05-06-2012, 10:02 PM
Removed wood grain
Today I was just reading some other posts on here and saw where someone removed their wood grain. My was/is in bad shape and has been since I had it. Next thing I know is I'm driving down the road peeling it off.It was much easier than I expected. My wife saw me doing it and started to join in. Kinda nice putting the wife to work on the truck without her even knowing it. It is leaving a little residue but nothing some mineral spirits can't clean up.
97 4Runner SR5, 4X4, 155000 miles in Memphis, LC/TRD strut assemblies with a dif drop, Aussie locked rear end, 4x4innovations sliders, Viper classic 10,000 winch
05-06-2012, 10:08 PM
Nice, it looks way better imo. Sneaky job on getting the wife to help with the truck lol
05-06-2012, 10:17 PM
You got lucky yours came off much easier than mine
05-06-2012, 11:42 PM
if mine isn't worn out and/or peeling how can i get it off easily?
05-06-2012, 11:49 PM
Yeah that actually looks much better. How'd you get it off?
1998 4runner Limited 4WD @145k
My Build Thread
05-07-2012, 01:21 AM
I would also love to know how that came off so cleanly. Mine is in pretty horrible shape right now.
97' 5 Spd 3.4L, 265/75/R16 Cooper Discoverer AT3, Bilstein 4600s OME 881/890, Deckplate & ISR Mod, Magnaflow 18" 380k [/COLOR][/CENTER]
05-07-2012, 07:42 AM
Great job! I have been doing the same thing to mine, have about 6hrs into it, still not finished. This is one place toyota got it wrong on the 3rd gen-
2004 v8 4x4 Sport, daystar preload level, 265/70-17 BFG A/T "C"
05-07-2012, 09:05 AM
I took a pretty heavy duty knife and would start with a corner. Once I got it started, I would pull with one hand on the wood grain and use the knife to cut/pry the tape holding it in. There was a lot of tape left over that I had to use my hands on to remove it. Scratch and peel with your fingernail. When I was done I used mineral spirits to clean it up. Be careful with the mineral spirits. It will start to take off some of the paint on the plastic if you are not careful. Here is what it looked like before peeling with my fingers. My hands were worn out afterwards.
05-07-2012, 09:10 AM
Use this instead of mineral spirits. Home - Goo Gone
What we used on my buddys 4Runner.
05-07-2012, 10:18 AM
To remove vinyl strips from cars you can heat the vinyl with a hair dryer so the glue gets soft (just a few seconds) then it pulls off easily. You might try that but be careful not to melt the plastic.
2002 T4R Limited, 191K miles - OME 883 front - LC 7 wrap/2nd gen sway bar links rear - Detroit Truetrac Diff - Cooper A/T3s - Warn M8000 - ARB Bumper - homemade (er, 'custom') rear bumper w/tire & can carrier - BajaRack - Diff Breather Mod - Hayden trans cooler - Yaesu 2M, Cobra CB - Fridge, off-road trailer with Tepui RTT (real expo poser)In Africa they say: "Buy a Land Rover and it will take you anywhere. Buy a Toyota and it will take you there ... and bring you back home." jannikt on wranglerforum.com - I'm guessing he didn't make many friends there with that line.
05-07-2012, 10:44 AM
For some reason rubbing alcohol on a cloth rag worked the best for me to get residual adhesive off. I tried the Goo Gone, as well, but got frustrated, and wasn't going to use acetone.... The hair dryer worked wonders, too. The important thing is getting it off, though.
2001 SR5 4X4, V6, 3.4L
