Old 05-09-2012, 01:45 PM #1
bak3rme's Avatar
bak3rme bak3rme is offline
bak3rme is on a distinguished road
bak3rme's Avatar
valve gasket help. too thick of gasket possibly?
So i got the valve cover gaskets and i'm trying to put them on but they are not sitting right. I got them at advance auto parts and they were the fel pro brand. blue in color. They line up with the grooves perfectly but when i put them in the groove and put the cover on ....they don't compress and leave a small gap between the cover and the lower piece on the engine. i think the gasket is a little too thick? i'm tightening them down but i don't want to tighten too much and crack the aluminum head.
any thoughts ?
'99 SR5 3.4L 2WD
SOLD
Build Thread
2003 Nissan 350z Track/Autocross
2014 4runner SR5
bak3rme is offline   Reply With QuoteReply With Quote
Old 05-09-2012, 01:57 PM #2
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
any thoughts ?
That's they way they work. You do not compress the valve covers down to the head. The rubber flexes and stays compressed under tension from the bolts. There is a torque spec for the vavle cover bolts and I think its 53 in lbs. After the first one its easy to tell how tight to make it. Compress the washer down until the rubber washer is the same size as the steel washer. Anymore than that and you could crack your aluminum valve covers.
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 05-09-2012, 04:02 PM #3
bak3rme's Avatar
bak3rme's Avatar
don't have a torque wrench on me. lets say i got it hand tightened..how much of a turn after that?
Just finished one side (other side next week when I can park it longer) and i turned on the car and noticed its smoking alot near the firewall. its getting onto the manifold and i just shut it off.. placed my hand around the area and no wet oil. i'm hoping its just old oil burning off?
'99 SR5 3.4L 2WD
SOLD
Build Thread
2014 4runner SR5
Old 05-09-2012, 05:02 PM #4
Jon's Avatar
Jon Jon is offline
Jon is on a distinguished road
Jon Jon is offline
Jon's Avatar
Sounds like you skipped out on replacing the cam plugs. Little half-moon pieces that go in the back. Only available from Toyota. Hope it's just residual oil that your getting. Don't forget to re-torque after the engine has reached op-temp.
I'm goin to tackle mine this weekend.
(SOLD and missed) TRD S/C'd/5spd trans swap/locked w/4.88s/on board air/Toytec 3.5"front/Superfex springst+1.5" spacers rear/35x12.50R17 Pitbull Rockers/AOR tube bumper/XRC8 Winch/custom snorkel/6000K HID Heads/18" LED light bar/Herculined floors and lots of stickers for added horse power
Build Thread
Jon is offline   Reply With QuoteReply With Quote
Old 05-09-2012, 05:35 PM #5
Diagram14's Avatar
Diagram14 Diagram14 is offline
Diagram14 is on a distinguished road
Diagram14's Avatar
When I accidentally over torqued a VC bolt the actual bolt snapped. If youre not tightened relatively evenly around the VC oil will get pushed out. Run your finger around the bottom edge to see where its actually coming out. The cam plugs are a possibility but probably were leaking before and not as a result of removing the VC. When my cam plugs were leaking the oil did not make it to the exhaust manifold to burn off but rather ran down the back side of the motor.
Jon is right though, those plugs will go and if youre already in its worth the time and RTV.
2000 SR5 Sport 4x4. Head Gasket mod. Rear Axle Seal mod. Functioning 4x4 mod. SOLD
2004 DC Tacoma TRD. Same guts, different skin, e-locked.
Diagram14 is offline   Reply With QuoteReply With Quote
Old 05-09-2012, 06:35 PM #6
bak3rme's Avatar
bak3rme's Avatar
i don't see how replacing those half moons would help even thought i should..i mean they look perfectly fine. just a half moon. metal is in good shape..just scraped off the old FIPG and it looked like new.
'99 SR5 3.4L 2WD
SOLD
Build Thread
2014 4runner SR5
Old 05-09-2012, 06:39 PM #7
Drcoffee's Avatar
Drcoffee's Avatar
Just tighten it until the rubber washer matches the steel washer diameter. It's very easy. Now someone else mentioned the half moon prices. Those don't need to be new because you can clean them and reseal with FIPG. Which also needs to be applied at the half moon seams. Hopefully you've done both otherwise you'll be leaking again. FIPG is a toyota glue and it's about $20 but it's good stuff.
Old 05-09-2012, 06:57 PM #8
bak3rme's Avatar
bak3rme's Avatar
yup i got it on there. just hope its enough i used a bit on each
'99 SR5 3.4L 2WD
SOLD
Build Thread
2014 4runner SR5
Newbie Help-- Valve Gasket and Trans Oil Pan Gasket Terminator_T4R 3rd gen T4Rs 3 11-23-2019 10:47 AM
blown head gasket.... possibly? hvguy 3rd gen T4Rs 34 12-12-2012 12:29 PM
Valve Cover gasket, anything else Aquabear 4th Gen T4Rs 8 03-23-2012 09:02 AM
valve cover gasket t4r4life 3rd gen T4Rs 10 01-08-2010 04:02 PM
Help with Valve Cover Gasket Clemsonfan15 3rd gen T4Rs 9 12-24-2008 12:37 PM
