Vibration help on my 2000
Ok I have a 2000 2wd. SR5 3.4 lifted 3 inches 33's I bought it for $5K but instantly put $3k into it. Tie-rods, Ball joints Uppers/lowers, steering rack, all fluids change, Timing belt, water pump, Shocks, etc.....one thing I didnt change was the U-Joints. a few months ago check engine light came on and it was a 420 code for catalytic Converter. I reset light and a few weeks later a loud vibration hit at 60 mph. many people told me U-joints. so I changed the U-joints and catalytic converter. Problem didnt go away. I have no idea what else it could be. Question tho: There is some sort or resonator before the Cat. Could that be plugged? Could it be that I need to replace the entire Drive shaft? some people are telling me that I should have done that instead of just the Ujoints. The Ujoints werent that bad in the front, but the back ones were a bit worn. The truck has 182K on it.
