Millerad1651
Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Old 07-16-2015, 01:28 PM #61
criera's Avatar
criera criera is offline
criera is on a distinguished road
criera's Avatar
Originally Posted by TheDurk View Post
I've never seen anyone claim to have removed it successfully (without breaking), let alone a how-to video.
I was able to remove mine in one piece. I used my frame end caps that I cut off, perfect size to fit two opposite each other and inserted underneath and snug all the way to the shaft. I was able to pry it up from both sides putting the pressure across the entire diameter of the fan (x2) and as close to the shaft as possible. This allowed me to put the most amount of lifting force with as little flexing of the fan as possible.
I would get it to move up a hair on the shaft, drop some oil on it then push it back down to lube the shaft on its way up. Did this about 20+ times moving a lil bit more each time. This part prol took a good solid 20-30 min of back and forth.
The job was pretty easy, hardest part was having the patience not to exert too much force. I could see how this would be more challenging if not impossible on a rusty truck, mine has very little.
So while was possible for me, it was a delicate procedure and I was prepared to be without a fan if I broke it. That said it was an easy choice since I was ready to drive off a cliff to make the chirping go away. Happy to report it's been silent ever since.
Cleaning the blower fan write-up-image-jpg
2000 SR5 V-6 Auto
criera is offline   Reply With QuoteReply With Quote
Old 07-16-2015, 02:34 PM #62
Ruff Ruff is offline
Real Name: Raul
Ruff is on a distinguished road
Real Name: Raul
I don't think I have the patience to try it. But, thanks for sharing how you went about it.
Ruff
Cypress, Texas
Ruff is offline   Reply With QuoteReply With Quote
Old 07-16-2015, 04:29 PM #63
yota_addict's Avatar
yota_addict yota_addict is offline
yota_addict is on a distinguished road
I did this last week. No more annoying sound!
97' Land Cruiser FJ80 OME lift with 35" tires
97' T4R Limited - Tundra trd coils up front, OME 906 in rear and 5100s on all 4s. BFG KO2s 265/75/16s. Detroit Truetrac Differential
85' FJ60 SOLD to Toyota
06' Tacoma double cab 4x4 with lockers SOLD
yota_addict is offline   Reply With QuoteReply With Quote
Old 07-16-2015, 07:44 PM #64
98WhiteT4R's Avatar
98WhiteT4R 98WhiteT4R is offline
Real Name: Jon
98WhiteT4R is on a distinguished road
98WhiteT4R's Avatar
Real Name: Jon
Did this today...cleaned out a bunch of pine needles.
98 T4R Limited-elocker-OME 883/891-Stubbs sliders-285/75/16 General Grabber AT2-LC wheels-Savage skids-Satoshi-front and rear CBI hybrids-Smittybilt XRC 9500
Link to Build Thread http://www.toyota-4runner.org/3rd-ge...ld-thread.html
98WhiteT4R is offline   Reply With QuoteReply With Quote
Old 07-17-2015, 12:13 AM #65
kball's Avatar
kball kball is offline
kball is on a distinguished road
kball's Avatar
I skipped the cleaning step and just bought a new one. Amazon.com: TYC 700061 Toyota 4 Runner Replacement Front Blower Assembly: Automotive
Kept the old one as a spare. The only difference I can tell so far (besides the quiet fan) is when I use the window washer fluid. Seems like now all the smell of the fluid comes right into the cab. Don't remember that ever being an issue before.
1996 SR5 4Runner V6 4WD Auto
Toytec Ultimate w/ OME 890's plus 1.5" daystar spacer
60028 OME shocks, Goodyear Duratracs 265/75 -16
B&M 70268 with Magnefine filter, 199mm TBU
236K miles
kball is offline   Reply With QuoteReply With Quote
Old 07-17-2015, 05:58 PM #66
SC01's Avatar
SC01 SC01 is offline
Real Name: Tyler
SC01 is on a distinguished road
SC01's Avatar
Real Name: Tyler
Originally Posted by haydenwebb404 View Post
So my ac was making a horrible noise I just bought it a few weeks ago and finally got around to looking into it and look what I found!
And there is some sort of filter way up top
Same deal with me. Mine was making a noise like a bike with a baseball card in the spokes. Turns out it was a sticker that had come loose from another part of the assembly. Dropped it down, fished it out, blew it clean, and popped back in. 15 minutes and all was well.
2001 Limited (gone), 2012 Trail Edition. South Carolina.
"Impossible isn't a fact, it's an opinion."
SC01 is offline   Reply With QuoteReply With Quote
Old 07-17-2015, 06:52 PM #67
Weagle2 Weagle2 is offline
Weagle2 is on a distinguished road
Talking
My son's '96 was making weird noise and clicking noise. Pulled it out to find it 1/3 full of old insulation from an old farm house near hunting club. (Field mice I guess). Cleaned it out and running fine. Wish we'd done it two years ago. Forgot to take pictures. Took us about 25 mins start to finish. Pretty easy for young person to contort and get to bolts and pull side kick panel. Did not remove glove box.
Weagle2 is offline   Reply With QuoteReply With Quote
Old 10-10-2015, 11:17 PM #68
purplePeopleEater purplePeopleEater is offline
purplePeopleEater is on a distinguished road
The other day my AC started to make a grinding sound, which progressed to a high pitched shriek, so following the instructions in this thread I removed the blower assembly. There was a buildup of grime on the fan, but otherwise it was empty. Unfortunately this meant the problem was internal, I suspect a bearing, so I could either 1) buy a new one, 2) try to fix it, fail, and then buy a new one.
What I did was weave a piece of string around the circumference of the fan, alternating between the inner and outer radius every 2-3 blades. For each "stitch" on the inner radius, instead of pulling it tight I created a loop of slack that reached to approximately the other side. By then joining together each of these loops at their apex, it created something of a cradle underneath the upper rim of the fan.
I took the attached picture right after I successfully removed the fan. I don't have access to a sufficiently large vise to hold things in place, so I sat in a chair and held it between my feet. The housing has a lip that extends beyond the edge of the fan, so by placing my feet on this lip and pulling the strings towards myself I was pulling the fan off of its spindle. The blue rope in the top of the photo bundled together all of the lines to provide a better hand hold.
As I started pulling I adjusted the slack to make sure the force was evenly distributed around perimeter, and then I gradually increased the tension. I had to pull pretty hard to get things moving, but eventually it started to slip, first a few mm, than a cm, and then it popped right off.
With the fan off you can see inside the fan motor, and unfortunately mine had a fair amount of rust (I live near the ocean, and the salt air wreaks havoc with hvac). The rust had basically fused the motor to the black plastic housing, but at least removing the fan exposes the innards of the motor. I cleaned out the insides with compressed air and lubricated all the moving parts in sight.
After that I reassembled, reinstalled, and fired it up. The squeal is gone, although it does seem a bit louder. Considering all the rust it will probably fail again soon, but at least for today things are working again.
****While this worked for me the standard disclaimer applies: I make no guarantees and assume no liability if you try this yourself.
Cleaning the blower fan write-up-fan_removal_rig-jpg
purplePeopleEater is offline   Reply With QuoteReply With Quote
Old 10-12-2015, 02:25 AM #69
Originally Posted by 4R#3 View Post
Try the foot kick or hammer tap.
I'll keep that in mind if it acts up again; the sound is piercing enough that I'll be more than happy to kick it.
Apparently people more skilled then I rebuild these electric motors. According to that page Toyota considers them sealed, and I couldn't see how to disassemble it without destroying it.
Old 01-28-2016, 05:28 PM #70
Mountaineer300ZX Mountaineer300ZX is offline
Mountaineer300ZX is on a distinguished road
Remove 4 screws at bottom door seal
Remove Kick panel
Remove electrical connector from motor
Remove 3 8mm screw bolts A swivel is needed for the back one
Drop the motor out
Remove Debris then hose off with water hose Let Dry
Reinstall in reverse order
Mountaineer300ZX is offline   Reply With QuoteReply With Quote
Old 05-01-2016, 11:28 PM #71
T4R3prospect T4R3prospect is offline
T4R3prospect is on a distinguished road
This is what i found in mine! Poor little guys.......
Cleaning the blower fan write-up-img_1597-jpg
T4R3prospect is offline   Reply With QuoteReply With Quote
Old 05-01-2016, 11:35 PM #72
amalik amalik is offline
amalik is on a distinguished road
almost barfed.
amalik is offline   Reply With QuoteReply With Quote
Old 05-01-2016, 11:41 PM #73
I felt them before I saw them
Old 05-02-2016, 01:51 AM #74
StreetCreeper's Avatar
StreetCreeper StreetCreeper is offline
Real Name: Woody
StreetCreeper will become famous soon enough StreetCreeper will become famous soon enough
Real Name: Woody
So how'd they taste?
I'm thinking like beef jerky but with a little crunch...eh?
"Variety is for your mind, not your body " —OS
StreetCreeper is offline   Reply With QuoteReply With Quote
Old 05-02-2016, 01:54 AM #75
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
I once found a litter in my Springer's Kibble drum. I just included them in his dinner. He loved them.
My Backyard Frame Swap
Fan blower on when off ? 4RNNR 4th Gen T4Rs 4 04-25-2012 04:00 PM
Blower or Fan? jerseygeorge 3rd gen T4Rs 9 10-13-2010 09:59 PM
'03/'04 4.7L TRD Blower chiplee Classifieds - buy & sell (no commercial ads please) 13 11-25-2009 10:57 AM
Cleaning out blower motor? MunkeyTX Maintenance/Detailing 3 08-28-2008 03:20 AM
a\c blower ENDLESS381 Problems & Warranty Issues 2 10-08-2007 04:27 AM
