04-24-2012, 12:35 AM
Actual mileage traveled after tire size upgrade
I've searched and everything I find talks about the speedometer. I've got a question regarding the odometer. I recently upgraded to 315's and my speedometer is off which I expected. My question, is there a way to actually calculate what my milage should be? Say my trip mileage says I drove 140 miles, what's the actual mileage traveled.
I just purchased a speedometer calibrator from a fellow member and from what I've read this will get my odometer back on track. If I'm wrong please let me know.
1999 T4R SR5 4WD [Nitro 4.88 Gears][Aussie Lockers Front & Rear][ARB Snorkel][231mm Tundra Brakes][Light Racing Adjustable UCA][Tacoma Manual Locking Hubs][Bilstein 5100/Toytec 650lb Coils][Tokiko FJ80 Shocks/OME 2861 Coils][JDM Field Monitor][AOR Hybrid Rear Bumper][HNC Hybrid Front Bumper][Treadwright 315/70R17 Guard Dog]
My Build Thread
04-24-2012, 12:37 AM
Real Name: Jim
Real Name: Jim
Plug in the numbers here: Tire Size Calculator - Compare Tire Sizes (current tire is the stock one, new tire is the 315)
Get the number for %error on revolutions per mile, drop the minus sign..
Ex: 5.2% = 0.052 (your number will be different)
Multiply your Odometer number by 1.052 = Actual distance traveled.
MPG= Actual distance traveled / Gallons used.
'13 Tacoma TRD-OR: The Spruce Goose. BUILD
'02 Sport Ed.- V2.0: The better build. Totaled BUILD 2.0
'02 Sport Ed.- V1.0: The college build Sold BUILD
04-24-2012, 12:40 AM
Moderator
Real Name: Waldo
Moderator
Real Name: Waldo
Mine is about 4-5mph off but it doesn't mess with your odo/trip.. If that was the case we'd all have falsified information on how many miles on are on our trucks.
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
04-24-2012, 12:59 AM
Thanks Ripcord, I obviously didn't spend much time paying attention in math class growing up.
Revolutions per mile (km)
Current Tire(265): 637.23 (395.96)
New Tire(315): 586.93 (364.7)
Difference: -50.3 (-31.26) -7.9%
So if my trip reads 140 miles am I multiplying it by 1.079? I'm not sure why my difference is a negative number. If I forget about the negative i get 151.06.
My Build Thread
04-24-2012, 01:03 AM
Real Name: Jim
Real Name: Jim
Its negative because there are less revolutions per mile.
Are you sure you put the right numbers in? When I did it for stock (265/ 70/16) and 35's (315/75/16) I got like 11.something.
04-24-2012, 01:07 AM
I'm not sure if I'm correct but if I start my 31" tire next to my 35" tire and let it roll one revolution wouldn't my 35" tire travel a greater distance in one rotation versus the 31" tire? How would that not effect the odometer if the computer/sensor was not calibrated for a 35" tire?
My Build Thread
04-24-2012, 01:11 AM
Are you sure you put the right numbers in? When I did it for stock (265/70/16) and 35's (315/75/16) I got like 11.something.
I'm pretty sure I input the numbers correctly. 267/75R16 were my original tire size however I did not check the door jam label. I recall seeing 225 or 245 as the original tire size. 315/70R17 are my new tire size. If I input 315 as my current tire size and 265 as my new tire size I get a positive value.
My Build Thread
04-24-2012, 01:13 AM
Real Name: Jim
Real Name: Jim
265/70/16 is the stock size, not 75.
Other than that, youre good to go. And no, larger tires will not change the ODO readings, making it inaccurate..
04-24-2012, 01:15 AM
Real Name: BJ
Real Name: BJ
@ryan, you are absolutely correct. Last week, my sending unit in the fuel tank started acting up, so my fuel gauge doesn't work properly. As such, I've been calculating fuel consumption by the odometer. The other night, it was late, I was tired and just wanted to get home, so didn't get gas when I should have. I thought "Meh, it's cutting it close, I'll make it." Nope, ran out of gas halfway home. Luckily, I was able to coast to some farm property we own, and we have gas there for tractors and such. Point of the story is, yes, larger tires affect the odometer. I sat down and did the math just to be sure. I had traveled something like 15 or 16 miles more than the odometer read on that specific tank of gas
1998 T4R Limited Sunfire Red Pearl 4WD 5VZ-FE-V6-3.4L E-Locker Falken Pathfinder 265/75/R16
04-24-2012, 01:20 AM
Thanks for the help. I really wish my trip was off because my gas mileage is so terrible around town. I really need to re-gear. I've got about a 1/4 tank of gas left and I've gone 140 miles.
My Build Thread
04-24-2012, 01:23 AM
Real Name: Jim
Real Name: Jim
I keep confusing myself by how I write.. When you change to larger tires, that change is not reflected in the ODO & Trip readings.. Which is why you have to calculate to find the error that is now present between the ODO readings and the actual mileage driven. Hope that makes sense.
And you need a tune up, read the buyers guide post #7.
04-24-2012, 01:29 AM
Moderator
Real Name: Waldo
Moderator
Real Name: Waldo
You're still going the same distance no matter what tire size.. your revolutions per mile is the only thing that changes.
04-24-2012, 01:35 AM
Yes but you odometer is calculated by the revolutions your wheel or hub or whatever makes. It doesn't actually know how far you've driven, it just knows how many revolutions the hub has made and calculates the mileage based on the revolutions and the stock tire size.
I could be wrong but that's how I've always understood it.
1996 Limited 4X4 Desert Dune, 140,000 miles, E-Locker
About to get a 5-Speed r150f!
04-24-2012, 01:37 AM
If my 4runner thinks(calibrated) for a 225/70R16 tire and I have a 315 tire. how is it not off? Even revolutions per mile would be off.
My Build Thread
04-24-2012, 02:02 AM
Real Name: Phil
Real Name: Phil
Thats correct
267/75/17 Cooper ATs - Level 8ZX wheels matte black - EBC rotors/ pads - 99 coils/ Bilstein 5100s - deckplate - Sotashi/custom emblem - Hella micro DE fogs - Kenwood/Alpine/Infinity system - sound deadened interior - color matched bumpers - LED tails - Safari LTD rack - Husky floor liners - clear corners
