09-09-2014, 04:36 PM
#16
Real Name: Matt
Real Name: Matt
alright when i buy and install them, ill post back on here, about what my experiences are
09-09-2014, 04:47 PM
#17
I did a real easy LED interior light upgrade by going to Advance Auto Parts. They sell a 12 light LED unit called "DomeLitz". Simply remove the existing maplight cover, dome cover and rear cargo area light cover and plug these babies in! It comes with all the adapters you need for a simple plug and play. When you order them online and enter a discount code, they are cheaper. I did not want to wait for an online vendor to ship them to me. Everyone who sees these lights always asks where I got them. They are awesome and put off LOTS of bright, white light.....
09-16-2015, 08:45 AM
#18
Anybody know the dome litz part number?
Thanks
09-16-2015, 09:36 AM
#19
official vendor
official vendor
Thanks
Use SuperBrightLEDs! Much cheaper, color options, and fast shipping. Plug in the information for your 4runner, and it tells you what you need. You can also reference the chart on the first since they use those bulb numbers.
09-16-2015, 12:28 PM
#20
09-16-2015, 03:34 PM
#21
The DOME LITZ (12 led panel) at Advance Auto Parts is number 77254. These are AWESOME and inexpensive and LAST FOR YEARS! They also come with all the adapters you might need.
09-21-2015, 09:24 AM
#22
Real Name: Justin
Real Name: Justin
I need some information to those who have swapped LEDs into the a limited with the digital AC, once you swap the bulbs over does the middle part where it shows the temp and the position stay on? I did the LED swap yesterday and the middle part is always lit up now. Also I would not recommend anyone buy the neowedges from Superbrightleds.com. I ordered some to replace the etc/rear window switch and they would not fit at all.
09-21-2015, 09:35 AM
#23
Originally Posted by 95yotarunner619
ok, what about the turn signals, would a flasher be required. i read on that link that the stock flasher might not be able to handle the leds
My front turn LEDs required resistors. When I switched my rear brake/turns to LEDs I had this bizarre situation that every time I activated a turn signal it would also activate my brake lights...I found this out because it would cancel my cruise control every time I would signal to switch lanes...I never figured out why this happened nor an easy fix...just switched the tails back to the originals. Some other threads suggested something to do with my hitch wiring.
Hope it al works out for you!
(SOLD)1999 4Runner SR5, 5spd-R452d 5th, 4x4 “Highlander”
Supercharged, Lifted, Dual cased, Dual Locked, Geared, Armored and more...
Papabeach Mod Thread
(SOLD)1997 Land Cruiser FZJ80
1979 FJ40L-KC
09-22-2015, 12:49 AM
#24
Real Name: Zach
Real Name: Zach
sylvania.com has a pretty good online auto replacement guide. Found a lot of part numbers for lights through their site
My Build Thread
1999 Highlander Edition w/ Factory E-Locker: Alarm/remote start, FN 5 star wheels, 285/75/16 Duratracs, King 2.4 Ext Travel C/Os, LC shocks/8 wraps, 1" Diff drop, Airaid Intake, Dual B&M 70264's, Satoshi grille, 01 Tails, shackles, Rear diff breather extension, Blue wire mod,Taco whip antenna, Window tint, Bi-xenon Morimoto Mini Stage III projectors, 231mm Tundra Brake Upgrade, Interior LEDs.
09-22-2015, 03:53 PM
#25
Real Name: Mitch
Real Name: Mitch
The middle part does stay on for me. I ordered all of mine from superbrightleds.com too and didn't have any issues.
Mitchell Schweitzer
1999 Toyota 4Runner Limited "Forerunner"
"Forerunner" Build Thread
09-22-2015, 04:00 PM
#26
official vendor
official vendor
I hardly doubt this is a reason to tell everybody to not buy from SuperBrightLED!
Post up which bulbs you got that wouldn't work.
09-22-2015, 04:17 PM
#27
Real Name: Justin
Real Name: Justin
I mean't not to buy the neo wedge type a from them. The ones they sent me would not fit in the wholes where the factory ones came out at all. It seemed like the base that held the LED was too big.
09-22-2015, 06:52 PM
#28
official vendor
official vendor
You ordered the wrong bulbs then. I bought all of mine from them including the Neo-wedges, and they worked just fine on mine.
09-22-2015, 06:57 PM
#29
Real Name: Justin
Real Name: Justin
I ordered the right bulbs because the fit in the climate control which are the same size. I went by what size the chart said to get.
09-22-2015, 07:42 PM
#30
official vendor
official vendor
and you bought one of these two bulbs?
