04-26-2012, 06:03 PM
Driver Side Grinding noise under hard braking
In just the last week or two I have noticed that under hard braking a rough, grinding noise occurs, (similar to the sound of the ABS kicking in), but only on the drivers side (no vibration in the pedel too)
I installed 199mm Tundra calipers along with new pads and rotors less then 5k miles ago so I know it's not the pads.
The problems seems to stem more from the sudden shift of weigh towards the front of the car, caused by the harder braking, than from the braking itself.
Any ideas?
98 Limited V6 w/310k Miles l 4X4 l Rear Locker l Goodyear Duratracs 265/75/16 l 199mm Tundra Brake Mod l Cobra 800 Watt Power Converter l Uniden Pro 520 XL CB Radio l Bilstein HD Shocks l CS 144 Alternator
04-26-2012, 06:23 PM
Check the caliper mounting bolts. If they backed out at all they'll cause problems.
2007 SportEdition V6 4WD Galactic Gray
Found on the trails of the Colorado front range
Daystar 2.5/1.5, Rear Diff Breather Mod, TRD Brake Pads, Full Synthetic 90w-135 Gear Lube, 265/70/17 Duratracs, Cobra 75, 3' Firestik, Refrigerated Console
Toyota Expert Tech/Lexus Certified Tech/ASE Master Tech
04-26-2012, 06:25 PM
I had a sort of grinding noise going on and I swapped out the cheap-o duralast semi-metallic pads I had to ceramics and the problem was gone... I also re-lubed the caliper slides in the process.
2014 4Runner Trail Edition Premium - Magnetic Gray
2001 4Runner SR5 Thread...Sold
2010 Bernese Mountain Dog
1998 4Runner Limited: Smooshed on an icy bridge in MT
04-26-2012, 06:33 PM
Maybe your tire is rubbing on something when the front suspension squats down under braking. Possibly a part of the fender liner that got bent toward the tire or something?
My first thought was the wear indicators on the pads, but you say they are new pads/rotors, so
04-26-2012, 06:55 PM
Well I'm back from diagnosis with an answer and a picture
Short Story: Inside of the wheel was grinding on the caliper, or rather, the caliper was grinding down the surface of the wheel.
Long Story: Turns out the casting of one of my wheels is different than than the casting of the other three. Three wheels have an area already ground out from the factory where the caliper was hitting the inside of the wheel. When I installed the Tundra brake Mod a few months back the current front wheels had the clearance not to rub the caliper. I just had my wheels rotated last week and that is when the problem arose. So the wheel that didn't have enough clearance must have been just rubbing the whole time lightly, and more so under hard braking. Most of the necessary grind of the wheel is done now...so I guess I'll just have to take off another millimeter with a grinding wheel later on. For now I just rotated the rear and front tire on the drivers side to fix the problem.
04-26-2012, 07:12 PM
D'OH! Can't believe I didn't think of that.
That doesn't seem like something that would change w/braking pressure though. Which begs the question: which component in the equation is moving? The caliper, or your hub/wheel mounting surface?
04-26-2012, 07:16 PM
Yeah that is causing me to wonder what might be moving too...
04-26-2012, 10:42 PM
Normal play in the wheel bearing would be enough.
04-26-2012, 11:05 PM
That's what I was thinking too, mainly because @ 250K miles (assuming they are original) they probably have a bit more than "normal" play in them.
04-27-2012, 02:28 AM
I think they are probably original. Good points fellas. Thanks for the input.
04-27-2012, 09:43 AM
Real Name: Isaac
Real Name: Isaac
thermal dynamics too... when under breaking the caliper would be heating up, possibly enough to cause it to come in greater contact with the wheel...? just a thought, i know its kinda hard to think there would be that much expansion but who knows...
if a*sholes could fly this place would be an airport -2004 GX470 spm -97 SR5 3.4, SCS Stealth 6's w/305 70 17s MTRs, Icon 2.5" RR w/700#coils, OME861s w/Icon tacoma 2.0 RR, ARBs w/nitro 4.88, PIAA LED lights, 170amp CS144, ARB snorkel, ARB bumper w/xd9000ce, CBI swingout loaded, BudBuilt skids, lil skip tank skid, sliders, LCE 231s(d&s), first gen roll bar mod, LED interior/dash lighting, B&M 70624+perma cool w/electric fan, dual electric fanshttp://www.toyota-4runner.org/3rd-ge...ld-thread.html
http://www.metaltech4x4.com/
