04-24-2012, 03:43 PM
Tire Deflators...?
Are any of you using tire deflators? If so, how do you like them, which brand, how much were they?
Looking to get a couple sets of them pretty soon. Thanks!
**SOLD** 1996 T4R, 5 spd, Toytech Ultimate lift kit, 2" BL, Front AOR tube bumper and rock sliders, 4.30 gears, E-locker rear, Smittybilt XRC8 winch, Goodyear Wrangler Duratrac's 285/75/16, Spidertrax 1.25" wheel spacers, Panhard bracket, Midland Handheld 75-822 CB w/Hustler FG27S Antenna Fender Mount , Rigid Dually LED's....Keep watching!!
04-24-2012, 04:13 PM
I just got the cheap screw on ones. I throw them on , wait for 2 mins and the tires are just about 15psi...
2005 Limited V8 4x4 4Runner
2005 SR5 V8 4Runner
1997 40th Anniversary FZJ80
2001 Ford F350 w/ FWC Hawk
04-24-2012, 04:23 PM
I had the Staun deflators, but I couldn't get them to stay at the pressure I wanted. I would set them to 16 or so, put them on and they'd go all the way to 10 or 12. Never trusted em, so I got rid of them.
And, why would you need more than 1 set?
2000 4Runner SR5 4x4,Volant CAI,5.29 gears, ARB lockers frt & rr, ARB Bumper w/ IPF lts, Warn M8000
All-Pro sliders, Skid Row Offroad Skids, ToyTec Ultimate Lift,2" BL, BFG KM2 315-75-16s,Cobra 75WXST CB
Headrest DVD x2 w/ XBox 360, 800W inverter,4x55W lts frt,2x55W lts rr on rack, Dual Optima Yellow Tops, VIAIR on-board air
04-24-2012, 04:32 PM
Thats probably what ill end up doing. Thanks!
Thanks for the input. Those are the ones ive been looking at, but they are pretty pricey! My main purpose of this post was to find out pretty much what you said, I was curious as to how accurate they were. As far as needing 2 sets, I need some for both mine and my wifes vehicle.
04-24-2012, 05:38 PM
Real Name: Addison
Real Name: Addison
Most people I wheel with run the Trail Head Deflators. I don't have any yet but that will be the route I am going to go. You can adjust the pressure that they air down to. You just throw them on and they do their thing..... Super awesome in the winter as your hands don't freeze trying to read tire pressures and you can even drive to a trail head while you are deflating.
04-24-2012, 06:18 PM
I will check on those when I get home. Thats what im wanting. I just want to be able to set them where I want, put em on and go. And as far as freezing your hands, I hear ya there. We were airing down a few weeks ago up in the mountains, and not only is the outside air cold, but the dang air coming out of your tires while you are holding the valve core to deflate is cold too!!! Thanks for the input!
04-24-2012, 09:47 PM
I have a set of stauns but just pulling the valve cores is the fastest so i find my self only doing that
check out my build thread My Build
04-24-2012, 09:51 PM
Real Name: Dave
Real Name: Dave
I just use a key and a tire gauge. Im cheap.
00 Limit. 4x4, 2.5 ICON coilovers w/ remote reses CDC valve front and rear , Rear Locker, Nitto Trail Grap.285's, BajaRack,1 in. body lift, Savage Offroad Rear bumper, spacers, sliders and full skids, ODL bumper, xrc8 winch, Deckplate Mod, VIAIR Heavy Duty onboard air, ICON UCA"S, Budbuilt diff skid, 4.88 G2 performance gears
04-24-2012, 10:56 PM
Moderator
Real Name: Waldo
Moderator
Real Name: Waldo
Have used one but don't own one (yet). They sure work like a dream.... >
ARB EZ Deflator
Amazon.com: ARB ARB505 E-Z Deflator: Automotive
Cool thing is you can usually find them at your local Toyota dealership parts counter.
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
04-24-2012, 11:19 PM
Real Name: Jim
Real Name: Jim
I went cheap on this one, just the screw on ones. A set of 4 is what? $10?
'13 Tacoma TRD-OR: The Spruce Goose. BUILD
'02 Sport Ed.- V2.0: The better build. Totaled BUILD 2.0
'02 Sport Ed.- V1.0: The college build Sold BUILD
04-24-2012, 11:23 PM
I use the stauns. They are quirky. To set them there is a part the screws up and down, and once it is set another part screw up tight into it to hold it in place. Kind of like using 2 nuts on a bolt. When youbscrew them on and off don't do it from those bolts do it from the many body of the deflator.
Once they are screwed on the tire valve, you need to have faith in them. If you regulated them to 15 and are starting at 30psi and you dont have faith and keep removing them to check with a pressure guage if you are getting close eventually they stop working. You need this to just let them drop the pressure from 30 to 15. If start them again at say 18 they might not start up again. They seem to need a higher pressure to start.
For the ARB quick deflator. I think that is the one that pulls the stem out. A friend used that, and the stem went off into the grass. The spare was needed then.
2003 4Runner Sport 4.7 V8 Silver/Grey - Fr/Rr ARB Locker - OME 885/895 - LR UCA - BFG KM2 255/80/17- RCI Skids - Demello Sliders - Bud Hidden Winch- Runva Winch - Synthetic oils- Trail Stripes - Two Baby Seats...
1984/86 4runner In Progress....... V6 swap - High Steer - 33" MTZ - 4.88 Gears - welded rear - ARB front - axle gaussets - Diff covers - Longfields - 4.7 crawler - Titan Winch http://www.toyota-4runner.org/classi...ner-build.html
04-25-2012, 12:37 AM
2001 4runner SR5 / 170KM / Bilstein 5100 with stock coils & OME906 / toyo 265/76/16 / 1.25" spidertrax
1997 S/C 4runner / 276km / 3" OME lift / 285-75-16 duratracs / rock crawler's
SOLD
1999 limited 4runner / 255km / 4" LC lift / 285-75-16 pro comps / and a million dollars in mods
SOLD
04-25-2012, 12:49 AM
Real Name: Connor
Real Name: Connor
Originally Posted by Jc12
These work really well. 20 bucks is 20 bucks.
1996 Toyota 4Runner 4x4 w/ 5 speed- Lifted, Locked,Painted,Armored
Build: http://www.toyota-4runner.org/3rd-ge...ld-thread.html
Originally Posted by invisible4Runner
Highlander = minivan, purses, soccer practice
4Runner = testosterone, steak, dirt
04-25-2012, 01:15 AM
Real Name: Instagram: briansd_97r
I'm going to buy these. They are not cheap but look pretty awesome.
TRAILHEAD TIRE DEFLATOR KIT - 5-20 PSI
http://www.amazon.com/TRAILHEAD-TIRE...5330960&sr=1-9
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
04-25-2012, 01:33 AM
Real Name: Eric
Real Name: Eric
hahaha same here man lol
