not work after stopping at the store and turning the car off, but upon restarting the vehicle it came right back on. It was a short in the ABS control module.
I am thinking the problem is something electric, especially if everything with the tranny fluid is normal and has been.
lem14 is offline   Reply With QuoteReply With Quote
Old 04-04-2012, 09:36 PM #11
Don't get me wrong. The fluid needed changing but this seems so coincidental that the two happened so close to each other. I forgot to mention it has 163k on it. Should I try and run an OBD scan?
Old 04-04-2012, 09:55 PM #12
Drcoffee's Avatar
Drcoffee's Avatar
I'm just trying to get a better picture of what's gong on. Are you sure that you topped off the trans fluid? I mean actually checked the dip stick while it is running to verify it has enough? Was the fluid you removed pink and milky or red'ish translucent? What concerns me if the port was so loose it fell off in your hand, I'm thinking the transmission ran dry. Or worse, the cooler inside broke first and mixed with the trans fluid. We just need more info to be able to help you.
Old 04-04-2012, 09:55 PM #13
lem14's Avatar
lem14's Avatar
I am not sure if it would tell you anything since there are not any lights on, but it can't hurt to try.
Also I googled tranny problems, and although this is a slightly different presentation of symptoms, this guy had a problem with his tranny that was Battery related??
When was the last time you had your battery replaced? Or even tested at a napa/auto zone?? Worth a shot, and cheaper than a new tranny??
2000 4Runner Automatic Transmission (Battery???) Problem - Transmission Discussions at Automotive.com
I am still thinking electrical, assuming that you checked everything that Dr. Coffee just said.
Old 04-04-2012, 10:08 PM #14
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
Get rid of the Lucas, that may be a problem. I have used a whole bottle before (not on an Aisin tranny) and had slippage.
I'd buy some transmission fluid in bulk (at least 16qts, more like 20) and do a flush. It sounds like a pink milkshake occurred and the clutches may be gone.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 04-04-2012, 10:09 PM #15
Im sure the tranny did not run dry. The fluid was not bright red. Slightly burnt. I suppose it could have gotten contaminated.
Can ODB or DLC be used to monitor real-time temps? MICA4R 4th Gen T4Rs 32 10-21-2013 02:32 AM
First Time Doing Real Hills in SR5 (Broken Arrow, OK) rlinger 5th gen T4Rs 15 10-21-2011 10:24 AM
Real Time Traffic alaskaman 4th Gen T4Rs 2 07-07-2008 04:53 PM
Adding Real Time Traffic alaskaman 4th Gen T4Rs 3 08-25-2007 08:07 PM
1998 A Little Wrecked and Is Time For Some Real Work WOODYs4RUNNER 3rd gen T4Rs 9 11-05-2005 05:37 AM
