Old 06-20-2012, 03:52 PM #1
SIKHILUXSURF's Avatar
SIKHILUXSURF SIKHILUXSURF is offline
SIKHILUXSURF is on a distinguished road
TRD Transcooler owners or similar cooler owners check in please
Hey guys just checking to see what you guys with TRD, B&M coolers of similar sizes drain and fill to?
i usually drain and fill about 3 qts. with out the trans cooler and now since having it i have drained and filled about 4.5 qts.
How much fluid are you guys filling in your guys trans and coolers?
99 4runner W/01-02 conversion
JDM Headlight Retrofit w/ custom LS460 bi xenon projectors,ODL Bumper,japan spec conversion ,Hella Twin Supertone horns,Kings 2.5" External Resi Compression Valved front and rear, Camburg UCA's,Addcco Sway bars,TRD supercharged,AFE Intake,Custom apexi catback,TRD Trans Cooler,Lots of Jaos Goodies,16x8 Volk Racing TE37X's BFG KO2 265/75/16 Stoptech Big Brake Kit
SIKHILUXSURF is offline   Reply With QuoteReply With Quote
Old 06-20-2012, 04:12 PM #2
Brilliant's Avatar
Brilliant Brilliant is offline
Brilliant is on a distinguished road
Brilliant's Avatar
Disconnect the send line and let the trans pump out into a bucket as you refill from the dipstick. Takes ~13 quarts IIRC to flush it. Not sure the value of only changing 3qts.
Brilliant is offline   Reply With QuoteReply With Quote
Old 06-20-2012, 05:03 PM #3
wasnt what i was getting at as i have done the trans flush already. and already know that info. i am curious to what others are filling their trans with extended coolers inline to.
Old 06-20-2012, 05:06 PM #4
Stick Figure's Avatar
Stick Figure Stick Figure is offline
Stick Figure will become famous soon enough
4.5 sounds closer to what I have used in the past, I honestly don't know that I ever changed it before having a cooler added in line to give a "stock" comparison.
Stick Figure is offline   Reply With QuoteReply With Quote
Old 06-20-2012, 06:05 PM #5
hugo2go's Avatar
hugo2go hugo2go is offline
hugo2go is on a distinguished road
hugo2go's Avatar
4-4.5 sounds about right.
Thats what mine drained out
hugo2go is offline   Reply With QuoteReply With Quote
Old 06-20-2012, 10:16 PM #6
KHoffRunner's Avatar
KHoffRunner KHoffRunner is offline
KHoffRunner is on a distinguished road
I just hooked my cooler up and when I disconnected the lines let them drain into a clear bottle and filled the it with the amount that drained out. should I add more?
2000 Limited:250K, Icon 2.5 fronts, Toytec Superflex rears/Bilstein 5100's, Yokohama Geolander AT 285/75/16, diff drop.
KHoffRunner is offline   Reply With QuoteReply With Quote
Old 06-21-2012, 09:12 AM #7
jonwilly2 jonwilly2 is offline
jonwilly2 is on a distinguished road
use the dip stick I put a 12x6 cooler with longer hoses and put pint in and checked the dip stick. Its not like a radiator that is a lot of space so only little extra is needed.
2000 4Runner SR5, Cold air intake, Auto, 2wd, 4.88, big dent
1995 4Runner SR5, E-locker, ATs, 5 speed 4x4
jonwilly2 is offline   Reply With QuoteReply With Quote
4.0 owners: how many added Trans cooler? 8086bruce Polls 30 05-18-2010 09:42 PM
Attention 4.7 V8 owners: Forget superchargers, check this out spanvs888 Engines / Suspension / Wheels / Tires / Audio / Accessories 5 04-28-2008 03:06 AM
2006 Owners check your lug nuts BC4Runner Maintenance/Detailing 1 07-06-2006 08:20 PM
Dog Owners - check this out exokomp 4th Gen T4Rs 16 03-26-2006 12:00 AM
Bug Shield owners check in Scrappy125 Engines / Suspension / Wheels / Tires / Audio / Accessories 15 02-03-2006 08:58 PM
