06-08-2012, 01:22 AM
Cheaper option than this set-up...?
I am thinking of pulling the trigger on the following suspension, but want to know if there is a cheaper alternative or a great source that has these parts for less than toytec (who wants about 200 for each component making it ~$600) that would achieve the same result?
Front: stock springs + bilstein 5100 adjustables (part D558) I think these are for a tacoma?
Rear: OME 890 springs + Bilstein 5125 (4R96-BIL)
Any other bit/parts I need to/should buy when I install these? (I am a noob when it comes to trucks)
The goal is to have a firm but comfortable quality ride with a slight rake and a ~3" lift to fit 33" tires (285-70-17 BF Goodrich T/A KO) on a 97 sr5 3.4l.
06-08-2012, 01:33 AM
Moderator
Real Name: Waldo
Moderator
Real Name: Waldo
If you want comfy, go with ome comfort shocks. I have those front and reear bilsteins, and trust me.. they're not built for comfort! Why would you run stock front springs? That doesn't make sense to me.
Don't be afraid to talk to the guys on the phone or through email. They sometimes will hook ya up with free shipping or a discount. They do run forum discounts from time to time, so get in contact with them and let them know you're ready to pull the trigger. They're great guys.
Edit.. here's the forum discount code thread. I don't know if it's current or the discount but it's worth a shot. http://www.toyota-4runner.org/www-to...ount-code.html
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
06-08-2012, 01:39 AM
im lift shopping/researching too and am confused by wanting to run the stock springs, is that an option??
06-08-2012, 01:50 AM
It is my understanding that you have to run aftermarket coils with the fatter tundra version of the 5100, but I think the version I cited is the Tacoma version with 3 Settings that will fit with a stock coil which toytec sells for our 3rd gen 4runners.
I thought I could knock ~180 off the price by using the 5100 shocks for the lift Killing two birds with one stone while achieving the slight rake that I want. I don't want an even 3" all around, and don't want to have to lift the rear even more to perch it higher than the front. Is this faulty logic, or is it not a compatible setup?
06-08-2012, 02:02 AM
Moderator
Real Name: Waldo
Moderator
Real Name: Waldo
I see what you are saying now, however someone might chime in with a little more experience with using the stock coils and those front shocks. I don't think it will be a comfy ride though if that's what you're going for.
06-08-2012, 02:06 AM
Well comfort isn't my priority. I like a planted feel, but also don't want a brain rattler! How would the stock springs change the ride compared to that shock + an aftermarket coil? And with that setup how would you describe the ride as compared to stock, as best you can? Since you have 5125 + ome 890 in the rear what did you pair w the 5100s in front?
06-08-2012, 06:13 AM
I believe there was a member here that put tundra 5100 in stock coils. I have a set of them that I could compare to stock shock diameter if you're curious.
戦争イーグル
Cory J
Wheel converter,
06-08-2012, 06:17 AM
Yes it is. Simply adjust the mount on the 5100 shock body. The higher you move the ring the stiffer the suspension gets.
戦争イーグル
Cory J
Wheel converter,
06-08-2012, 09:36 AM
Sure, I would be very curious. I thought I read that they didn't fit, but if thy did they would be preferable since they have two more adjustment points! Then again, are there any other cheaper ways of accomplishing my goal or is my proposed setup the least expensive path with reasonable performance?
06-08-2012, 09:37 AM
Too bad there isn't an adjustable rear as well so that I could run the whole setup near stock height at a later date if I wanted to...
06-08-2012, 10:18 AM
You would be much better off finding a set of front springs and setting the 5100's on the lower perch. It'll ride like sh*t with them jacked all the way up, your front end will ride like a basketball.
Adjustables aren't an option for the rear because the rears aren't a coilover design.
As far as saving some money, hunt around for a set of used springs or even a set someone bought but never used (like me.)
06-08-2012, 10:35 AM
Do you have a set I can call dibs on or is that how you found your own set? What is the least expensive coil for the front that will do the job I want?
06-08-2012, 01:29 PM
Since you asked for a cheaper option, why don't you piece it together yourself? I bought LC springs (7 7/8 wrap) for $90 shipped, used OME 883s for $110 shipped, Rough Country front shocks from Wheelers for about $135 shipped, and some Monroe Magnum LC rear shocks from O'Reilly ($88 pair). It looks good and rides great. I have about $425 in it. I put some 2nd gen sway bar links on too - another $50. Just look around on the forums. Guys are always selling springs.
2002 T4R Limited, 191K miles - OME 883 front - LC 7 wrap/2nd gen sway bar links rear - Detroit Truetrac Diff - Cooper A/T3s - Warn M8000 - ARB Bumper - homemade (er, 'custom') rear bumper w/tire & can carrier - BajaRack - Diff Breather Mod - Hayden trans cooler - Yaesu 2M, Cobra CB - Fridge, off-road trailer with Tepui RTT (real expo poser)In Africa they say: "Buy a Land Rover and it will take you anywhere. Buy a Toyota and it will take you there ... and bring you back home." jannikt on wranglerforum.com - I'm guessing he didn't make many friends there with that line.
06-08-2012, 03:09 PM
The set I have is a set of 906's.
06-08-2012, 04:21 PM
I ran 5100s up front with the perch at 2.5" with stock springs for about 7 months and it rode great. Just a little stiffer than stock but still very comfy. When I swapped the stock coils out to toytec/eibachs and 0" on the shocks the ride got even stiffer.
02 4Runner 4WD 3.4 Sport Edition
ryhi's 4runner
99 4Runner 2WD 2.7 Base
ryhi's 4runner #2
