Old 04-11-2012, 05:09 PM #1
tbst's Avatar
tbst tbst is offline
tbst is on a distinguished road
tbst's Avatar
How To Press Shock Bushings In and Out
So if you order Bilstein 5100 Tundra then you will need to push out the old bushing and push in a new (3/4") bushing into the shock. This applies to the rear shocks, the fronts don't need any bushings to be pressed in or out.
This is one way it can be done.
Tools Needed
3/4" deep well socket
Impact gun (or strong arms and a 1/2" ratchet)
32 mm socket (rent from AutoZone for FREE)
Pitman puller (rent from AutoZone for FREE)
Crescent wrench
Supplies Neeed
Shocks
3/4" bushings
1/2" x 5" carriage bolts and corresponding nuts with a few washers
Pushing Bushings Out
Get out Pitman puller.
Add a few washers to the end of the Pitman puller. This is done for two reasons. One, the shaft on the puller will fit into the bushing, jamming into the bushing. Two, the shaft isn't long enough, so you need the washers to push out the bushing.
Put on shock.
Crank down (your choice: man or machinery). Should look like this.
Keep cranking down until you have this out.
This is the end result.
Pressing Bushings In
This is where you will need the 1/2" carriage bolt.
Make a setup like this with the 3/4" rubber bushing.
Using crescent wrench tighten down.
This should be the end result. If you go too far then switch over to the other side.
Done!
Obviously this would be done another way, pressing the bushings out only using the 32mm nut. However, I have not tried this method. I am very sure it would work though.
And a h/t must go to rickashay and 004RunnerLtd for their help and bouncing ideas off them with 004 giving me the Pitman idea.
My 2001 SR5 4WD build thread
Writeups: How To Press Shock Bushings In and Out | Interior LEDs for $14.21 |
I need black SR5 flares. PM me if you have them!
tbst is offline   Reply With QuoteReply With Quote
Old 04-11-2012, 06:02 PM #2
zgensler31 zgensler31 is offline
zgensler31 is on a distinguished road
i like it. btw got my shocks in today. thanks again for the hook up. i owe you.
1996 Limited 4X4
Desert Dune, 140,000 miles, E-Locker
About to get a 5-Speed r150f!
zgensler31 is offline   Reply With QuoteReply With Quote
Old 04-14-2012, 02:34 PM #3
004runnerLtd's Avatar
004runnerLtd 004runnerLtd is offline
004runnerLtd is on a distinguished road
Awesome man!
Came out great. Thanks for creating this write-up.
Will be ordering my rear tundra 5100s (with hour glass bushings) and OME 906s shortly!
Post photos when you get your suspension all in!
2000 Toyota 4Runner Limited, White/Silver
Tundra TRD Coils/Bilstein 5100 adjustables (front) -- OME 906s w/ Tundra 5100s (rear) -- Tundra 'Big Brake' Upgrade -- FJ Cruiser Wheels (265/70R17) -- Sound deadened/barrier -- Deck Plate Mod
004runnerLtd is offline   Reply With QuoteReply With Quote
Old 04-15-2012, 08:38 AM #4
Qyota's Avatar
Qyota Qyota is offline
Qyota is on a distinguished road
Qyota's Avatar
This applies to the rears only, correct? Front 5100s need no modification?
Qyota is offline   Reply With QuoteReply With Quote
Old 04-15-2012, 10:17 AM #5
tbst's Avatar
tbst's Avatar
One day I will call on you.
Originally Posted by 004runnerLtd View Post
Awesome man!
Will do. And thanks for your help.
That is correct. Rears only need bushings pushed. From 1/2" to 3/4".
Old 04-16-2012, 01:32 PM #6
rickashay's Avatar
rickashay rickashay is offline
Real Name: Addison
rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold
rickashay's Avatar
Real Name: Addison
Great write-up! Glad that you got everything to work out.
So, this proves it.... you CAN press out the tundra bushings and hourglass ones WILL fit in their place! hahaha
rickashay is offline   Reply With QuoteReply With Quote
Old 04-16-2012, 02:55 PM #7
hungryeddy's Avatar
hungryeddy hungryeddy is offline
hungryeddy is on a distinguished road
hungryeddy's Avatar
great write up! where do you get those bushings? anyone know if they'll fit stock tundra trd billies? i got some i want to fix but can't find the bushings anywhere...
1997 SR5, 217xxx, 5 Speed, 3" Eibach Springs w/ Tundra Bilstein 5100's, LC 8 Wraps, Bilstein 5125 in the rear, ISR, Elbow Removal mod, FJ Wheels, Tundra Brake Swap, 265/70R17 Goodyear Duratracs - SOLD
1999 SR5 220k, Automatic, e-Locker w/ blue wire mod, 3" Eibach Springs w/ Tundra Bilstein 5100's, LC 8 Wrap coils, Monroe Econo rear shox, 5th gen TRD Wheels, Tundra Brakes, Diff Breather, Satoshi Grill, Sport Hood
hungryeddy is offline   Reply With QuoteReply With Quote
Old 04-17-2012, 10:49 PM #8
Qyota's Avatar
Qyota's Avatar
Are these the right bushings? Bilstein 98108G - Bilstein Replacement Shock Bushings - Overview - SummitRacing.com
Old 04-18-2012, 12:06 AM #9
BrianSD_42's Avatar
BrianSD_42 BrianSD_42 is offline
Real Name: Instagram: briansd_97r
BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice
BrianSD_42's Avatar
nice dude!
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
BrianSD_42 is offline   Reply With QuoteReply With Quote
Old 04-18-2012, 12:16 AM #10
tbst's Avatar
tbst's Avatar
Thanks guys!
For whatever reason I am not getting email notifications anymore for threads I am sundries to.
Eddy and Qyota, those look exactly right and they have the right 3/4" inner diameter. Really cheap too!
Old 04-18-2012, 01:33 AM #11
Orev Orev is offline
Orev is on a distinguished road
Thanks for the valuable write up!
I am still slightly confused with a few things,
1.In the pictures you are changing the bushings on Rear Tundra 5100's.
2.Does this need to be done to the front shocks as well? I am installing Front Tundra 5100's (f4 be5 6929 ho)?
3.Also I have been told the rear Tundra 5100's are too short for a 3 inch lift is this correct??
Orev is offline   Reply With QuoteReply With Quote
Old 04-18-2012, 09:48 AM #12
tbst's Avatar
tbst's Avatar
This does not need to be done with the fronts. They are already the right size.
The Tundra 5100's with a 3" lift are perfect. No worries. If you want some more travel you could look into Bilstein 5125's.
Old 04-18-2012, 02:37 PM #13
Thanks tbst!
Buying some rear 5100's today!
Old 04-19-2012, 02:49 PM #14
tbst's Avatar
tbst's Avatar
No problem let us know how it goes.
Old 04-21-2012, 07:57 PM #15
Qyota's Avatar
Qyota's Avatar
Got my rear 5100s and the 3/4" bushings today. Gonna do the bushing swap tomorrow. Interesting that the 3/4" bushings are all rubber, but the 1/2" ones have the metal sleeve.
EDIT: just did the bushing swap, went great! I just used the two sockets and the carriage bolt for removal and install. Actually use a dead blow hammer to get the new ones in most of the way.
Nice write up, tbst!
bushings , pitman , press , shocks
Do LC shock bushing match stock lower shock bushings?? Jc12 3rd gen T4Rs 2 04-10-2012 07:54 PM
Anyone got extra / used rear shock bushings (3rd gen) bak3rme Classifieds - buy & sell (no commercial ads please) 0 04-05-2011 07:48 PM
Upper control arm bushings (do poly bushings exist?) jamess 3rd gen T4Rs 20 02-21-2011 04:07 PM
Can 5w-30 Casue low oil press in my 94 sr5, auto? skinnadoor Classic T4Rs 0 06-13-2007 05:00 PM
285/75/R16 BF All Terrain Tire Press... AZrunr 3rd gen T4Rs 4 02-24-2005 11:43 AM
