Old 07-19-2018, 07:14 PM #31
YourUncleFats YourUncleFats is offline
YourUncleFats is on a distinguished road
Zombie post!
Got my hourglasses on amazon, 4$
Energy Suspension 9.8108G 3/4" Hourglass Shock Eye Bushing https://www.amazon.com/dp/B000CN9D4E..._ANruBbN0DNZ5Z
Then I used the pitman puller I rented and a washer (didn't have a fender washer handy, had to use 2) to push the new bushing back in. It was real easy to push the new one through.
YourUncleFats is offline   Reply With QuoteReply With Quote
Old 12-06-2018, 04:04 PM #32
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
@tbst, thanks for posting the Pitman puller and bolt/washer ideas. Perfect solutions, and as cost effective as it gets. These are 4600s I recently picked up for my 4th Gen.
Removal
Insertion
Done!
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 12-06-2018, 10:58 PM #33
ChildrenOfBodom's Avatar
ChildrenOfBodom ChildrenOfBodom is offline
Moderator
Real Name: James
ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light
Moderator
Real Name: James
Can anyone verify the dimensions (ID, tube length, old sleeve length, bolt size) of the bilstein shock eye? I'd like to see if a better fit straight eye bushing exists.
I see folks using the 9.8108 which is a 1.125 OD hourglass... it's really not recommended that someone use hourglass bushings in straight eyes. The bushings werent made for that, they are meant for hourglass shaped eyes.
Take, for example, most OE replacement rear shocks, the lower eye... those are almost always hourglass shaped. For those, 9.8143 is a perfect fit for OE Toyota shocks and most OE style replacement brands.
Source: I work for Energy Suspension and am completely familiar with these products
IG: @jimharb | YouTube | '99 Limited 2WD |
'99 4Runner - 2.7L 3RZ-FE - TRD S/C - 4WD Conversion + R150F 5-Speed Swap - Imperial Jade Mica on Oak
'87 4Runner Turbo - 2.4L 22R-TE - CT-26 Supra Turbo - W56 5-Speed Swap - Red on Red
'90 4Runner 2-Door - 3.0L 3VZ-E - Auto to R150F 5-Speed Swap - Red on Gray
'94 Supra Turbo Targa - 3.0L 2JZ-GTE - Marlin Crawler R154 - Imperial Jade Mica on Black
'89 Supra Turbo Targa - 3.0L 7M-GTE - Marlin Crawler R154 - White Package on Blue
'89 Pickup DLX 2WD - 2.4L 22R-E - W55 5-Speed - White on Blue
ChildrenOfBodom is offline   Reply With QuoteReply With Quote
Old 01-11-2019, 04:44 PM #34
Hollis's Avatar
Hollis Hollis is offline
Hollis is on a distinguished road
Hollis's Avatar
Bump because I wanna know, too!
1997 4Runner SR5 4wd 3.4 V6 Auto, 280,000 + club Toytec Ultimate Lift with Bilsteins, 2006 Tundra TRD Off Road 5 Stars, Falken Wildpeaks 265/65/16, ARB Front Bumper, Sport Hood, Snorkel, TYC Crystal Headlights, Gibson SS Exhaust, 13WL Tundra Brake Upgrade, Pioneer AVH-1400NEX HD stereo, Infiniti Reference 6.5",Running board delete, Ft Factory Mudflaps, Bone stock drive train, front window tint, alarm.
Hollis is offline   Reply With QuoteReply With Quote
Old 03-12-2019, 02:55 PM #35
runokc runokc is offline
runokc is on a distinguished road
we got a different energy suspension part number that may be better?
runokc is offline   Reply With QuoteReply With Quote
Old 10-02-2019, 06:42 PM #36
DMain DMain is offline
DMain is on a distinguished road
Hello, I am new here and playing catch-up. Was there a better option for the Tundra 5100 that the daystar bushing? Was the ES bushing determined to be incorrect? Thanks!
DMain is offline   Reply With QuoteReply With Quote
Old 10-14-2019, 07:40 PM #37
Moderator
Real Name: James
Moderator
Real Name: James
Well, due to a lack of responses, I said screw it and purchased a set of Bilstein 5100 (part # 24-100144) and here's what I've determined:
Shock eye diameter is 1.0625
ID needed is .750 to fit 4R
Bingo bango, Energy Suspension part # 9.8140 fits the bill. Fits standard straight eye (as the Bilstein has), .750" ID, 1.5625 overall length.
Fits like a glove and it will actually last since it's a straight eye bushing and NOT and hourglass!
Old 10-16-2019, 11:40 PM #38
mastee mastee is offline
mastee is on a distinguished road
Is the busing above also recommended when replacing 4th gen tr4 rears with lets say 2019 taco bilstein rears? or these are for 5100 only
mastee is offline   Reply With QuoteReply With Quote
Old 10-19-2019, 09:59 AM #39
Moderator
Real Name: James
Moderator
Real Name: James
It can't be determined without verification that the eyes use the same dimensions. Bilstein makes a lot of different shock eye sizes.
If you have a digital caliper, try to get an outside diameter measurement of the metal shell that surrounds the original rubber bushing... we can go from there.
Thanks
Old 10-19-2019, 11:25 AM #40
Model number 48530-04110, can you recommend the right straight ones if these are not compatible. pics are failing, I am going to put these up on flickr
20191019_081251 | Bilstein 48530-04110 | mastee24 | Flickr
20191019_081235 | Bilstein 48530-04110 | mastee24 | Flickr
Old 10-20-2019, 12:39 PM #41
Moderator
Real Name: James
Moderator
Real Name: James
That OD is PERFECT for the bushing, almost dead on 1-1/16".
The one other thing you'd wanna check is the tube width of the shock eye itself, instead of the OD. The bushing I have listed fits about a 1" wide shock eye.
Bilstein probably used the same shock eyes on these model shocks as the Tundra 5100.
bushings , pitman , press , shocks
Do LC shock bushing match stock lower shock bushings?? Jc12 3rd gen T4Rs 2 04-10-2012 07:54 PM
Anyone got extra / used rear shock bushings (3rd gen) bak3rme Classifieds - buy & sell (no commercial ads please) 0 04-05-2011 07:48 PM
Upper control arm bushings (do poly bushings exist?) jamess 3rd gen T4Rs 20 02-21-2011 04:07 PM
Can 5w-30 Casue low oil press in my 94 sr5, auto? skinnadoor Classic T4Rs 0 06-13-2007 05:00 PM
285/75/R16 BF All Terrain Tire Press... AZrunr 3rd gen T4Rs 4 02-24-2005 11:43 AM
