06-13-2012, 12:13 AM
Wandering on road
Hey guys..
Loving the forum, so much already fixed due to all the help. So with that said I am hoping you can help me figure out why my 4 runner wanders all over the place on rutted roads. I think I need to tack weld the joint in the steering but also want to see if there is anything else I should take a look at.
I have checked all the suspension and its all very tight with no signs of issues other than the sway bar. Any help would be great.
06-13-2012, 12:26 AM
Originally Posted by CarmMontana
Hey guys..
There is a rubber coupling just above the steering rack. Make sure it is in good order as well with no tears/cracks. I replaced mine when I did my body lift.
1998 SR5, V6, 5spd, 3" OME Suspension lift with 2" body lift, diff drop kit, Spidertrax 1.25" Spacers, Goodyear Duratrac 285/75/16 Tires.
Hopefully In the Future: ACME Adapters VW Diesel Engine to Toyota R150F Transmission Adapter Plate so I can do a VW Diesel engine swap.
I'M STILL LOOKING FOR A SPARE 3RD GEN 5SPD TRANSMISSION FROM A V6
LOOKING FOR EXTERIOR PLASTIC CLADDING/FENDER FLARES FROM A LIMITED
Take it to a good alignment shop...
Other things to check for is ball joint play and tie rod play. Its pretty simple to change out the inner and outer tie rods, as well as the lower ball joints. You can also replace the steering rack bushings. But to me, Id try looking into a good alignment shop and having them dialing it in.
2005 Limited V8 4x4 4Runner
2005 SR5 V8 4Runner
1997 40th Anniversary FZJ80
2001 Ford F350 w/ FWC Hawk
06-13-2012, 08:05 AM
If the steering components are in good shape, talk to your alignment shop and have them add in as much toe-in as they can, Within the allowable range. Toe-in helps with that twitchy steering feeling when the tire wants to wander around.
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
06-13-2012, 09:27 AM
Hey guys..
I doubt your steering slip joint is the problem. Lots of people jump to that one right away because there's a neat write-up on it, but that is a very specific problem, and is by far not the most common cause of wandering like you describe. If you read the write-ups, it gives you an easy procedure for checking this (sticking your hand down on the steering column, turning the wheel and feeling for play in the slip joint). If that procedure doesn't result in obvious play, then don't tack weld a safety feature...
It could be lots of things:
Lower Ball Joints
Inner tie rod ends
Outer tie rod ends
worn out suspension (this is pretty common, and is mostly limited to wandering on bumps)
control arm bushings
Then if all else checks out, it may be in the steering column, but you should go there last.
I would put my money on worn out suspension.
Adjusting toe to the extreme of the spec would just be a band-aid to cover the real problem. Something is worn out and needs to be replaced. I replaced most of these front end components all in one shot and now my 13 year old 4runner drives like it's brand new.
2000 SR5 3.4L V6 Automatic 4x4, e-locker, 175k Miles, Rust
Imp. Jade Mica with Oak Leather Interior, Field Monitor Unit - B&M Tranny Cooler - SG2 - New (to me) rear axle assembly - Goodyear Duratrac 265/75-16 - 1.8" Ironman Front Lift, OME 906/Procomp 9000 Shocks
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
06-13-2012, 01:48 PM
I have the same problem with my 4R. Had the problem since I bought it.
Mine drives fairly well on flat, smooth roads, but easily affected by wind. When driving down a road with ruts (semi trucks, well used, etc) it'll get very twitchy and caution is required. Reminds me of a snowmobile with the improper toe out and what sledders call "darting".
I'm in the process of lifting it, which has me worried about not tracking down this problem first, however, I feel fairly confident that it's an alignment issue. Tire wear proves some of that with irregularly worn tires.
So, I may be creating a headache anyways, but I'm lifting it with LC/TRD set-up, new tires, and alignment. If it's not fixed I'll start looking at steering bushings, etc since I'll ask the alignment shop to confirm tie rod and upper ball joints prior to doing the work. I just replaced the lowers with OEM ball joints. I was supposed to have uppers but they were out of OEM and apparently weren't getting anymore in. I wasn't going to put in generic brand ball joints so for the time being I skipped out on it.
I know alignments aren't cheap, but if you have a chance, jack up the tire. Do the prybar test for ball joints. Confirm tie rods appear tight. If all is good, take it and get the alignment done. I'm fairly sure it'll fix your issues and save your tires!
06-13-2012, 03:53 PM
Excessive toe-in with radial tires negates their lower rolling resistance advantage over bias-ply tires. This will reduce fuel economy and increase wear. I would consider a urethane anti-sway bar bushing kit, rotate the tires, and get an alignment.
2000 SR-5, V6, 4WD, 5-Spd
07-07-2012, 12:01 PM
Ok guys... Back to the top. After the lift and alignment with the tie rods replaced I still have the wander. On flat roads it's great, tracks straight and everything is good. On rutted roads it's scary... So I took it back to the alignment shop and they told me everything is good, all is tight and they aren't sure what's up. They thought it may be the tires. Any thoughts?
1998 Toyota 4Runner Limited "Angus"
1969 Toyota Landcruiser FJ55 "IRONPIG"
1998 Toyota Tacoma (Sold)
07-07-2012, 12:27 PM
Real Name: Phil
Real Name: Phil
There are so many threads on this forum about front end issues. Literally almost every day theres a new thread about someones loose steering, vibrations, knocking or clunking, etc . . . And a lot of guys like you and myself have replaced the front end components that would typically cause these issues. Granted the problem is not always the same for each case, and new ball joint, inner/outter tie rods, rack bushings, shocks and coils, wheel balancing, and alignment all seem to help to a point. But Im convinced in the end the majority of steering slop and related issues fall back on the steering rack. Ive driven many many cars and trucks, and never felt a front end quite like the 3rd gen runner. One minute the steering seems tight, then you hit a good size bump and your steering wheel goes crazy. The rack is what keeps the wheels in place (along with centrifical force of the rolling tires of course). But its the tightness in the rack that keeps the wheels from pushing or pulling sideways when one tire hits a good sized pothole, or when a large gust of wind hits you on the highway. Granted the 4runner is tall and square, so side winds are going to push it. But in the end my theory is that the 3rd gen OEM rack has some issues with holding the wheels tightly in place. When so many of us have replace our front end components and still have these issues, an overly loose steering rack is the only answer that makes sense.
267/75/17 Cooper ATs - Level 8ZX wheels matte black - EBC rotors/ pads - 99 coils/ Bilstein 5100s - deckplate - Sotashi/custom emblem - Hella micro DE fogs - Kenwood/Alpine/Infinity system - sound deadened interior - color matched bumpers - LED tails - Safari LTD rack - Husky floor liners - clear corners
07-07-2012, 02:27 PM
Front end
I agree with you 1985taylor! I just got done replacing all front end parts(Otr,itr,lbj,ubj,remaned steering rack) and had an alignment and although it is better, it still wonders on anything other than a smooth and flat road! It is almost as bad as my 2000 f350! I do have a bent rear lower control arm I took off this am to straighten but I am not hopefull that it will help. I feel it is just the nature of the beast. I am going to get me some spiderrtax spacers and see if sliding out those wheels will help with the tip top feeling, my fj cruisers wheels tuck tight under the runner and make it feel a little top heavy.
98 Limited ko2s stock!
Sold-88,86,89,95,11,91 on Tons, 00 and 07-4runner, 07 Taco, 70-40,01-Tundra,97 FZJ 40th,98 & 04 LC
07-08-2012, 12:16 AM
Real Name: Phil
Real Name: Phil
Im on my second remanufactured rack, and I will never waste my time on one again. They are useless. The next rack I get will be brand new.
So the truth about wheel spacers . . . wheel spacers are going to make your front end feel even more sloppy. I posted this picture a while back to illustrate this in a different thread where wheel spacers came up. Your wheels swivel at a pivot point, and when you add a spacer you increase the distance between the wheel and pivot point. That creates more leverage for swiveling the tires. Its like adding a cheater bar to create more leverage when trying to remove a bolt (granted on a very minor level). But with the influence of 5000lbs pushing the tires, that small spacer will make a noticable difference. I added 1.5 spacers to my stock wheels several months ago, and the front end wandered like crazy.
07-09-2012, 07:43 AM
Thanks guys for the info. Im at my wits end here. I will look into the rack and see if I can swing that.
Just out of curiosity has anyone changed the guide on the rack, or tightened the guide bolt. Ive heard that helps a bit and was wondering if it would...
07-10-2012, 12:06 AM
Anybody done this?
07-10-2012, 12:43 AM
I have the same problem as the OP.
I have tightened the guide bolt and replaced my rack bushings so far. There was improvement from doing these things but the problem remains. I just received a newer style guide and will install that next. After that I'm looking at the column.
Maybe the extra leverage/stress just makes apparent an existing problem? I'm not willing to give up my 1.5" spacers without trying many other possibilities... can't anyway due to tire rub.
'99 Limited, Millennium Silver, E-Locker
Front: '99 Tall Springs, Tundra Bilstein 5100's @ 5th perch, 3/8 in. Top plate spacer, Light Racing/SPC UCA's, 1.25in wheel spacers, sway end links from 2nd gen rear
Rear: Toytec Superflex, 05'+ Tacoma Bilstein 5100's, extended bump stops, extended brake line, e-brake strain relief bracket, 1.25in wheel spacers, front sway bar links, ES sway bushings
Other stuff: 1/2" body lift, B&M tranny cooler, extended rear diff breather, deckplate, blue-wire mod, ARB Tacoma BullBar, Smittybuilt XRC8 winch, 285/75/16's
07-10-2012, 10:05 AM
Hopefully you're taking your trucks to a good alignment shop and not some ignoramus at a tire shop.
A seasoned alignment/front end specialist will be able to tell you exactly whats up. This shouldn't be such a mystery.
Have you tried jacking up the front and tugging on the tires at 9 and 6 o'clock? Is there play? Where is it coming from? Hows your bushings look on the a-arms? Have you replaced the ball joints? Steering rack bushings ok? Inner and outer tie-rods looking decent? The rack guides do have play, but I've never got wondering from it.
When I had my first 4Runner, I lifted it and it sucked on the highway. I wasted money spending it on stupid alignments from tire shops that just read stuff from a computer. I then took it to an alignment specialist (yes they will cost more, but you get what you pay for) and it fixed my problems. Now I never go back to a general shop for that work.
2005 SR5 V8 4Runner
