Old 04-20-2012, 12:21 AM #1
gh0stRush gh0stRush is offline
gh0stRush is on a distinguished road
Blown fuse/relay? Door lock, Interior light, Radio dead
Hi, I'm new to this forum. I have a '96 4runner, and ran into a bit of a problem today while swapping out my map lights with new LED panels. I might have shorted something during the install because the automatic door locks, radio, interior lights all went out at the same time and haven't came back on since, even after I removed the new lights. I can't toggle the door locks from my remote or from the door panel control. Turning the key only unlocks that particular door instead of all four. I can toggle the alarm, but it is acting sort of funny - when I turn it on and off it will emit four chirps; it's never done this before.
Everything was working fine prior to my attempt at doing the LED swap. My dash lights, AC, windows, etc all work. As far as I know, the problem is only restricted to the interior lights, radio and door locks.
Has anyone seen this problem before? Could it be a blown fuse or a relay? If so, which one? What should I look for?
gh0stRush is offline   Reply With QuoteReply With Quote
Old 04-20-2012, 12:32 AM #2
R.A. R.A. is offline
R.A. is on a distinguished road
Check for a fuse in the engine compartment fuse box. It's called "DOME", 10A.
R.A. is offline   Reply With QuoteReply With Quote
Old 04-20-2012, 12:57 AM #3
Well that was fast -- it was the dome light fuse! Swapped it out and everything came back on. Thanks!
I was gearing up for a much more complicated check, looking up wiring diagrams and such. Nope, just one fuse disabled all of those systems.
Old 03-28-2019, 09:53 AM #4
chipmunk7000 chipmunk7000 is offline
chipmunk7000 is on a distinguished road
I'm having the same issue, but the Dome fuse isn't blown. I also checked the Accessory fuse, same deal.
The only thing is that I replaced both fuses and after a couple days, both fuses have a bit of reddish tint on the pins. Any idea what that could indicate?
chipmunk7000 is offline   Reply With QuoteReply With Quote
door locks , fuse , interior lights , radio , relay
Clicking Relay and Dead Battery woomammoths 3rd gen T4Rs 19 09-15-2015 03:18 PM
Blown Relay? captainnemojr 5th gen T4Rs 5 04-17-2010 10:55 AM
frequent brake circuit blown fuse / shift lock problem vespa Classic T4Rs 1 04-12-2008 05:33 PM
Which fuse is the map light/door light fuse? Ryan32 4th Gen T4Rs 2 12-16-2007 11:29 AM
blown dome light fuse wlhinso Problems & Warranty Issues 0 01-22-2007 11:13 AM
